The user id that is in the android app seettings. Is that the same ID that I use on this board? For some reason I have a completely different id noted on my instructions and can't remember why I would have noted it.
With the webbanner stuff, you just had to "pick" a userid and hope it wasn't being used by somebody else. That has changed with the portal. The portal is linked to your login/userid.Mike S wrote:The user id that is in the android app seettings. Is that the same ID that I use on this board? For some reason I have a completely different id noted on my instructions and can't remember why I would have noted it.
If it's not getting or sending data, then something is preventing it from running properly. If it's working the way it should, it will at least give you an error when it's trying to communicate. This may sound odd, but have you removed the application and reinstalled it? What version of the app are you running?symon_say wrote:No error at all, it just don't get or send any data.
I'll see what I can do to get that added.projectx wrote:Great work like that can noe clear overheat and auto time out from the phone. I am going to do a feature beg for expansion relays lol
So we could have a "Download settings from portal?" option that would download the expansion quantity?rimai wrote:Can I ask for featureon next revision?
Maybe use EM and REM from XML to determine the expansion modules available?
I like the idea of it. Currently that could only work for PWM, Salinity and Expansion Relays.rimai wrote:Yes, this would also work for other expansion too.
They could be automatically displayed on main window or additional window when you query the controller or query the reefangel.com site.
if (EM & 1<<0) then it would enable the PWM window or display the %s on main window.
if (EM & 1<<1) then it would enable the RF window or display the mode, speed and duration on main window
if (EM & 1<<2) then it would enable the Aqua Illumination window or display the Aqua Illumination %.
if (EM & 1<<3) then it would display the salinity on main window
if (EM & 1<<4) then it would display ORP on main window
if (REM & 1<<0) then enable expansion relay box 1 window and so forth for additional relay boxes.
I think it would be pretty cool
dedvalson wrote:Looking forward to having the Expansion Relay Support.
You're begs are finally answered. There is now expansion relay support as of 0.5.0.projectx wrote:Great work like that can noe clear overheat and auto time out from the phone. I am going to do a feature beg for expansion relays lol
Welcome.rimai wrote:I love it![]()
I can finally override it without having to go to a computer
Thanks!!!
Welcome. Like I mentioned, I have a fix that will work for 0.8.5.X libraries in case you are still running the older version.projectx wrote:Very cool thank you very much!!
Sent from my SCH-I800 using Tapatalk 2
