Controlling Jebao/Tunze/Speedwave pumps
Would you like to help?
Sebyte
Re: Controlling Jebao/Tunze pumps
Post by Sebyte »
I would love to get one of these pumps going but don't have any free PWM ports, or do I?
I am using the Water level expansion so I do have the two ATO ports free and I seem to remember that they can provide a 0-5v PWM output.
I guess the question is would this output be sufficient to drive the the pump? If so how would the above code need to be changed to get the ATO ports in to use.
Only one ATO port can do PWM.
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,ReefCrestMode(60,20,true)*2.55);
The cable is designed to work on 0-10VDC signals.
You will need to mod the cable if you want to use 0-5VDC signal.
Take one resistor and bridge the pads instead.
Edited: Pads do not need to be bridged. Only removal of resistor R2 is necessary
Sebyte
Post by Sebyte »
Thanks, I thought that was the case. As I have not seen the cable harnes I am not sure what you mean by bridge the pads?
Any chance of a circuit diagram?
Many thanks
Remove R2.
Sebyte
Post by Sebyte »
Thanks Roberto
I will get a pump sent over and the place an order for cable and a couple of other bits as well.
Thanks again
mluz
Post by mluz »
First I would like to thank you all for the great info and help. I've owned my RA for about three weeks and I found everything I needed to get it running in this forum.
I also bought a WP40 pump and cable. I was able to upload the code (reef crest) and its working great, thank you to Roberto for the tutorial.
My question is, can I use the portal or the reef angel client to change the settings on PWM? How do i go about doing that? Specifically change the maximum and minimum percentage settings on reef crest.
You could leverage the RF memory locations until we have developed memory locations specific for Jebao.
For example:
  ReefAngel.PWM.SetDaylight( ReefCrestMode(InternalMemory.RFSpeed_read(),InternalMemory.RFDuration_read(),true) );
The above function would use the RF Speed as the average speed and RF Duration as the offset.
Now you can change it in the Portal :)
Take a look at this post as well. It has logic to leverage all the "vortech" modes.
http://forum.reefangel.com/viewtopic.php?p=23072#p23072
Ciwyn
Post by Ciwyn »
Can anyone recommend a code for just running one WP40? Should I just set my relay (port5) to always on, then put one of the codes in the custom code section? I currently have the reefcrest code in there. May try the random mode code that Roberto posted though.
Right now I have port 5 set to wavemaker random and the pump stays off for longer than I care for it to.
You can actually plug it to the wall and use Port 5 for something else you may want to control.
Ciwyn
Post by Ciwyn »
Alright so I was thinking correctly. Currently I have ports available, I will stash that away for future reference though. Thanks again
All the functions are already in the libraries.
What do you have in mind?
Yes, you could put codes into a .h file and call the #include in the code.
You could have but it's no longer necessary to do that nor put the functions into your INO file. Just go ahead and use them and the new libraries will take care of it.
jjdezek
Post by jjdezek »
rimai wrote:You could do something like this:
if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(60,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(60,20,false) ); // ReefCrest at 60% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,60,200,true) ); // Short pulse at 60% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,60,200,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,60,10,true) ); // Long pulse at 60% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,60,10,false) ); // Long pulse at 60% with 10s pulse on anti-sync mode
when i loaded this code it shut my right leds off completly my middle whites off and the rest were still on. what would cause that to happen......why is it every code i try for the jebao on here it doesnt work
ReeferBee
Post by ReeferBee »
Do you have the harness for it? What ports do you have the wp40 hooked up to?
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
jjdezek
Post by jjdezek »
i just realized i used an older code set up that doesnt have my current light set up....i rewired my lights into all dimming ports and the code i used to load this one in was from when i had the lights wired into two ports. rookie mistake. not sure whats ups with the other codes i have tried though.
jjdezek
Post by jjdezek »
plugged it in my current code set and works fine.
oscarinw
Post by oscarinw »
rimai wrote:Only one ATO port can do PWM.
analogWrite(lowATOPin,ReefCrestMode(60,20,true));
I am also connecting the WP40 to the ATO PWM...
Considering this is a different wattage PWM, what are the proper values to be used for the different modes??
Re: Controlling Jebao/Tunze/Speedwave pumps
Sorry, that post is incorrect.
I'll update it, but here is how it needs to be:
analogWrite has a range of 0-255 instead of 0-100
daniella3d
Post by daniella3d »
just wondering if I only have one jebao pump connected do I need both of these lines? or just one?
You can just use one
carlii
Post by carlii »
I see that the Tunze control in in the portal now. Way cool!. I assume that I need to use internal memory to use the portal. How do I code that for Tunze pumps on a PWM expansion box?
ReefAngel.DCPump.ExpansionChannel[0]=Sync;
ReefAngel.DCPump.ExpansionChannel[1]=AntiSync;
Change the channel number and the type to however you want to configure it. That's all there is to it. If you want you can define the speed for Water Change and Feeding Modes...
ReefAngel.DCPump.FeedingSpeed=10;
Sebyte
Post by Sebyte »
I have been using the ATOPinLow port and memory settings via the Portal to control my Jeboa for some time.
Today I have tried adding ReefAngel.DCPump.FeedingSpeed=10; to my code, but the pump did not operate during the feed mode. I have tried a number of values up to 50 with the same result.
I am not sure if the ReefAngel.DCPump.FeedingSpeed should work with the ATOPinLow port or not also if it should do I have the command in the right place in my code.
Any suggestions please.
My INO
// Created using Wizard 14/09/2013
// DC pump set to use ATOPinLow
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
    InternalMemory.LCDID_write(0); // new LCD screen
    ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.DCPump.FeedingSpeed=50;
   // ReefAngel.StandardATO( Port2 );
    ReefAngel.DCPump.LowATOChannel = Sync ; // Jebo connected to AtoPINLow
   // Waterlevel code changed 20/04/13 to stop quick cycle of ATO pump
byte l = ReefAngel.WaterLevel.GetLevel();
  if (l>85) ReefAngel.Relay.Off(Port2);
  if (l<82 && l>0) ReefAngel.Relay.On(Port2);
  if (now()%20<10)
 // Delay turning Skimmer back on
    ReefAngel.Relay.DelayedOn( Port1,60 );
  // Activate Watch Dog Timer at 6am and 6pm
  if ((now()%86400)==21600) delay(1000);
  if ((now()%86400)==43200) delay(1000);
// Wavemaker not available 9 pm to 10 am
  if ( (hour() >= 20) || (hour() <= 9) )
    ReefAngel.DCPump.Mode==Custom;
    ReefAngel.Portal( "sebyte" );
    int x,y;
#if defined DisplayLEDPWM && ! defined RemoveAllLights
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
    // Water Level
    TempRelay &= ReefAngel.Relay.RelayMaskOff;
    TempRelay |= ReefAngel.Relay.RelayMaskOn;
ReeferBee
Post by ReeferBee »
Where do I post this in my code? Thanks!
Barry
In the loop() section.
ReeferBee
Post by ReeferBee »
above the "place custom code below here"? Thanks again Roberto
Barry
Place it below that line
ReeferBee
Post by ReeferBee »
Got it working. Thanks!
Barry
ReeferBee
Post by ReeferBee »
Is it odd that both of my float switch ports run my wp40?
Barry
