Problem With WiFi.
Re: Problem With WiFi.
I'm not so sure where the 10. came from if your network is setup to 192.
abhi_123
Post by abhi_123 »
192 series is the IP assigned to devices where as 10 series IP are Dynamic IP provided by ISP
abhi_123
Post by abhi_123 »
Finally somehow able to forward the port. Portal & client is working fine.
Thanks roberto & others for their support & patience.
abhi_123
Post by abhi_123 »
prob has started again but this time i am able to use client suite but data on portal is not updating.
abhi_123 wrote:prob has started again but this time i am able to use client suite but data on portal is not updating.
What version of the libraries are you using?
abhi_123
Post by abhi_123 »
Dev 0.9.6
Did your ip address assigned to you by your isp change?
If it changes, you will need ddns
abhi_123
Post by abhi_123 »
rimai wrote:Did your ip address assigned to you by your isp change?
Yep it changes. It's a dynamic IP. The prob looks like to be solved for now. Will see for ddns if its continue.
abhi_123
Post by abhi_123 »
Looks like the prob is sorted completely. Btw here is a link of site which i used for port forwarding quite simple & free too. www.simpleportforwarding.com
Thanks for sharing.
I liked this application a lot, except for the part I had to find which router model I had... lol...
But it was very easy to get it to setup my router.
abhi_123
Post by abhi_123 »
rimai wrote:Thanks for sharing.
Any time Roberto.
