Not looking for anything fancy right now...just want a sunrise/sunset effect...
// Autogenerated file by RAGen (v1.2.2.171), (05/22/2012 14:47)
// RA_052212_1447.ino
//The following features are enabled for this File:
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define SIMPLE_MENU
#define PWMEXPANSION
#define RFEXPANSION
#define IOEXPANSION
// LEDPWM Channel defines for easy code reading
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
//Start of PWM Expansion Code for Slope
PWMChannel[LEDPWM0]=PWMSlope(11,00,17,00,20,80,60,PWMChannel[LEDPWM0]);
PWMChannel[LEDPWM1]=PWMSlope(10,00,18,00,20,80,60,PWMChannel[LEDPWM1]);
PWMChannel[LEDPWM2]=PWMSlope(9,30,18,30,20,80,30,PWMChannel[LEDPWM2]);
PWMChannel[LEDPWM3]=PWMSlope(10,30,17,30,20,80,30,PWMChannel[LEDPWM3]);
// The lines above are what calculates the slope.
// You can change the schedule by changing the parameter inside the parenthesis of the PWMSlope() function
// The are as follow:
// 1st parameter: hour to start slope
// 2nd parameter: minute to start slope
// 3rd parameter: hour to end slope
// 4th parameter: minute to end slope
// 5th parameter: % of the PWM signal to start slope
// 6th parameter: % of the PWM signal to end slope
// 7th parameter: duration of slope in minutes
// 8th parameter: always the same as the variable before the PWMSlope() call
