Ph cal
Would you like to help?
PostPosted: Mon Apr 02, 2012 7:22 pm
You got PM
PostPosted: Mon Apr 09, 2012 10:53 pm
Calibrated to pH 4(244, adjusted to 544 via phone app) and pH 10(840, don't know what to adjust to since I can only go to 1024). Been playing with the numbers and I can't really find my sweet spot. It's read from 6.6 to 8.9. The only other way to check pH is a redsea kit, showing 7.8. What am I doing wrong? Adjusting all from the phone app.
I let the probe sit in the solutions roughly 10 min (I was worried about the temp variations so I cut it down a little), rinsed between solutions also.
PostPosted: Tue Apr 10, 2012 7:44 am
544 for pH7 and 840 for pH10 seem correct numbers.
PostPosted: Tue Apr 10, 2012 9:21 am
The issue is that those settings make my pH read ~6.6
PostPosted: Tue Apr 10, 2012 9:42 am
What were the numbers you got for pH4 and pH9?
PostPosted: Tue Apr 10, 2012 10:48 am
I calibrated to 4 and 10. I got 244 and 840, respectively.
PostPosted: Tue Apr 10, 2012 10:52 am
Oh, one other thing. Doing through the phone, Client or any app will require you to reboot the controller after you save the numbers.
PostPosted: Tue Apr 10, 2012 11:08 am
Thanks, rebooting now
Reading 7.6
RedSea is currently reading 7.8
Changed the pH10 to 740, the RA is reading 7.87 now...fixed
PostPosted: Wed Apr 18, 2012 10:56 pm
hi everyone!
I am a bit slow thinking and i don't get it :(
so i got Ph9 and PH 7 from Dupla because nobody sells 10, i was looking all around australia and nothing
with 10 calibration...
so if anyone knows how to setup with 9?
7 is all good but 9 :?
sorry for the silly question and thanks heaps in advance.
cheers.
Slow down to speed up
PostPosted: Thu Apr 19, 2012 7:18 am
Just go ahead and go through the calibration with 7 and 9.
Write down the numbers you are getting on the calibration process.
It's just simple interpolation.
Post those numbers and I'll help you with that.
PreviousNext
Return to Tutorials
