New design layout
Re: New design layout
Thanks for adding the file.
I will try it and provide feedback. To change the library I just need to replace the folders in \Documents\Ardunio\libraries with the ones in the zip file, correct?
Thank you Roberto.
Thank you Roberto.
I just installed this.
Feedback so far:
- I found that there is some error displaying my T1.
- Whats is the normal mode screen?
Screenshots (sorry for the low quality cell pics)
Feedback so far:
I guess I need a better sentence
That screen only has 1 option to display, which is lights on mode.
If it is not lights on mode, it will display "Normal mode"
Should I name something else?
I guess we could have a new screen dedicated for AP/DP with bars too.
In fact, I think that's what I'll do.
Awesomerimai wrote:I guess we could have a new screen dedicated for AP/DP with bars too.
Maybe something in my code? Other screen show fine so I dont think is the screenrimai wrote:I can't seem to be able to replicate your T1 problem though
Ok, I updated the dev branch with the dimming channels in a separate screen.
I will try it when I get home. Is there a way to chart the AP/DP? I would like to see how the wave patterns are behaving through the day.
http://forum.reefangel.com/status/chart ... ilter=pwmdganjero wrote:Roberto,
The controller only sends data every 5 minutes though
Doesn't change a thing.lnevo wrote:Custom screens...hows that gonna work???
Just like custom screens bypass the original one, it will bypass this one too.
Also, if you don't add ReefAngel.Use2014Screen(); the new screen is not enabled anyway.
Is there a way to tap into the new screen though and add stuff? Maybe like a DrawCustomGraph() ?
Would love to get all the new stuff but keep some functionality...
Or can I do my own DrawCustomMain() and call a Draw function for the screens you've created?
Did we get an answer to this i would love to alter the new screens! I love how they look but somethings are not named properly for my system!lnevo wrote:Is there a way to tap into the new screen though and add stuff? Maybe like a DrawCustomGraph() ?
just updated to the new display this weekend. noticed that the head unit menu overheat setting is overriding what i entered through the wizard. what other settings in the menu overrides wizard settings?
i've since changed the overheat setting from 78 to 85.
sorry, bonehead mistake on my part. put in the set temp as overheat temp in the wizard. fixed now.
no, just the recommended for new users "in the code" setting.
So I'm using the example from CustomMainScreen_PowerControlExpansion and I was wondering if the relay expansion port labels are supposed to display starting at "Port 11" going through "Port 18"?
I understand why it's happening. #define Box1_Port1 11 in Globals.h. I'm just wondering if the new screens need code added to change the label to either "Port 9" through "Port 16" or "Exp Port 1" through "Exp Port 8" or if this is the desired label?
Okay, now I understand.
It's done in ReefAngelClass::InitCustomLabels():
So "String("Port "+ String(a) + String(b))" giving 18 means "Box 1 Port 8".
#ifdef RelayExp
for (int a=1;a<=MAX_RELAY_EXPANSION_MODULES;a++)
for (int b=1;b<=8;b++)
CustomLabels[(a*8)+b-1]=String("Port "+ String(a) + String(b));
#endif // RelayExpRe: New design layout
nice work I like the layout. Im guessing in time all the sub menus could be dolled up to be more graphical.. Its w nice feature set you have going here..
