I already use my standard lights and metal halide lights from internal memory to control separate channels of the LEDs. Any easy way to just say outler on at 11:10 pm and off at 9:50 am. This is for a chaeto light running opposite my tank lights.
thanks
I want Port 7 on at 11:10 pm and off at 9:50 am
Re: I want Port 7 on at 11:10 pm and off at 9:50 am
You can use
This will turn Port1 to be on opposite cycle as StandardLights();
Or, you can manually set times:
ReefAngel.MoonLights(Port1);
ReefAngel.StandardLights(Port1,23,10,9,50);
thanks I will use the moonlights option. I did finally find the second suggestion in the forum search but I think I would rather just use the moonlight option. btw this thing has been great and your support is second to none.
after i entered
the MoonLights wording is black? from what everything else looks like should it be red?
As long as it is compiling without errors, you are good.
Updating to newer libraries will make it turn orange.
The orange color is just highlight context asnd sometimes I forget to add them and I catch as we go along and place on the next updates.
