IO expansion module
ahmedess
IO expansion module
Post by ahmedess »
whats it used for?
Re: IO expansion module
Buttons, Float switches, Relay contacts, flow meters
ahmedess
Post by ahmedess »
so the channels can be used as input or output? What is the voltage on the output? Are they all digital channels or can they be set as A/D or D/A channels whether input or output channels?
They can be setup and input or output at 5VDC.
They are all digital. No A/D or D/A available.
btorrenga
Post by btorrenga »
I'm confused, where is the IO module shown on the products web page? Is this the PWM module? I would like to configure several float switches to monitor various topoff tanks beyond the two included ATO ports included.
It's an special order item.
You can check the manual for it at http://www.reefangel.com/Download.ashx
It looks just like the PWM expansion module.
btorrenga
Post by btorrenga »
Ah, I see, thank you for the explanation. I would like to specially order an IO module and a Reef Angel Plus. :)
tkeracer619
Post by tkeracer619 »
I have two of them. Great add on :)
I use them to monitor flow on my... Carbon, GFO, Bio Pellets, and return pump.
abhi_123
Post by abhi_123 »
tkeracer619 wrote:I have two of them. Great add on :)
How you are managing the flow? Simply with the module or some other device too?
