iPhone app problem
Poiromaniax
iPhone app problem
Hi,
I think I've found a bug in the app.
When I try change memory values, changes don't reflect on the controller.
For instance, I was trying to change vortech mode (location 855) any change I made did not reflect
wolfador
Re: iPhone app problem
I will look into this.
Great!!!
I can't wait to see this fixed
I was trying a custom memory yesterday and it didn't work
It would be nice to be able to read as well as write.
Also, is there a way to get vortech stuff in there too
wolfador
If someone wants to send me an mp10 and the modulerimai wrote: Also, is there a way to get vortech stuff in there too
I will add it in as a dedicated spot instead of having to use the custom variable.
Cool!!
I think the labels could use the units too, so everyone knows what that number represents. Something simple like (s) to indicate seconds for example
- mikedizon
Re: iPhone apps
Hi,
I was wondering if the "custom" box works in the memory?
I would like to use the mem loc and value for controlling ph with dosing.
I just downloaded the new reef angel update.
- Contact:
Re: iPhone apps
It should work. You just need to input the memory location you wish to use in there and then update the value.mikedizon wrote:Hi,
- mikedizon
Hi,
After downloading and updating the Reef Angel Libraries Version: 0.9.6 and the new update wizard 1.04.
None of the setting in the memory works. You can view the overheat temp value that but cant change any settings. I just read that when it's hard coded it won't work. Maybe this is the reason. The wizard creates hard coding. Can anyone verify if this is correct. Any work around this. Thanks
SuperDodge
Yeah, iphone app is broken for that part
John hasn't updated that yet for quite some time.
Anyone else to take over??
