Re: Programming via ISP
Posted: Fri Aug 24, 2012 1:42 pm
I'm still not following.
What do you do to upload again??
Are you disconnecting it?
How can you program controllertest.hex if it was failing before?
You've gotta be doing something that I didn't quite grasp yet
Posted: Fri Aug 24, 2012 2:22 pm
by Bryan
Copy the InitialInternalMemory.hex and controllertext.hex created from RA/Arduino files to a directory
Using Atme Stuido 4 or 6 and the dragon programmer
Erase device
Flash InitialInternalMemory.hex. Fflashes and verifies fine. LCD screen shows Internal memory loaded...
Flash the controller test.hex and it flashes but fails verification,screen is black
#$&*swear
Erase device
Flash controllertest.hex. and it flashes fine and lcd screen shows "Internal memory required.
Flash InitialInternalMemory.hex Flashes but fails verification. LCD screen is black
$#*swear again <g>
Posted: Fri Aug 24, 2012 2:28 pm
Oh ok... You erase the chip, now I got it
I'm not used to AVR Studio.
Everytime I burn with avrdude, the chip gets erased by default automatically, but then again, I only burn bootloaders
Posted: Fri Aug 24, 2012 4:44 pm
by Bryan
Will try a blank 328P, perhaps the one on the board has been damaged somehow.
Posted: Tue Aug 28, 2012 1:26 pm
by Bryan
It's a stumper, tried a breadboard with a blank 328P and programming by ISP from Atmel Studio, exact same issue. I did manage to find a sketch from about a year ago and it flashed fine on the RA board using ISP. Seems to be something with the newer Arduino 1.0.1. Will have to pick up a USB to TTL cord and program from the RA Arduino.
Posted: Tue Aug 28, 2012 5:53 pm
by Bryan
Managed to find a bit of a work around, copy the setup code of the internalmemory sketch into another sketch. It will flash and verify and work,
Posted: Tue Aug 28, 2012 9:44 pm
by fatman
Now that is weird.
