Page 1 of 2
Re: ReefAngel Status
Posted: Tue Apr 24, 2012 3:39 pm
by binder
abhi_123 wrote:for some reasons i am not able to extract exe file file from the zip folder. i am using window7 with java installed on my system already.
any idea how to extract & download the software?
There is not an EXE file in the JAR file. The JAR file is a java executable file. What you need to do is simply download the JAR file then you double click on it to run it. If you have java enabled on your computer it should automatically launch and run the app. You may have to "unblock" it like Sebyte said, but otherwise it should simply run without any other extraction or unzipping.
Posted: Fri Jun 15, 2012 11:45 am
by agentgreen
How do I specify what COM port to use in this app?
Posted: Sat Jun 16, 2012 9:16 am
by binder
agentgreen wrote:How do I specify what COM port to use in this app?
Unfortunately COM ports are not working in this app. It's purely wifi only right now. I have had intentions of adding COM support but have not been successful in getting it to work across all platforms easily. I think I will have to revisit this issue.
Posted: Wed Jun 20, 2012 11:02 am
by agentgreen
Ah gotcha. My wifi module is out of commission right now which is why I asked.
Sent from my Transformer TF101 using Tapatalk 2
Posted: Fri Aug 24, 2012 4:55 pm
by Bryan
Hi Curt:
Any chance the COM port option will be supported.
Posted: Fri Aug 24, 2012 8:32 pm
by DrewPalmer04
At least with windows
Posted: Fri Aug 24, 2012 8:38 pm
Well, the whole idea of Java is to be cross platform.
If you want just windows, you can use the Client
The problem is that there is no java implementation for serial communication.
You have to use a work around that is OS specific, which makes is not trully cross-platform.
So, if there is ever an update for serial, there would have to be 3 packages (Windows, MacOSX, Linux).
That's what I had to do with the wifi utility.
Posted: Sat Aug 25, 2012 1:55 am
by Bryan
Problem with Client is it requires admin rights to install. Want to monitor the tank in my office. PC's are locked solid. Reef Angel Status will run without admin rights.
Posted: Sat Aug 25, 2012 6:18 am
by binder
Bryan wrote:Hi Curt:
Yes, I would like to get COM port option working at least for windows. Like Roberto said, there's no Java implementation for serial communication. I honestly have been focusing my time on the Android Status app and have not gotten back to the java app. I think I need to revisit it soon....after I get this release of the Android app out.
Posted: Sat Aug 25, 2012 7:27 pm
by Bryan
Thanks Curt that would be great, well at least for the windows users.
Posted: Sun Feb 10, 2013 5:35 pm
by binder
Just released another version. Officially released v1.0.0 (too long in the works). Check out the original post for the updated information about what's new.
Posted: Sun Feb 10, 2013 5:55 pm
by 00Warpig00
Nice. Working well here... thanks Curt
Nick
Posted: Sun Feb 10, 2013 5:57 pm
by binder
00Warpig00 wrote:Nice. Working well here... thanks Curt
Nick
Good. I figured it was time I actually updated some of my apps to have all the features in them.
This one will be slower than the Android one though but shouldn't be a problem.
Posted: Sun Feb 10, 2013 8:04 pm
by daniella3d
wow, thanks so much!! that's exactly what I wanted and it work like a charm!
Plus it does not take much memory, so that's great.
Posted: Sun Feb 10, 2013 8:26 pm
by binder
daniella3d wrote:wow, thanks so much!! that's exactly what I wanted and it work like a charm!
Glad you like it.
Posted: Mon Feb 18, 2013 10:46 am
by tkeracer619
Awesome Job! Best one yet!
I think it exposed something in my Wifi module that I don't like.
It pops up every couple hours with a notification with Error 11 Bad URL. On the last version it would just kick back saying it couldn't connect and after a try or two it would work.
Last night I updated the firmware on my wifly and it seems to have made it much much better but I still get that error from time to time. Is there a way to turn that notification off or is something else going on that I need to address?
Posted: Mon Feb 18, 2013 2:12 pm
by DrewPalmer04
working great! is there an auto refresh set time? or do I have to do it manually?
Posted: Mon Feb 18, 2013 3:58 pm
by binder
DrewPalmer04 wrote:working great! is there an auto refresh set time? or do I have to do it manually?
right now it is manually updated...so you have to refresh yourself. i can look into doing the auto refresh feature but it would only be while the app was open. otherwise i would have to create a service and then log to a database and such (just like i do with the android app).
no, there is no way to turn off the notifications from being displayed. however i can work on adding that in if you would like. something like disable alerts or popup notifications. just let me know what you think and would like.
Posted: Mon Feb 18, 2013 4:14 pm
by DrewPalmer04
Cool ever thought about an icon so us Mac people could put it on our dock?
Posted: Mon Feb 18, 2013 4:34 pm
by binder
DrewPalmer04 wrote:Cool ever thought about an icon so us Mac people could put it on our dock?
yes. i started to look into it but never completed it. guess i need to revisit this as well.
Posted: Wed Feb 20, 2013 9:04 am
by binder
This sounds like an error message on the Android Status App and not the Java Desktop Status App (sorry for any confusion).
For the Android App, if you are getting those errors and a retry will correct it, I would suggest going to the Settings and then down to Notifications. There is the Error Retries section. I would suggest changing that from 2 to 5 (or something above 2) OR change the Error Retry Interval from 15 seconds to 30 seconds. This way you can hopefully avoid those unfortunate mishaps.
Posted: Wed Feb 20, 2013 5:49 pm
by binder
I've got that fixed and updated. I'm actually going to package it up like the MenuGenerator app so you can actually install it. I'm almost ready to do another update/release for it. I have a couple more things I would like to add (ok, well one more). I'd like to have the auto refresh ability in the app. Although I may just push out this update and then work on the auto refresh and update it again...not sure. Oh and I'm thinking of adding in a notification for software updates to the app as well, so you can check for updates from the app without having to search.
Posted: Wed Feb 20, 2013 8:19 pm
by DrewPalmer04
Awesome! The release is up to you. No rush on my side
Posted: Tue Apr 02, 2013 4:34 pm
by binder
DrewPalmer04 wrote:Awesome! The release is up to you. No rush on my side
Just released the update. Did not create a mac package for it (I forgot how I did it) but I can if needed. Let me know how it works for you.
Posted: Tue Apr 02, 2013 5:44 pm
by DrewPalmer04
Ok cool. I'll mess with it tomorrow AM
Posted: Sun Apr 28, 2013 3:12 pm
by ahmedess
is it possible in the coming update to add an option to the application to be able to save custom memory location to the list of memory locations already available. It would be great to be able to save the memory location number, its type int or byte and its name.
Posted: Sun Apr 28, 2013 4:44 pm
by binder
ahmedess wrote:is it possible in the coming update to add an option to the application to be able to save custom memory location to the list of memory locations already available. It would be great to be able to save the memory location number, its type int or byte and its name.
I hadn't thought about that for this application. I suppose it could be possible. I will have to look into it.
Posted: Mon Apr 29, 2013 12:22 pm
by ahmedess
Is there any other application that has this option we could use?
Posted: Mon Apr 29, 2013 6:26 pm
by binder
ahmedess wrote:I hadn't thought about that for this application
I just meant that I was working on this functionality for the Android Status App and never considered doing this for the Java Status App. I don't know of any other app that you could save the custom memory locations for quick reference. Let me start working on this functionality for you and see what I can come up with.
Posted: Wed May 08, 2013 4:08 pm
by jsclownfish
Does anyone know how to load the Java Status App on the iPad?
Jon
