Page 1 of 2
Re: Moon rise/set implementation
Posted: Sat Mar 23, 2013 8:01 am
17:13 to 5:29 for today's schedule...
looks good so far :)
Posted: Sun Mar 31, 2013 1:26 am
by thekameleon
Not sure if you had updated the code attached. The isRise was true outside the rise to set time range. I tried to figure out what is going on, but I got lost quickly with the code as I could not figure out the meaning of the variables. So I went ahead and use a PMWParabola function with the rise and set times, which is working so far... Do you have an updated code file?
Posted: Mon Apr 01, 2013 7:01 am
The isRise variable I believe is only used during the test_moon() function. This is why I stopped using it also and did the same thing as you. The issue though, I don't know if the parabola works properly when spanning over midnight. I used a previously published PWMSlopeOvernight which I have modified to work either overnight or not overnight. It should end up in the libraries next update I believe. Is the parabola working properly for you?
Posted: Mon Apr 01, 2013 7:05 am
Btw, the last code I posted has been updated to the latest and is complete. I haven't done any work on it and it looks like it's working properly. The time is 3 hours off from the coordinates that I am testing with but it could be because we do not really do any time zone on the RA. and the place I have is -3 from GMT... anyway, please test and if you have improvements, I'm all for it. I don't know enough of what's going on and spent like 3 days reading the code to really start tinkering and changing it around. I now have a variable rise/set that matches a moon cylce so I'm happy :)
Posted: Mon Apr 01, 2013 11:26 am
by thekameleon
I'd just like to understand the variable names and what it all means. I haven't seen the PWMSlopeOvernight function, but I wrote this to drive my moon lights.
      byte moonPhase = MoonPhase();
      byte moonPWM = 0;
      if(moonPhase > 0)
        moonPWM = PWMParabola(Moon.riseH, Moon.riseM, Moon.setH, Moon.setM, 10, ((moonPhase / 10) + 11), 0);
My question is around MoonPhase and if I am using it right. It appears the value is an index or in this case 0 - 100, so when it returns 1, I should have the lowest value (dimmest light). Knowing that my MeanWell drivers don't turn on until a value of 11 is sent to them. I adjusted the index according (hence the adding of 11).
Posted: Mon Apr 01, 2013 11:30 am
Yeah. I just don't know that the PWMParabola function will work properly when PM -> AM versus AM->PM. There was an issue with this in the PWMSlope and so a PWMSlopeOVernight was written. Moving forward there will be one PWMSlope function, but again, not sure on the parabola.
You have the moonphase and params correct it looks like.
Posted: Mon Apr 01, 2013 12:50 pm
by thekameleon
I think this should do it:
byte PWMParabolaOvernight(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte oldValue)
        unsigned long Start = previousMidnight(now())+((unsigned long)NumMins(startHour, startMinute)*60);
        unsigned long End = nextMidnight(now())+((unsigned long)NumMins(endHour, endMinute)*60);
        boolean isOvernight=NumMins(startHour,startMinute)>NumMins(endHour,endMinute);
        int Now = NumMins(hour(), minute());
        if (hour()<startHour && isOvernight) Start-=86400;
        if (hour()<startHour || !isOvernight) End-=86400;
        byte PWMDelta = endPWM-startPWM;
        byte ParabolaPhase=constrain(map(Now,Start,End,0,180),0,180);
        if ( Now <= Start || Now >= End)
               return oldValue;
               return startPWM+(PWMDelta*sin(radians(ParabolaPhase)));
I'll let you know in a few days.
Posted: Mon Apr 01, 2013 12:58 pm
Let me find you the thread that I posted the overnight/non-overnight code. You should test with that because moonrise could be within the same day or be an overnight event...
Posted: Mon Apr 01, 2013 1:01 pm
Original PWMSlopeOvernight
http://forum.reefangel.com/viewtopic.php?p=11781#p11781
My Modification to make it universal
http://forum.reefangel.com/viewtopic.php?p=22384#p22384
Lol nevermind... just read your code... looks like you got my changes :)
Roberto.. if this works, both fixes should go in together :)
Posted: Mon Apr 01, 2013 1:24 pm
The slope one is already merged in the dev branch :)
I'll check out the parabola.
Posted: Wed Apr 03, 2013 10:57 am
by thekameleon
So the function did not work. So I tweaked it to this:
        int start = NumMins(startHour, startMinute);
        int end = NumMins(endHour, endMinute);
        if (start < end)
          //Example: 2300hrs to 0200hrs
          if (hour() < endHour) start -= 1440; //past midnight
          if (hour() > startHour) end += 1440; //before midnight
        int current = NumMins(hour(), minute());
        byte pwmDelta = endPWM - startPWM;
        byte parabolaPhase = constrain(map(current, start, end, 0, 180), 0, 180);
        if ( current <= start || current >= end)
          return oldValue;
          return startPWM + (pwmDelta * sin(radians(parabolaPhase)));
This is outputting during a normal non-over midnight. I wish there was a good way to Unit Test Arduino to validate over midnight.
Posted: Wed Apr 03, 2013 11:40 am
You can, but you will need to modify the libraries.
Would you like to do that?
Posted: Wed Apr 03, 2013 11:44 am
by thekameleon
I was thinking of using Visual Studio for Unit Testing and even building sketches. Visual Micro for Visual Studio actually allows for step through debugging via the serial port. I am not sure how tweaking the libraries would help here, I just want to run the code out side of the controller
Posted: Wed Apr 03, 2013 11:47 am
I used VS with RA just fine :)
Posted: Wed Apr 03, 2013 12:29 pm
by thekameleon
Wow... That was easy.
Posted: Mon Apr 15, 2013 12:07 am
by thekameleon
Here is the function PWMParabolaOvernight. I have been testing it for over a week and it seems to be behaving properly.
  if (start > end) //Start is greater than End so its over midnight
    return oldValue;
Posted: Mon Apr 15, 2013 6:29 am
Awesome!
Posted: Mon Apr 15, 2013 8:32 am
Thanks!!!
But it is not working :(
I tested PWMParabolaOvernight(23,0,8,0,10,90,5) and got this:
23	1	5
23	2	5
23	3	5
23	4	5
23	5	5
23	6	5
23	7	5
23	8	5
23	9	5
23	10	5
23	11	5
23	12	5
23	13	5
23	14	5
23	15	5
23	16	5
23	17	5
23	18	5
23	19	5
23	20	5
23	21	5
23	22	5
23	23	5
23	24	5
23	25	5
23	26	5
23	27	5
23	28	5
23	29	5
23	30	5
23	31	5
23	32	5
23	33	5
23	34	5
23	35	5
23	36	5
23	37	5
23	38	5
23	39	5
23	40	5
23	41	5
23	42	5
23	43	5
23	44	5
23	45	5
23	46	5
23	47	5
23	48	5
23	49	5
23	50	5
23	51	5
23	52	5
23	53	5
23	54	5
23	55	5
23	56	5
23	57	5
23	58	5
23	59	5
0	0	37
0	1	37
0	2	37
0	3	38
0	4	38
0	5	38
0	6	39
0	7	39
0	8	39
0	9	41
0	10	41
0	11	41
0	12	42
0	13	42
0	14	42
0	15	43
0	16	43
0	17	43
0	18	45
0	19	45
0	20	45
0	21	46
0	22	46
0	23	46
0	24	47
0	25	47
0	26	47
0	27	48
0	28	48
0	29	48
0	30	50
0	31	50
0	32	50
0	33	51
0	34	51
0	35	51
0	36	52
0	37	52
0	38	52
0	39	53
0	40	53
0	41	53
0	42	54
0	43	54
0	44	54
0	45	55
0	46	55
0	47	55
0	48	57
0	49	57
0	50	57
0	51	58
0	52	58
0	53	58
0	54	59
0	55	59
0	56	59
0	57	60
0	58	60
0	59	60
then I went and tested PWMParabolaOvernight(22,0,8,0,10,90,5) and got this:
22	1	5
22	2	5
22	3	5
22	4	5
22	5	5
22	6	5
22	7	5
22	8	5
22	9	5
22	10	5
22	11	5
22	12	5
22	13	5
22	14	5
22	15	5
22	16	5
22	17	5
22	18	5
22	19	5
22	20	5
22	21	5
22	22	5
22	23	5
22	24	5
22	25	5
22	26	5
22	27	5
22	28	5
22	29	5
22	30	5
22	31	5
22	32	5
22	33	5
22	34	5
22	35	5
22	36	5
22	37	5
22	38	5
22	39	5
22	40	5
22	41	5
22	42	5
22	43	5
22	44	5
22	45	5
22	46	5
22	47	5
22	48	5
22	49	5
22	50	5
22	51	5
22	52	5
22	53	5
22	54	5
22	55	5
22	56	5
22	57	5
22	58	5
22	59	5
23	0	34
23	1	34
23	2	34
23	3	34
23	4	36
23	5	36
23	6	36
23	7	37
23	8	37
23	9	37
23	10	38
23	11	38
23	12	38
23	13	38
23	14	39
23	15	39
23	16	39
23	17	41
23	18	41
23	19	41
23	20	42
23	21	42
23	22	42
23	23	42
23	24	43
23	25	43
23	26	43
23	27	45
23	28	45
23	29	45
23	30	46
23	31	46
23	32	46
23	33	46
23	34	47
23	35	47
23	36	47
23	37	48
23	38	48
23	39	48
23	40	50
23	41	50
23	42	50
23	43	50
23	44	51
23	45	51
23	46	51
23	47	52
23	48	52
23	49	52
23	50	53
23	51	53
23	52	53
23	53	53
23	54	54
23	55	54
23	56	54
23	57	55
23	58	55
23	59	55
0	0	57
0	1	57
0	2	57
0	3	57
0	4	58
0	5	58
0	6	58
0	7	59
0	8	59
0	9	59
0	10	60
0	11	60
0	12	60
0	13	60
0	14	61
0	15	61
0	16	61
0	17	62
0	18	62
0	19	62
0	20	63
0	21	63
0	22	63
0	23	63
0	24	64
0	25	64
0	26	64
0	27	65
0	28	65
0	29	65
0	30	66
0	31	66
0	32	66
0	33	66
0	34	67
0	35	67
0	36	67
0	37	68
0	38	68
0	39	68
0	40	69
0	41	69
0	42	69
0	43	69
0	44	70
0	45	70
0	46	70
0	47	71
0	48	71
0	49	71
0	50	72
0	51	72
0	52	72
0	53	72
0	54	73
0	55	73
0	56	73
0	57	73
0	58	73
0	59	73
Looks like it is missing the starting hour completely.
Here is the test code I used:
int test=0;
  ReefAngel.Init();
  wdt_reset();
  adjustTime(60);
  Serial.print(hour());
  Serial.print("\t");
  Serial.print(minute());
  Serial.print("\t");
  Serial.println(PWMParabolaOvernight(22,0,8,0,10,90,5));
  delay(10);
  if (test++>2500)
  while(1) wdt_reset();
    return oldValue;
The only thing is that you will need to change the libraries to perform this test.... :(
You need to change ReefAngel.cpp
From
	setSyncInterval(SECS_PER_HOUR*6);  // Changed to sync every 6 hours.
To
	setSyncInterval(SECS_PER_HOUR*6000);  // Changed to sync every 6 hours.
Or the clock will keep syncing with the RTC.
Posted: Mon Apr 15, 2013 4:42 pm
by thekameleon
I was just testing if you were actually paying attention.... :D
I think my problem is this line:
Change it to this
if (hour() >= startHour) end += 1440; //before midnight
Posted: Tue Apr 16, 2013 8:33 am
Awesome!!!
I'll include in the next update :)
Posted: Tue Apr 16, 2013 8:35 am
Fantastic.. now both the slope and parabola functions will work am-pm or pm-am :)
Posted: Tue Apr 16, 2013 11:55 am
by thekameleon
Here is the code for the slope. its based off of Parabola
byte PWMSlopeOvernight(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
	int startD = start + Duration;
	int stopD = end - Duration;
	if ( current >= start && current <= startD )
		return constrain(map(current, start, startD, startPWM, endPWM),startPWM, endPWM);
	else if ( current >= stopD && current <= end )
		byte v = constrain(map(current, stopD, end, startPWM, endPWM),startPWM, endPWM);
		return endPWM - v + startPWM;
	else if ( current > startD && current < stopD )
		return endPWM;
    // lastly return the existing value
    return oldValue;
Posted: Tue Apr 16, 2013 12:38 pm
Definitely looks cleaner then mine...
Posted: Tue Apr 16, 2013 2:31 pm
Should I use thekameleon version instead then?
Posted: Tue Apr 16, 2013 3:19 pm
If the logic works then yeah. This matches the parabola logic and looks more like the original code than the original overnight that I started from...
Posted: Tue Apr 16, 2013 3:23 pm
The only con I see is the logic to add/subtract time only focuses on hours...if someone were to use it for a slope with less time or if someone wanted a slope/parabola from 11:55pm - 11:05pm...it might have an issue..maybe not... That would be the only point to check IMO.
Posted: Tue Apr 16, 2013 3:24 pm
I think actually it may be fine after reading it again...
Posted: Fri Jun 07, 2013 9:04 pm
by Aemornion
Hello
I just signed up for this forum today to seek help with the moon.h library.
and as I am apparently too new to send a PM I shall post here. Hopefully this thread is not dead yet.
I am attempting to implement my own arduino tank controller, nothing fancy tank wise just my little 29 planted tank.
I started to learn the arduino in November for this purpose and have come a long way in the short about of time I have been chugging along and learning a lot in the process. =)
So I stumbled across this thread and the moon.h library, and real moon times is something i would really like to implement.
This might sound pathetic... but i am stuck on step 2
I have put
#included moon.h
and the ide recognizes that as a valid library
no complaints their
But when I put
moon_init(21,-73);
into the program, is complains
moon_test.ino: In function 'void loop()':
moon_test:26: error: 'moon_init' was not declared in this scope
I have tried putting it elsewhere in the setup loop, outside theloop, different places within the loop. going as far as to delete everything else, except the necessary libraries wire.h, time.h, DS1307RTC.h.
Do you guys have any ideas as to why this would not be working? I am at a complete loss.
I am appreciative of any assistance offered.
-Jay
Posted: Sat Jun 08, 2013 3:06 am
Aemornion wrote:
I have put
#included moon.h
Welcome and good luck. Try this instead..
#include "moon.h"
Also make sure that line is in the global declarations not within setup() or loop()
Posted: Sat Jun 08, 2013 10:20 am
by Aemornion
Thanks for the reply and assistance lnevo. =)
Alrght, so I made an error in my above statement, When i was
doing
#included moon.h
I was actually doing
#included <moon.h>
Which is what i do with all my other libraries standard with no issue.
Last night I did run through other iterations, such as using "" as you suggest which are outlined below.
Doing
#included moon.h
yields an error of
moon_test.ino:5:10: error: #include expects "FILENAME" or <FILENAME>
(hence why i starting making <> standard a while ago)
and when i try
#include "moon.h"
yields an error of
moon_test.ino:5:18: error: moon.h: No such file or directory
However the moon library is available under the arduino ide, being in the contributed section of the
sketch->importlibrary drop down menu, and when i select it to re import it, it tells me that their is already an moon library.
I should also note that these errors were acquired with the
moon_init(21,-73);
code removed.
Here is my total code with all the fat trimmed off.
/////////moon.h test Program//////////
#include <moon.h>
  //moon_init(21,-73);
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
I left the RTC stuff in their because I am assuming that the moon.h library needs it at some point.
Thank you for any help,
=Jay
