Re: Has anyone tried the Mean Well LDD series drivers on the
Posted: Thu Nov 08, 2012 10:00 pm
Yeah, that should do it :)
Posted: Sun Dec 02, 2012 7:37 pm
by dcartier
rimai wrote:You need to open the relay box and remove the booster.
If it is just one channel you need, you can use one of the ATO ports as output, but only one can output PWM signals.
Is the booster on the PWM expansion a daughter card? I am wondering if it can be ordered as a 10V and changed to 5V support by unplugging something or if desoldering is required.
Dennis
Posted: Mon Dec 03, 2012 4:26 am
Yes, you can desolder and create jumpers to have a 5V output.
Let me know if you are interested.
Posted: Tue Apr 30, 2013 12:04 pm
by HodagReef
Rimai - a reply to an old post, but trying to figure out the cabling for PWM signal. Would it be ok to run 25 ft of RJ-45 or CAT5? My plan is to control LDD drives from your PWM expansion.
Posted: Tue Apr 30, 2013 12:08 pm
Yeah, the PWM signal should be fine at that distance.
