Stuggling with the LDD Drivers
Re: Stuggling with the LDD Drivers
newtoke wrote: I respect your thoughts on this Steve, but as I understand what PWM is and as referenced in the following post from Roberto...
http://forum.reefangel.com/viewtopic.php?f=2&t=2980
I don't think this is correct. A PWM determines the value between the width of each pulse, it still pulses at 10 volts right?
Correct.
PWM will output a 0-10V PWM signal and will change the width of the pulse.
The new dimming expansion modules can outpout 0-5V PWM signals.
newtoke
Post by newtoke »
Correct.
Thanks Roberto... So there is no way to get the PWM signal out of the relay box to be 5 vdc?
Technically there is, but it will require you to open the box and solder some jumper bridges with wires to short out the gain of the op amp that boosts the signal.
Another way is to use your ATO port. They output 0-5V PWM.
Something like this:
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,2.55*80); // set Low ATO port to 80%
newtoke wrote:
Sacohen wrote:The PWM control signal going from the RA dimming ports to PWM in on the LDD would be 50% of the full 10v (or 5v).
Here is code for a PWM slope going from 0-50% for the daylight and actinic channels.
Times are 9am to 8pm.
    ReefAngel.PWM.SetDaylight( PWMSlope(9,0,20,0,0,50,60,0) );
    ReefAngel.PWM.SetActinic( PWMSlope(9,0,20,0,0,50,60,0) );
Sorry you are correct. I was thinking backwards. My brain is a little foggy right now, I've been up all night the past 2 nights working on a freelance video editing job.
newtoke
Post by newtoke »
rimai wrote:Technically there is, but it will require you to open the box and solder some jumper bridges with wires to short out the gain of the op amp that boosts the signal.
When I set the pin mode, do I just set it in Setup and the analogWrite in the loop? Also I assume the RA libraries won't freak out over the ATO been used as a output instead of input correct?
No, you need to have it on loop too.
People have used this for Jebao pumps, but nobody has never tested with LEDs.
newtoke
Post by newtoke »
Is it true that only one ATO port can send out PWM?
Also what configuration have folks had success with?
On the standard RA, only one, but on the RA+, you can use both.
newtoke
Post by newtoke »
Sigh... it didn't seem to work. I put those two lines you mentioned before the "interface" method. This is what I did:
//ATO PWM output
  pinMode(lowATOPin, OUTPUT);
  pinMode(highATOPin, OUTPUT);
  analogWrite(lowATOPin, ReefAngel.PWM.GetActinicValue() * 2.55);
  analogWrite(highATOPin, ReefAngel.PWM.GetDaylightValue() * 2.55);
  ReefAngel.Portal();
I am ordering new drivers in case I fried them. Any other ideas? I'd really love to find a testing device that can generate a PWM signal and a device that can test a PWM signal, but I have yet to find any.
What size LDD do you need.
I think I have 2 1000mA that I'm not using.
newtoke
Post by newtoke »
I already ordered two 1000ma Steve... Thanks for the offer. I ordered the PWM Expansion Module, because it appears that is the only way people are having success... I would though hope that Roberto will add the ability to modify the voltage out of the relay pack PWM outputs in the future.
No Problem. Good luck with them.
I have 4 that I need to get motivated to set up.
newtoke
Post by newtoke »
newtoke wrote:Sigh... it didn't seem to work. I put those two lines you mentioned before the "interface" method. This is what I did:
//ATO PWM output
  ReefAngel.Portal();
Roberto any thoughts on this code?
Code looks fine.
Sent from my SM-G900P using Tapatalk
newtoke
Post by newtoke »
Doesn't work... Only thing that happens is that the lights go out. Hopefully the dimmer module I just purchased will solve this?
blert
Post by blert »
newtoke wrote:Sigh... it didn't seem to work. ...
The LDD drivers and the controlling device MUST share a common ground. You can't just send them a signal and have them work, they need to be properly hooked up electrically.
newtoke
Post by newtoke »
I know the ground from the RA ATO port was connected to the -Vout on the power supply. I was trying to use Roberto's suggestion of having using the ATO as a PWM 5vdc signal using the code shown in earlier in this thread, but the lights would just stay dark.
Do you get any voltage when you measure the ago ports?
newtoke
Post by newtoke »
I went ahead and purchased the Dimmer module. I opened it up and put in the 5 vdc jumpers. I wired ther LDD white wire to the dimmer and the negative or ground of the DImmer module to the negative VOut on the power supply and the lights don't turn on at all.
If I disconnect the white wire from the dimmer module then I get 100% full on from my lights
Did you change your code to use the dimming expansion module?
Can we see it?
newtoke
Post by newtoke »
  ReefAngel.ActinicLights( Port5 );
  ReefAngel.MoonLights( Port4 );
  ReefAngel.PWM.ActinicPWMSlope( 60 );
  //Moon output
  moonPWM = Moon.MoonPWM(0, 20);
  if (moonPWM >= 1)
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.Off( Port3 );
  //light temp
  int lightTemp = ReefAngel.Params.Temp[T2_PROBE];
  if(lightTemp > 1200) lightOverHeat = true;
  if(lightTemp < 900)
    lightOverHeat = false;
  //fan control
  if(lightTemp > 950)
    //turn on fans when over 95 degrees
  else if(lightTemp <= (ReefAngel.Params.Temp[T1_PROBE] + 50))
    //turn off fans when in five degrees of room temp;
    ReefAngel.Relay.Off( Port8 );
  //driver control
  if (lightOverHeat)
	  ReefAngel.PWM.SetChannel(0, 0);
	  ReefAngel.PWM.SetChannel(1, 0);
	  ReefAngel.Relay.Off( Port5 );
	  ReefAngel.PWM.Channel0PWMSlope();
	  ReefAngel.PWM.Channel1PWMSlope(60);
	  ReefAngel.Relay.On( Port5 );
newtoke
Post by newtoke »
Oh and the code worked fine with my older meanwell drivers.
This code doesn't use the dimming expansion.
Try adding this to see if it works:
ReefAngel.PWM.SetChannel(0,100);
ReefAngel.PWM.SetChannel(1,100);
ReefAngel.PWM.SetChannel(2,100);
ReefAngel.PWM.SetChannel(3,100);
ReefAngel.PWM.SetChannel(4,100);
ReefAngel.PWM.SetChannel(5,100);
newtoke
Post by newtoke »
Isn't this the dimming expansion code?
//driver control
if (lightOverHeat)
Oh. :oops:
My bad. I didn't scroll down the code.
I just looked the top part.
You are correct. They are for the dimming module.
What do you see in the screen for the channels 0 and 1?
Is it showing 0 or some other number?
newtoke
Post by newtoke »
Its 100 as it should be.
I'm thinking it is something in your wiring or your driver.
Can you post a sketch of how you connected stuff together?
newtoke
Post by newtoke »
If you disconnect the white ch0 wire, what voltage do you get on channel 0?
newtoke
Post by newtoke »
I will have to check when I get back into work on Tuesday.
