Setting up a new reef angel
paxton106
Good morning to all, trying to set up my reef angel on a MAC and for some reason when setting up the wifi portion I am getting a flashing green light, and not truly connecting to the wifi. Any suggestions?
Re: Setting up a new reef angel
flashing green means it is conneted. do you mean flashing blue?
paxton106
No it is flashing green, but I am getting a dchp error message and I am not able to get an I.P. address. Is there a way to test the wifi?
paxton106
The DHCP says False, but the rest seems to say it has a good connection, with the exception of the I.P. address
What are you using for router airport?
Check on attached devices on the airport utility.
paxton106
No i am using my home wireless network
What security mode and encrytion are you using?
Use WPA2-PSK with AES encryption.
If you have mixed mode or mixed encryption, it could it.
paxton106
I am using a mac does that make a difference? and where would I find the security mode and encryption?
No, doesn't make a difference.
You need to login into your router to see your wifi settings.
paxton106
Sorry, but not sure how to log into the router
Sebyte
Have a look at the user guide for your router, if you don't have one Google the make and model and you should find a copy.
Look for the router IP address, mine is http://192.168.2.1/ and this is often used as a common address.
To access the router via a web browser by entering the IP address in the address bar.
i.e. http://192.168.2.1/ or what ever yours is.
That should then bring up the router home page and from there you can access all the features.
