Ph cal
Would you like to help?
Re: Ph cal
You should increase slightly.
jemw
Re: Ph cal
Post by jemw »
rimai wrote:You should increase slightly.
Do I have to reboot controller?
_____
Jim
Re: Ph cal
Yes, for every change you make on the PHMax value.
jemw
Re: Ph cal
Post by jemw »
Not sure what is going on, but the pH calibration function appears not to function correctly. I finally had to take the initial readings given by the function and then read the pH7 and pH10 calibration fluids and manually adjust from within ReefAngel Client. It took me about three adjustments with each the pH7 and pH10 calibration fluids to tune it in. My pH probe is now in sync with my pH test kit.
Needless to say that cycling the equipment that many times adds to the possibility of failure. :( You really need to address this issue.
_____
Jim
Re: Ph cal
Thanks for the observations and it's been logged for future updates.
Re: Ph cal
Did you rinse the probe before transfering and let it stabilize on the pH 10 for while?
Re: Ph cal
They shouldn't be the same.
What happens to those numbers if you dip the probe into vinegar?
alexwbush
Re: Ph cal
Post by alexwbush »
mine was weird in that my numbers were:
211 (7.0)
523 (10.0)
Right now reads 7.82
Sebyte
Re: Ph cal
Post by Sebyte »
For a Standard test that is cheep and repeatable I use the 20 Mule Team Borax test.
Borax or sodium metaborate solution will always be at a pH of 9.18 + 0.02, even if you do a poor job of making this solution.
Use a pint of water (473ml) and add a half teaspoon (1/2 level tsp.) of borax to make a resultant pH standard solution with about 2 gm of sodium metaborate per 473 ml or 4.3 grams of sodium metborate/litre.
Although using this method to make the standard will only result in an accuracy of about plus or minus 10% of the lab standard sodium metaborate pH calibration solution, for me it's a good and cheap test to make sure the probe is on the mark. Compared to commercial solutions you can afford to use this test every week when you clean your probe.
Re: Ph cal
Add these 2 lines to your PDE file, just bellow the ReefAngel.Init()
ReefAngel.PHMin=520
ReefAngel.PHMax=801
Re: Ph cal
sorry. forgot to add ;
use this one instead:
ReefAngel.PHMin=520;
ReefAngel.PHMax=801;
J_C
Re: Ph cal
Post by J_C »
Is there a way to change the values I calibrate to? I only have available pH 4 and pH 9 calibration solutions from all of the LFS in the area. I could order the pH 7 and pH 10 calibration solutions, but then I'd have to order the big bottle.
Re: Ph cal
It's simple interpolation math.
You can get the numbers from pH4 and pH9 and calculate both 7 and 10 values.
J_C
Re: Ph cal
Post by J_C »
awesome, how would I accomplish this?
Just a thought from a noob and some reading
pH 4 reading would be something like 398
pH 9 reading would be something like 903
I would just change the numbers to make them work for the pH 7 and pH 10, something like this?
adjust pH 4 reading to 698
adjust pH 9 reading to 1003
Re: Ph cal
Correct. You just need to calculate the simple interpolation math.
Not too hard, but if you get problems, let us know.
beaker77
Re: Ph cal
Post by beaker77 »
When I finish the pH calibration and leave the probe in the 10.0 solution the controller shows the pH @ 9.87 (which is close enough). But when when I remove the probe from the 10.0 solution and put it in my sump the reading on the controller jumped to 20.21. I put the probe back in the 10.0 solution and the display now reads 19.43. There is no way the pH in my tank is that high. I tested with a Salifert pH test and it shows 8.3
Rebooting the controller doesn't make any difference. I've repeated the calibration 4 times now with the same results.
I've only had the controller setup for just over a week now and my probe is new and never been exposed to air.
What can I do?
Re: Ph cal
Did you do pH7 first?
beaker77
Re: Ph cal
Post by beaker77 »
rimai wrote:Did you do pH7 first?
Yes
Re: Ph cal
Which numbers did you get on screen while doing the calibration?
beaker77
Re: Ph cal
Post by beaker77 »
7.00 = 243
10.00 = 360
Re: Ph cal
Does not look right.
Is the glass bulb in the tip of the pH probe intact?
beaker77
Re: Ph cal
Post by beaker77 »
OMG, There isn't a glass bulb on my probe.
Re: Ph cal
You got PM
J_C
Re: Ph cal
Post by J_C »
Calibrated to pH 4(244, adjusted to 544 via phone app) and pH 10(840, don't know what to adjust to since I can only go to 1024). Been playing with the numbers and I can't really find my sweet spot. It's read from 6.6 to 8.9. The only other way to check pH is a redsea kit, showing 7.8. What am I doing wrong? Adjusting all from the phone app.
I let the probe sit in the solutions roughly 10 min (I was worried about the temp variations so I cut it down a little), rinsed between solutions also.
Re: Ph cal
544 for pH7 and 840 for pH10 seem correct numbers.
J_C
Re: Ph cal
Post by J_C »
The issue is that those settings make my pH read ~6.6
Re: Ph cal
What were the numbers you got for pH4 and pH9?
J_C
Re: Ph cal
Post by J_C »
I calibrated to 4 and 10. I got 244 and 840, respectively.
Re: Ph cal
Oh, one other thing. Doing through the phone, Client or any app will require you to reboot the controller after you save the numbers.
J_C
Re: Ph cal
Post by J_C »
Thanks, rebooting now
Reading 7.6
RedSea is currently reading 7.8
Changed the pH10 to 740, the RA is reading 7.87 now...fixed
