Coding Pwm module.
Re: Coding Pwm module.
Well, since you don't show anything on a custom screen, you really don't need anything on your main code.
You could just load the PWM code on your PWM module.
Open the enclosure.
You will see a 6 pin header.
Connect the USB-TTL cable and upload the code the same way you do on the controller.
Black wire is GND
Black wire is GND
Alright.Should I enter the complete code or only pwm expansion custom code in it?
this one.ReefAngel.PWM.SetChannel(0,PWMParabola(9,0,17,0,10,90,0));
ReefAngel.PWM.SetChannel(1,PWMParabola(9,0,16,30,20,95,0));
ReefAngel.PWM.SetChannel(2,PWMParabola(9,0,20,0,0,100,0));
ReefAngel.PWM.SetChannel(3,PWMParabola(9,0,12,0,25,100,0));
byte Fan1Speed;
Fan1Speed=map(ReefAngel.Params.Temp[1],772,800,30,100); // Calculate Fan 1 speed
Fan1Speed=constrain(Fan1Speed,0,100);
ReefAngel.PWM.SetChannel(4,Fan1Speed);
byte Fan2Speed;
Fan2Speed=map(ReefAngel.Params.Temp[2],772,800,30,100); // Calculate Fan 2 speed
Fan2Speed=constrain(Fan2Speed,0,100);
ReefAngel.PWM.SetChannel(5,Fan2Speed);
ok i am trying to upload the above code getting an error "expected constructor,destructor, or type conversion before'.' token "
No. No that code.
You have to copy one of the codes that someone else created on the threads I posted earlier.
Complete pwm code that they posted, but change and adapt to your own setup.
Sent from my SPH-D700 using Tapatalk 2
You could also try helping rufessor test his code.
http://forum.reefangel.com/viewtopic.ph ... 9480#p9480
i am planning to use this code
#include "ReefAngel_Globals.h"
#include "ReefAngel_Features.h"
#include <ReefAngel_Colors.h>
#include <avr/wdt.h>
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
//Globals integers
long calcSec(long,long);
long calcTime(long,long);
short Ndays; //Returns the number of day in the year
byte cloudduration=0;
int cloudstart=0;
int rhour = 0, rmin = 0, shour = 0, smin = 0;
byte PWMports[] ={
3,5,6,9,10,11};
byte ChannelValue[] = {
0,0,0,0,0,0};
// PWM, sunrisehour, sunriseminute, sunsethour, sunsetminute, cloudstarthout, cloudstartminute, cloudduration
byte SeasonsVar[]={
0,0,0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
Serial.begin(57600);
Wire.begin(8);
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
randomSeed(analogRead(0));
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
//wdt_enable(WDTO_1S);
now();
wdt_reset();
//Serial.println(ChannelValue[0],DEC);
if (cmdnum!=255)
ProcessCMD(cmdnum,datanum);
cmdnum=255;
datanum=255;
Seasons();
CheckCloud();
//Serial.println("Start");
//Serial.println(rhour,DEC);
//Serial.println(rmin,DEC);
//Serial.println(shour,DEC);
//Serial.println(smin,DEC);
//Serial.println(cloudstart/60,DEC);
//Serial.println(cloudstart%60,DEC);
//Serial.println(cloudduration,DEC);
for (int a=0;a<6;a++)
analogWrite(PWMports[a],ChannelValue[a]);
wdt_reset();
if (howMany==5)
cmd1=Wire.receive();
cmd2=Wire.receive();
cmd3=Wire.receive();
cmd4=Wire.receive();
cmd5=Wire.receive();
if (cmd1=='$' && cmd2=='$' && cmd3=='$')
cmdnum=cmd4;
datanum=cmd5;
//Serial.println(cmd4,DEC);
//Serial.println(cmd5,DEC);
for (int a=0;a<howMany;a++)
Wire.receive();
void ProcessCMD(byte cmd, byte data)
wdt_reset();
// Individual Channel
if (cmd>=0 && cmd<=5)
ChannelValue[cmd]=data;
analogWrite(PWMports[cmd],data);
void requestEvent() {
SeasonsVar[0]=ChannelValue[0];
SeasonsVar[1]=rhour;
SeasonsVar[2]=rmin;
SeasonsVar[3]=shour;
SeasonsVar[4]=smin;
SeasonsVar[5]=cloudstart/60;
SeasonsVar[6]=cloudstart%60;
SeasonsVar[7]=cloudduration;
Wire.send(SeasonsVar,8);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,00)
#define End_Cloud_Before NumMins(17,00)
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B001110
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B000001
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen
// results could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
//fit in that 510 minutes window.
static byte cloudchance=255;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
ChannelValue[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ChannelValue[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) ChannelValue=100;
else ChannelValue=0;
//delay(10);
ChannelValue=20;
cloudindex++;
if (cloudindex < numclouds)
//End Cloud Function
//Reverse PWM slope from cloud function
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Reverse PWM function
//Calculate Sunrise/set by date & predefined season & rise/set times
void Seasons()
#define forceseasoncalculation
static byte ssn , ssnp , ssnpt ;
long stime, wstime, vstime, wrtime, rtime, vrtime;
int wrhour,wrmin,wrsec,wshour,wsmin,wssec,rsec,ssec,vrhour,vrmin,vrsec,vshour,vsmin,vssec;
int iDiffrise = 0;
int iDiffset = 0;
int risediffperday = 0;
int setdiffperday = 0;
int totalrise = 0;
int totalset = 0;
byte s=0;
int DaysPerYear;
//rise and set times set by hour and minute. there are 4 seasons however there are 8 highs & lows in rise and set throughout the year
//first spot is second half of winter starting jan 1st
int risehour[8]= {
7,7,7,6,6,5,6,6 };
int riseminute[8]={
00,30,00,30,00,30,00,30 };
int sethour[8] = {
17,18,18,19,19,19,19,18 };
int setminute[8] = {
30,00,30,00,00,30,00,00 };
if (hour()==0 && minute()==0 && second()==0) ssnp=0;
#ifdef forceseasoncalculation
if (ssnp==0)
#else
if (hour()==0 && minute()==0 && second()==1 && ssnp==0)
#endif
//leapyear or not - Define days per year
if (year()%4 == 0 && !(year()%100 == 0 && year()%400 != 0)) {
DaysPerYear=366;
//every other year
else {
DaysPerYear = 365;
//Call Day Number Calc
DayNumber(year(),month(),day());
//define days between begin and middle season
int seasons[9] ={
0,45,96,135,187,238,283,328,DaysPerYear };
//define season and array pulling variable
for (s=0; seasons[s] < Ndays; s++) ssn = s+1, ssnpt = s+1, ssnp = s;
//set loop on array time pulling variable to go back to beginning instead of increasing array size
if (ssn >= 7) ssn = 0;
//differece in seconds between season array times
long rise1 = calcSec(risehour[ssn],riseminute[ssn]);
long rise2 = calcSec(risehour[ssnp],riseminute[ssnp]);
iDiffrise = calcTime(rise1, rise2);
long set1 = calcSec(sethour[ssn],setminute[ssn]);
long set2 = calcSec(sethour[ssnp],setminute[ssnp]);
iDiffset = calcTime(set1,set2);
//calculate new sunrise/set difference from array value
//here we take the difference in day and get a difference in seconds per day. So if the time difference is 30 minutes from the last e
//uation we divide that by the start day of season subtracted by the end day of season to get the number of days in the season
//example: 30 minutes/(day 45 – day 0) = 30/45 = 0.66666
//0.66666 is the difference of minutes each day throughout the season for sunrise
risediffperday = iDiffrise/(seasons[ssnpt]-seasons[ssnp]);
totalrise = risediffperday*(Ndays - seasons[ssnp]);
setdiffperday = iDiffset/(seasons[ssnpt]-seasons[ssnp]);
totalset = setdiffperday*(Ndays - seasons[ssnp]);
//creating time in seconds
rtime=calcSec(risehour[ssnp],riseminute[ssnp]);
if (ssnp == 0 || ssnp == 2 || ssnp == 4 || ssnp == 6){
rtime -= totalrise;
else {
rtime += totalrise;
stime=calcSec(sethour[ssnp],setminute[ssnp]);
if (ssnp == 1 || ssnp == 3 || ssnp == 5 || ssnp == 7){
stime -= totalset;
else {
stime += totalset;
wrtime = rtime + 1200;
wstime = stime - 1200;
vrtime = rtime - 1200;
vstime = stime + 1200;
//turning seconds back to h m s
//here are three different times offset by half hour to have different colors rise and set at different times
//standard times
rhour=rtime/3600;
rtime=rtime%3600;
rmin=rtime/60;
rtime=rtime%60;
rsec=rtime;
if(rsec > 30) rmin++;
shour=stime/3600;
stime=stime%3600;
smin=stime/60;
stime=stime%60;
ssec=stime;
if(ssec > 30) smin++;
//to change the offset change the number 1200 in seconds added or subtracted to rtime
//half hour shorter
wrhour = wrtime/3600;
wrtime=wrtime%3600;
wrmin=wrtime/60;
wrtime=wrtime%60;
wrsec=wrtime;
if(wrsec>30) wrmin++;
wshour = wstime/3600;
wstime=wstime%3600;
wsmin=wstime/60;
wstime=wstime%60;
wssec=wstime;
if(wssec>30) wsmin++;
//half hour longer
vrhour = vrtime/3600;
vrtime=vrtime%3600;
vrmin=vrtime/60;
vrtime=vrtime%60;
vrsec=vrtime;
if(vrsec>30) vrmin++;
vshour = vstime/3600;
vstime=vstime%3600;
vsmin=vstime/60;
vstime=vstime%60;
vssec=vstime;
if(vssec>30) vsmin++;
//time for each active led channel to pull for sunrise
int Sunrise[2]={
rhour,rmin };
int Sunset[2]={
shour,smin };
int whSunrise[2]={
wrhour,wrmin };
int whSunset [2]={
wshour,wsmin };
int vSunrise[2]={
vrhour,vrmin };
int vSunset [2]={
vshour,vsmin };
ChannelValue[LEDPWM0]=PWMSlope(whSunrise[1],whSunrise[2],whSunset[1],whSunset[2],0,100,180,ChannelValue[LEDPWM0]);
ChannelValue[LEDPWM1]=PWMSlope(vSunrise[1],vSunrise[2],vSunset[1],vSunset[2],0,100,180,ChannelValue[LEDPWM1]);
ChannelValue[LEDPWM2]=PWMSlope(Sunrise[1],Sunrise[2],Sunset[1],Sunset[2],0,100,180,ChannelValue[LEDPWM2]);
ChannelValue[LEDPWM3]=PWMSlope(Sunrise[1],Sunrise[2],whSunset[1],whSunset[2],0,100,180,ChannelValue[LEDPWM3]);
//return Sunrise, Sunset, whSunrise,whSunset,vSunrise,vSunset;
//End Seasons Calculation
//Calculators for Seasons function
long calcSec(long hr, long minu)
long totalseconds;
totalseconds=(hr*3600)+(minu*60);
return totalseconds;
long calcTime(long seconds1, long seconds2)
long timediff=abs(seconds1-seconds2);
return timediff;
void DayNumber(unsigned int y, unsigned int m, unsigned int d)
int days[]={
0,31,59,90,120,151,181,212,243,273,304,334 }; // Number of days at the beginning of the month in a not leap year.
//Start to calculate the number of day
if (m==1 || m==2){
Ndays = days[(m-1)]+d; //for any type of year, it calculate the number of days for January or february
} // Now, try to calculate for the other months
else if ((y % 4 == 0 && y % 100 != 0) || y % 400 == 0){ //those are the conditions to have a leap year
Ndays = days[(m-1)]+d+1; // if leap year, calculate in the same way but increasing one day
else { //if not a leap year, calculate in the normal way, such as January or February
//End calculators
my 5 & 6 channels are assigned to fans so what modification i need to do in the code?
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
//Globals integers
int cloudstart=0;
byte PWMports[] ={
3,5,6,9,10,11};
0,0,0,0,0,0};
byte SeasonsVar[]={
0,0,0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
Wire.begin(8);
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
now();
wdt_reset();
if (cmdnum!=255)
cmdnum=255;
datanum=255;
Seasons();
CheckCloud();
wdt_reset();
if (howMany==5)
cmdnum=cmd4;
datanum=cmd5;
Wire.receive();
wdt_reset();
SeasonsVar[2]=rmin;
SeasonsVar[4]=smin;
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
//delay(10);
ChannelValue=20;
cloudindex++;
cstart*=60;
cend*=60;
void Seasons()
int iDiffrise = 0;
int iDiffset = 0;
int totalrise = 0;
int totalset = 0;
byte s=0;
int DaysPerYear;
int risehour[8]= {
7,7,7,6,6,5,6,6 };
int riseminute[8]={
int sethour[8] = {
if (ssnp==0)
#else
#endif
DaysPerYear=366;
//every other year
else {
DaysPerYear = 365;
int seasons[9] ={
rtime -= totalrise;
else {
rtime += totalrise;
stime -= totalset;
else {
stime += totalset;
//standard times
rhour=rtime/3600;
rtime=rtime%3600;
rmin=rtime/60;
rtime=rtime%60;
rsec=rtime;
shour=stime/3600;
stime=stime%3600;
smin=stime/60;
stime=stime%60;
ssec=stime;
//half hour shorter
wrtime=wrtime%3600;
wrmin=wrtime/60;
wrtime=wrtime%60;
wrsec=wrtime;
wstime=wstime%3600;
wsmin=wstime/60;
wstime=wstime%60;
wssec=wstime;
//half hour longer
vrtime=vrtime%3600;
vrmin=vrtime/60;
vrtime=vrtime%60;
vrsec=vrtime;
vstime=vstime%3600;
vsmin=vstime/60;
vstime=vstime%60;
vssec=vstime;
int Sunrise[2]={
rhour,rmin };
int Sunset[2]={
shour,smin };
int whSunrise[2]={
wrhour,wrmin };
int whSunset [2]={
wshour,wsmin };
int vSunrise[2]={
vrhour,vrmin };
int vSunset [2]={
vshour,vsmin };
long totalseconds;
return timediff;
int days[]={
if (m==1 || m==2){
//End calculators
I think the code you have above is already all set for channels 0-3.
You can leave the code for your fan (channels 4 and 5) in the main code. Just remove the stuff in your main code that references the channels 0-3.
I think it should work this way like you wanted.
Hi Roberto,
the code is giving following error "wire.receive() has been renamed Wire.read().
That code was probably developed prior to the release of Arduino 1.0
Just change wire.receive() to wire.read() and it should work.
I just tried the code you posted.
It was definitely coded for earlier version of Arduino.
You will also need to replace the header section to this:
#include "Globals.h"
Bingo. got the code done. now should i remove pwm expansion code from my head unit code
yes. Just leave the channels 4 and 5, which are for fan speed control.
If you ever want to go back to original PWM code.
- PWMExpansionCommands.ino
- (3.04 KiB) Downloaded 448 times
my original code is working fine. i want to program my pwm module for sunrise & sunset effect with random cloud & lightning.
Great.
Now that we have established that everything works, we can move on to next step.
Remove the lines in your code that reference the PWM channels 0-3 and load the pwm code into your PWM module.
You posted one earlier:
http://forum.reefangel.com/viewtopic.php?p=9591#p9591
You may want to ask or send a pm to the author of that code.
Or, we can go with standard Parabola and forget about the seasonal sunrise/sunset calculation.
Alright.I want to change that code to work with 2 drivers instead of 4. what changes should i make?
The Author seems to be away from the forum as i tried to contact him by pm without any response.
Well, let's try another code then.
Let's start simple again. This code is simply doing the Parabola.
Test it out and let me know if it works.
byte PWMports[] ={
3,5,6,9,10,11};
0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
Wire.begin(8);
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
now();
wdt_reset();
if (cmdnum!=255)
cmdnum=255;
datanum=255;
ChannelValue[0]=PWMParabola(9,0,20,0,0,100,0);
ChannelValue[1]=PWMParabola(9,0,20,0,0,100,0);
ChannelValue[2]=PWMParabola(9,0,20,0,0,100,0);
ChannelValue[3]=PWMParabola(9,0,20,0,0,100,0);
wdt_reset();
if (howMany==5)
cmd1=Wire.read();
cmd2=Wire.read();
cmd3=Wire.read();
cmd4=Wire.read();
cmd5=Wire.read();
cmdnum=cmd4;
datanum=cmd5;
Wire.read();
wdt_reset();
The Code is not working. I uploaded it on my pwm module & changed my basic code by removing pwm parabola function from it.
How are you making sure it is not working?
Did you measure voltages?
Right now, the PWM module is not communicating with the controller and data won't show up on the Portal.
