Re: RAGen v1.2.2 - MUST READ for all RAGen Users
Posted: Thu Apr 05, 2012 6:59 am
by dmolton
rimai wrote:I liked the old format too, but the problem was that there is an increasing number of memory locations and it would become too big for one window.
Maybe a tab system just like the RAGen tabs? One for standard settings like lights, heater and ato and then one for the additional settings, and then one for each expansion module?
Just a thought.
Yes, definitely. I noticed quite a few extra memory locations I didn't recognize initially on the drop down. I didn't mean to be overly critical or too harsh in anyway. Having 1 form with 100 options scattered all over the place is also not a very good solution. I think either a tabbed control or maybe an accordion style control similar to what you have on the portal dashboard would be a good way to show/hide what a user cares about at any given time. I'm still glad that RAGen is actively being worked on and evolving because I think it's the best application available for the RA bar none.
Posted: Fri Apr 06, 2012 3:20 pm
Yeah Dave & I have had a lengthy discussion about the Internal Memory page. I do have some more ideas about improving it.
The comments were not too harsh, but they were rather hysterical.
The nice thing was that constructive criticism was given and suggestions for improvements. Commenting truthfully on things can be a bit touchy at times but it's definitely needed and appreciated.
One thing that I thought of as well, is to put a "Preview" button on the form. This would generate a "document" (just a bunch of text inside another window) that displays all of the memory settings. This way you could "preview" it before you generate the memory file. It would be a general overview that you could glance at all the settings and figure out what needs to be changed (if anything). This could be a temporary "fix" until I can devote time to improving it. Any thoughts on this??
Posted: Sat Apr 07, 2012 3:31 pm
by rossbryant1956
how do I get the new app? Is it on the download site? TIA
Posted: Sat Apr 07, 2012 4:24 pm
by Sebyte
Posted: Sun Apr 08, 2012 9:58 am
by rossbryant1956
should I uninstall the earlier version or just install over? Thx
Okay, so I looked..there is nothing to uninstall...there is also no setup.exe.
Do I just copy these files into the right directories?
Posted: Sun Apr 08, 2012 10:23 am
by Sebyte
It is always best practice to remove previous versions of any application before you install new. Most applications will leave behind files which hold user set up references, and they will then apply them to the new version. I believe that RAgen will do this too.
Posted: Sun Apr 08, 2012 10:40 am
rossbryant1956 wrote:should I uninstall the earlier version or just install over? Thx
You just need to download the RAGen-v122-static.zip file (
http://curtbinder.info/apps/RAGen-v122-static.zip). Unzip the file and you will have RAGen.exe. Overwrite the RAGen.exe file that is located in the c:\Program Files\Reef Angel Controller (or Program Files (x86)).
Just copy / paste to overwrite. Make sure that you have RAGen closed when you copy & paste, otherwise it will give you an error.
That's all that it takes to update it.
Posted: Sun Apr 29, 2012 7:11 am
by abhi_123
Hi Curt.
suppose if i want to use pwm parabola function instead of slope than also we have to enter the values in internal memory.
Posted: Sun Apr 29, 2012 7:15 am
abhi_123 wrote:Hi Curt.
The pwm slope and parabola both use the same internal memory locations. So you would need to have the internal memory locations set if you wanted to use the short forms of them. You can always use the long forms and manually add in your values, but doing this will not allow you to update them without reloading your code.
Posted: Sun Apr 29, 2012 7:34 am
by abhi_123
This is my test internal memory code which i have generated.
// Autogenerated file by RAGen (v1.2.2.171), (04/29/2012 19:59)
// Memory_042912_1959.ino
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(8);
InternalMemory.MHOffHour_write(16);
InternalMemory.MHOffMinute_write(16);
InternalMemory.StdLightsOnHour_write(8);
InternalMemory.StdLightsOffHour_write(16);
InternalMemory.StdLightsOffMinute_write(15);
InternalMemory.WM1Timer_write(90);
InternalMemory.WM2Timer_write(200);
InternalMemory.LEDPWMDaylight_write(70);
InternalMemory.LEDPWMActinic_write(75);
InternalMemory.ATOTimeout_write(75);
InternalMemory.DP1RepeatInterval_write(0);
InternalMemory.DP2RepeatInterval_write(0);
InternalMemory.PWMSlopeStartD_write(10);
InternalMemory.PWMSlopeEndD_write(95);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(20);
InternalMemory.PWMSlopeEndA_write(100);
InternalMemory.RFMode_write(0);
InternalMemory.RFSpeed_write(100);
InternalMemory.PWMSlopeStart0_write(15);
InternalMemory.PWMSlopeEnd0_write(100);
InternalMemory.PWMSlopeDuration0_write(60);
InternalMemory.PWMSlopeStart1_write(15);
InternalMemory.PWMSlopeEnd1_write(100);
InternalMemory.PWMSlopeDuration1_write(60);
InternalMemory.PWMSlopeStart2_write(15);
InternalMemory.PWMSlopeEnd2_write(100);
InternalMemory.PWMSlopeDuration2_write(60);
InternalMemory.PWMSlopeStart3_write(15);
InternalMemory.PWMSlopeEnd3_write(100);
InternalMemory.PWMSlopeDuration3_write(60);
InternalMemory.PWMSlopeStart4_write(15);
InternalMemory.PWMSlopeEnd4_write(100);
InternalMemory.PWMSlopeDuration4_write(60);
InternalMemory.PWMSlopeStart5_write(15);
InternalMemory.PWMSlopeEnd5_write(100);
InternalMemory.PWMSlopeDuration5_write(60);
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
and this is my first code
// Autogenerated file by RAGen (v1.2.2.171), (04/29/2012 20:02)
// RA_042912_2002.ino
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
#define ENABLE_ATO_LOGGING
#define SALINITYEXPANSION
#define ORPEXPANSION
#define FONT_8x8
ReefAngel.LCD.DrawDate(6, 112);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.StandardATO(Port1);
ReefAngel.StandardFan(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
// PWMSlope based on Internal Memory values for Standard Lights
// This sends all the data to the portal
// Do not add any custom code that changes any relay status after this line
// The only code after this line should be the ShowInterface function
ReefAngel.Portal("abhi_123");
here in my code there is no value assigned for pwm slope. should i manually enter the value or it will work default on values entered in internal memory?
Posted: Sun Apr 29, 2012 7:40 am
The 2 slope functions that are added (ActinicPWMSlope and DaylightPWMSlope) use these memory values:
and they also use the same light schedule (on & off times) as the StandardLights schedule.
So no changes are necessary to the functions.
Posted: Sun Apr 29, 2012 7:54 am
by abhi_123
Thanks Curt. Btw if i plan to use parabola what changes if i have to make in my current code?
Posted: Sun Apr 29, 2012 7:57 am
abhi_123 wrote:Thanks Curt. Btw if i plan to use parabola what changes if i have to make in my current code?
The changes are simple. You would change this:
to this:
Then reload your code on your controller. That's all that would be needed.
Posted: Sun Apr 29, 2012 8:03 am
by abhi_123
cool. Thats very simple.
one more thing(sorry for troubling you with my newbie question) i will be using pwm fans to control the temp of my heatsink & tank i want to put a conditional code like if the temp of t1 increased the desired value start the fan which is installed on channel 4 in pwm expansion module & gradually decrease its speed depending upon the temp.
Posted: Sun Apr 29, 2012 8:19 am
http://forum.reefangel.com/viewtopic.ph ... 170&p=8969
Roberto will have to comment on how he does the gradual increasing.
Posted: Sat Oct 06, 2012 6:23 pm
by TanksNStuff
binder wrote:abhi_123 wrote:Thanks Curt. Btw if i plan to use parabola what changes if i have to make in my current code?
to this:
Sorry to bring up old topics, but I had a question about the code above and the 1.2.2 libraries.
How would I do this for the PWM Expansion Module channels?
My currently working code (using slope) is as follows:
ReefAngel.PWM.Channel0PWMSlope(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel1PWMSlope(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel2PWMSlope();
ReefAngel.PWM.Channel3PWMSlope();
I'd like to change it from Slope to Parabola. What's the proper syntax please?
Posted: Sat Oct 06, 2012 8:03 pm
ReefAngel.PWM.Channel0PWMParabola(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel1PWMParabola(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
Posted: Sat Oct 06, 2012 8:27 pm
by TanksNStuff
Thanks Roberto. That's what I thought it was, but just wanted to be sure.
