clouds and storms without PWM expansion?
grafxalien
Post by grafxalien »
Just a quick question. Is it possible to code for storms and clouds with just the standard 2 PWMs that are on the unit. I have a small 10 gal tank so I only have two channels. My "clouds" would be more just random dimming and lightning be random very bright ramping up. Just wondering because most of the code I have seen for this uses the PWM expansion
Re: clouds and storms without PWM expansion?
Sebyte
Post by Sebyte »
I have just added it to my setup, the cloud effect is ok, but I have removed the lightning effect as it does not work well with my MeanWell drivers. Also it was traumatic for the fish :?
grafxalien
thanks. will have to give it a try a little later. I am using steve's led drivers. will let you know how they react.
Awesome.
I'm very interested on knowing how those drivers work out.
I'm actually specially interested on knowing if they really can dim down to 1% and how hot the chip gets.
When you find out what is the lowest cutout point, will you let me know?
I've made my own LED drivers in the past that could dim to 1% and had super fast response.
The only probem I had was that they used to generate lots of heat.
grafxalien
I just got my controller a few days ago and actually haven't had time to wire it up to tank. will keep you posted. this is my first time coding, another quick question for you. I am trying to make a manual bypass mode for the lights. my idea is to make a menu item where each time it is clicked, it will add 10 to the PWM value, and then after 100% would go back into auto mode where lights are controlled by the pwm ramp. default would be control by pwm ramp. so: auto, 0 ,10, 20 etc, 100, auto.
Right now I am just trying to get it to bypass the pwm ramp and set actinic to 10%. And i am even failing at something that simple. here is what i have:
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
boolean LEDauto=true;
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Force Storm";
prog_char menu2_label[] PROGMEM = "Actinic";
prog_char menu3_label[] PROGMEM = "Daylight";
menu1_label, menu2_label, menu3_label  };
void MenuEntry1()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry2()
LEDauto=false;
ReefAngel.PWM.SetActinic(10);
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardATO(Port1);
    ReefAngel.MHLights(Port3);
    ReefAngel.StandardFan(Port4);
if (LEDauto)
// Calculate your regular sunrise/sunset PWM value
    ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(10,00,22,15,0,30,40,DaylightPWMValue);
    CheckCloud();
There is nothing wrong with your code, at least not from I can see it, but something tells me that you only have 1 menu option enabled. That's why the MenuEntry2() function is being ignored.
In fact, the code is pretty awesome!! :)
You get to force % on demand. Cool!
Open ReefAngel_Features.h file and look for:
#define CUSTOM_MENU_ENTRIES 1
The file is located at "Documents\Arduino\libraries\ReefAngel_Features" folder.
If the number is 1, you need to increase to 3, which is the number of menu entries you have.
grafxalien
that was exactly it. I got it to just set PWM to a number easily. Now i cant get it to cycle through 0,10,20,...,100,auto like i want it to do. any ideas?
byte Actinic=0;
void MenuEntry1()
ForceCloud=true;
void MenuEntry2()
  LEDauto=false;
  if (Actinic==0);
   ReefAngel.PWM.SetActinic(0);
   Actinic=1;
  if (Actinic==10);
   Actinic=0;
   LEDauto=true;
  if ((Actinic>0) && (Actinic<10));
  ReefAngel.PWM.SetActinic(ReefAngel.PWM.GetActinicValue()+10);
  Actinic=Actinic+1;
I haven't tested, but try this:
void MenuEntry2()
  ActinicPWMValue+=10;
  if (ActinicPWMValue>100)
    LEDauto=true;
    ActinicPWMValue=0;
    LEDauto=false;
rimai wrote:I haven't tested, but try this:
void MenuEntry2()
    LEDauto=true;
    ActinicPWMValue=0;
    LEDauto=false;
That code looks good. That's exactly what I would suggest doing.
grafxalien
that code almost did it. it scrolled between the auto value and 100. would not go below the auto value. it did teach me what i needed to know to fix it though. working code is below. thanks for the help! cant wait to get enough time off work to hook it up to the tank!
void MenuEntry2()
      if (LEDauto)
      ActinicPWMValue=0;
      LEDauto=false;
          LEDauto=true;
grafxalien
full working code with 2 channels. requires both channels to be toggled to "auto" position in order for auto mode to work.
boolean Actinicauto=true;
boolean Daylightauto=true;
void MenuEntry1()
ForceCloud=true;
void MenuEntry2()
      if (Actinicauto)
      ActinicPWMValue=0;
      Actinicauto=false;
          Actinicauto=true;
          ActinicPWMValue=0;
void MenuEntry3()
      if (Daylightauto)
      DaylightPWMValue=0;
      Daylightauto=false;
      DaylightPWMValue+=10;
      if (DaylightPWMValue>100)
          Daylightauto=true;
          DaylightPWMValue=0;
if ((Actinicauto) && (Daylightauto))
    CheckCloud();
Good stuff :)
grafxalien
trying to make sure i have all the bugs worked out before i hook it up to tank. today i noticed that client suite always reads 0% for both PWM channels. The screen on the reef angels says says otherwise. Any idea how to fix this?
complete code:
// Autogenerated file by RAGen (v1.2.1.158), (03/28/2012 22:23)
// RA_032812_2223.ino
#define DisplayLEDPWM
#define wifi
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 8
prog_char menu4_label[] PROGMEM = "Feeding";
prog_char menu5_label[] PROGMEM = "Water Change";
prog_char menu6_label[] PROGMEM = "ATO Clear";
prog_char menu7_label[] PROGMEM = "Overheat Clear";
prog_char menu8_label[] PROGMEM = "pH Calibration";
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label  };
void MenuEntry1()
ForceCloud=true;
void MenuEntry2()
      if (Actinicauto)
      ActinicPWMValue=0;
      Actinicauto=false;
          Actinicauto=true;
          ActinicPWMValue=0;
void MenuEntry3()
      if (Daylightauto)
      DaylightPWMValue=0;
      Daylightauto=false;
          Daylightauto=true;
          DaylightPWMValue=0;
void MenuEntry4()
ReefAngel.FeedingModeStart();
void MenuEntry5()
void MenuEntry6()
ReefAngel.ATOClear();
void MenuEntry7()
ReefAngel.OverheatClear();
void MenuEntry8()
ReefAngel.SetupCalibratePH();
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port6);
  //  ReefAngel.SingleATOLow(Port1);
    ReefAngel.StandardLights(Port4);
    CheckCloud();
       ReefAngel.SingleATO(true, Port1, 60, 1);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
    if (ForceCloud)
    ForceCloud=false;
    cloudchance=1;
    cloudduration=10;
    lightningchance=1;
    cloudstart=NumMins(hour(),minute())+1;
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      if ((cloudstart/60)>=10) x=11; else x=17;
      if ((cloudstart%60)>=10) x=29; else x=35;
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Try removing the ShowInterface() right above Port2.
You should only have on ShowInterface(), which should be at the end of the loop().
grafxalien
fixed that. now it displays whatever the calculated value is from the auto mode, even when I have it in manual mode.
Cool :)
grafxalien
any ideas on why the client suite always displays the value calculated from sunrise/sunset code even when I am running the lights in manual mode?
grafxalien
looking in to it more it appears that reef client is not updating very often at all. from error log:
*****4/3/2012 3:48:34 PM*****
Message:
Unexpected end of file has occurred. The following elements are not closed: RA. Line 1, position 5.
StackTrace:
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String arg)
at System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r)
at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r, LoadOptions o)
at System.Xml.Linq.XDocument.Load(XmlReader reader, LoadOptions options)
at System.Xml.Linq.XDocument.Load(TextReader textReader, LoadOptions options)
at ReefAngelWCFListener.ReefAngelListener.BuildRelayStatuses(String xml)
grafxalien
rimai wrote:Awesome.
the steve LED drivers work amazing. Super fast response time. dim smooth down to 1%. I would highly recommend his products!
Does it get any hot?
grafxalien
the driver? i will give it a test tomorrow. I have them mounted to a pretty large heatsink though.
here is my tank build thread so you can see what i mean
http://www.nano-reef.com/forums/index.p ... 273895&hl=
Nice build :)
Yeah, I was talking about the driver chips itself, but I see you have it mounted on the heatsink for dissipation, whick is a good idea.
I'll get one of those drivers sometime to check it out.
