ORP+SALINITY Probe in one module.
abhi_123
Was looking around & find all the controller manufacturer make separate module for salinity & ORP. Is it not possible to have both of them in same module or they just do it to make us spend an extra 80 bucks?
Can we think of having a single module for handling both by Reef Angel manufacturers? If it is so that will be a very well deserved addon for every reef hobbyist who is using ozone or willing to use ozone in future.
Re: ORP+SALINITY Probe in one module.
It's much easier to build them with independent circuits than together in one circuit.
They need galvanic isolation or they would interfere with each other.
The components to isolate the two circuits would cost even more than building them separate.
abhi_123
Thanks roberto. Btw when we are going to have modules for orp & salinity?
abhi_123
claudacate
I am waiting for the orp addon before I purchase reef angel so I can save some money on shipping. Anyway to subscribe to news about reef angel so I don't have to check the forum every other day for news about orp? Thanks
ruckusman
How do you calibrate the salinity probe. When I click ok in the calibrate it just closes out. Does that mean its fine? It has a red zero past the 35ppt. I assume the 35 ppt is what it is reading? Which I think is my target of about 1.026
Are you using custom menu by any change? Or simple menu?
ruckusman
simple menu.
ruckusman
I'm clearly not getting something because my salinity dropped do to a float valve fail today and its still reading the same...thoughts anyone?
ruckusman
// Autogenerated file by RAGen (v1.2.1.158), (04/06/2012 13:56)
// RA_040612_1356.ino
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define wifi
#define SIMPLE_MENU
#define SALINITYEXPANSION
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.Portal("ruckusman");
#define VersionMenu
#define wifi
#define SIMPLE_MENU
ruckusman
how do I export the features file, I assume you are talking about what I have checked off in the features in RAGEN...I see import but not export. I assume you don't want a simple print screen of that. Sorry for not knowing...
The file is located at "Document\Arduino\libraries\ReefAngel_Features\ReefAngel_Feature.h"
The code above does not even have display of salinity on the screen.
You need to create a custom main screen for it.
Take a look at the sample code. File->Sketchbook->Example Codes->CustomMainScreen_Salinity
ruckusman
I added the salinity example code...still don't see it on the menu other than to calibrate....
ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
For more information about custom main screen: http://forum.reefangel.com/viewtopic.php?f=14&t=109
To be able to use the custom main screen and salinity, please make sure that you enabled custom main screen and salinity on your features file.
Open RAGen and make sure you have Custom Main Screen and Salinity checked under the Features tab.
Or, you can manually edit the file.
The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
#define CUSTOM_MAIN
strcat(text," ");
#define CUSTOM_MAIN
ruckusman
features file
// AutoGenerated file by RAGen (v1.2.1.158), (04/24/2012 17:13)
* Copyright 2010-12 Curt Binder
* Licensed under the Apache License, Version 2.0 (the "License")
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#endif // __REEFANGEL_FEATURES_H__
#define VersionMenu
#define wifi
#define SIMPLE_MENU
- Contact:
The only thing in the menu is calibration for the Salinity module. There's not much else you can do in the menu other than calibrate the Salinity module. If you want to see the actual salinity, you must display it on the screen which is what it looks like you are doing.
ruckusman
I guess that is what I was asking. Should it be on the main display, or just visible under calibrate salinity. Under calibrate salinity I see 35 ppt or m can't remember. Except I don't think that is accurate based on my other readings. Am I not understanding calibrate?
If you are not seeing it on the screen, you need to turn on custom main screen.
Open RAgen->Features tab
Check Custom Main
Click Save
Upload your code again.
Check Custom Main
Click Save
ruckusman
after I did that I still didn't have salinity on the display. I tried to upload the custom main with salinity and get this.
ReefAngel\ReefAngel.cpp.o: In function `ReefAngelClass::ProcessButtonPressCustom()':
C:\Users\bharper\Documents\Arduino\libraries\ReefAngel/ReefAngel.cpp
undefined reference to `MenuEntry1()'
I have reloaded the ra gen code with the custom menu and custom main 3 times..
Not custom menu.
You don't have custom menu.
You only need custom main.
ruckusman
When I didn't choose custom it said my file was to big. can I just change it back to simple menu?
ruckusman
To make sure I am understanding, simple menu is the list of items I get once I click the button, custom main is what I get when I move the joystick and activate the screen. one has nothing to do with the other than the word custom?
That's what you should use... Simple menu and custom main.
The menu is what you get when you press the joystick and screen is what is normally displayed when you do nothing.
ruckusman
I follow you. Sorry, for the confusion. That is simple enough to understand if I just take the time to understand it instead of clicking and uploading.
Jorge Ramalho
- Contact:
I see the ORP module, as the Salinity one, is driven at 9V. Is that the reason we need galvanic isolation? If it was driven at 5v would I still need to isolate them?rimai wrote:It's much easier to build them with independent circuits than together in one circuit.
I'm asking because I'm building a controller based on an Arduino Mega and some shields I'm building. Until now, the pH shield is working fine (took the circuit from Reef Angel plus Schematic), but I don't want a lot of wires (BUS cable and power supply for each module) to build the whole system.
Enviado do meu iPhone usando o Tapatalk
Jorge Ramalho
- Contact:
