Re: Proofreading Jebao on ATO.....
Posted: Sun Aug 24, 2014 4:43 pm
by GiraffeCat
lnevo wrote:Pretty straight forward like you said.
2 things to verify that you did download the dev tree and also make sure you restart arduino.
Reinstalled Arduino - Reef Angel Controller. Downloaded the dev tree. Replaced the contents of the "libraries" folder with the contents of "libraries-dev"- no change. Closed arduino, restored the original libraries folder, and then overwrote the folders that were different in the libraries - no change.
Is there something I am not adding up top in the code somewhere?
Anyway. It works as it is now. I would like to understand what is going on now to help prevent future issues. LMK. Thank you,
Dan
Posted: Sun Aug 24, 2014 4:45 pm
Can you post the code you attempted to compile?
Posted: Sun Aug 24, 2014 6:16 pm
by GiraffeCat
lnevo wrote:Can you post the code you attempted to compile?
Here is the quick throw together code. My current code is in the first post. I feel like it is something stupid I am missing.
(I want a bigger monitor, no, make that two bigger monitors.) I do like the fact that my current set up has three different "modes" for different times of day. If you figure out my issue with the libraries, then would you please tell me how to do my different modes your way? The more I learn now the better off I will be.
InternalMemory.OverheatTemp_write( 805 );
ReefAngel.StandardLights( Port1,17,0,17,2 );
ReefAngel.StandardLights( Port2,19,0,19,1 );
ReefAngel.StandardLights( Port3,19,2,19,5 );
ReefAngel.StandardHeater( Port4,773,776 );
ReefAngel.StandardFan( Port5,781,785 );
ReefAngel.StandardLights( Port6,9,0,20,0 );
ReefAngel.StandardLights( Port7,8,30,20,30 );
ReefAngel.StandardLights( Port8,8,29,20,31 );
ReefAngel.PWM.SetDaylight( PWMSlope(9,0,20,0,0,90,60,0) );
ReefAngel.PWM.SetActinic( PWMSlope(8,30,20,30,0,90,60,0) );
ReefAngel.DCPump.SetMode( TidalSwell,65,10 );
ReefAngel.DCPump.LowATOChannel = Sync;
ReefAngel.DCPump.HighATOChannel = AntiSync;
ReefAngel.Portal( "GiraffeCat" , "passwordgoeshere");
GC
Posted: Mon Aug 25, 2014 9:18 am
It compiles fine. Can you please try again and post the error. Make sure you have the right Libraries folder when you're updating... if you look in the file DCPump/DCpump.h within the Libraries folder you should see the Low and High ATO channel defined as bytes.
If you're getting this, you're NOT using the right libraries for sure.
sketch_aug25a.cpp: In function 'void loop()':
sketch_aug25a:85: error: 'class DCPumpClass' has no member named 'LowATOChannel'
sketch_aug25a:86: error: 'class DCPumpClass' has no member named 'HighATOChannel'
It's important the we figure out the issue to make sure there's no issue with the dev libraries... so thanks in advance. Once we get this working we can simplify your code and use the right methodology
for now, though I'm glad it's working for you.
Posted: Mon Aug 25, 2014 8:53 pm
by GiraffeCat
lnevo wrote:It compiles fine. Can you please try again and post the error. Make sure you have the right Libraries folder when you're updating... if you look in the file DCPump/DCpump.h within the Libraries folder you should see the Low and High ATO channel defined as bytes.
That is the error it generates when I hit verify. I went back and downloaded the dev libraries again. It unzips and saves in downloads folder as "Libraries-dev", so I think I am downloading the right files. I deleted the "Libraries" folder from Computer/Local Disk(C)/Program Files(x86)/Reef Angel Controller, and put the "Libraries-dev" folder in its place. No change. Changed the folder name from "Libraries-dev" to just "Libraries", closed Arduino, restarted it, and - wait for it - No change. Dang it.
When I open the DCPump header file I see:
- header file.jpg (145.22 KiB) Viewed 5996 times
Let me know what you want me to try next. Different computer maybe? Is there a supporting library I need to check?Already reinstalled Arduino - Reef Angel Controller twice. Restarted computer multiple times, restarted Arduino between each try.
Thank You,
Dan
GC
Posted: Mon Aug 25, 2014 9:05 pm
Ahhh.
You are placing the files in the wrong spot.
Here is what you will need to do to fix it:
Reinstall Arduino - Reef Angel Controller to place the original libraries folder back.
Move the dev libraries folder into Documents\Arduino\libraries.
Posted: Tue Aug 26, 2014 7:06 pm
by GiraffeCat
rimai wrote:Ahhh.
lnevo wrote:You want to change the branch to dev and then on the bottom right you can download the zip file.
Unzip it and replace the libraries folder with whats inside
I was just doing what it says!
Glad that was an easy fix. Two folders-same name. Leave it to me to find the monkey trap.
Anyway. Thanks for lurking, Roberto.
Now. This young grasshopper would love to continue his lesson on multiple wave settings the "easy way". lnevo, please continue. I'm going to stare at Colin's else mode for a little while, maybe figure it out.
(Yeah, right.)
Thank you,
Dan
Posted: Tue Aug 26, 2014 8:57 pm
Here you go. only the relevant code is displayed.
ReefAngel.DCPump.Threshold = 32;
if (hour()>=9 && hour()<17)
ReefAngel.DCPump.SetMode(LongPulse,60,8);
else if (hour()>=17 && hour()<18)
ReefAngel.DCPump.SetMode(NutrientTransport,75,50);
else if (hour()>=18 && hour()<9)
ReefAngel.DCPump.SetMode(LongPulse,40,12);
You no longer need to set the low speed to 32 anymore since the dev libraries now have a threshold you can set on the pumps. You'll see I defined that right after setting the pump channels. After that it was just a matter of setting the speed and duration based on what you had before. One call to SetMode takes care of everything
Posted: Wed Aug 27, 2014 6:40 pm
by GiraffeCat
Thank you. Not too much different, just getting rid of all the "instruction" in the custom area and let "SetMode" do its thing.
Okay, so what would it take to get the pumps to go nuts during a lightning storm, and then go back when done.
Is it as easy as:
if CheckCloud() // I'm not sure on the terminology, just an example.
ReefAngel.DCPump.SetMode (BatShipCrazy,90,5) // I know it's not a real mode (yet), you know what I mean!
else if (hour.....blah blah blah and so on.
Just would be nice to make it randomly go nuts with the lightning storms - you know.
Thank you,
GC
Posted: Sun Jan 01, 2017 1:18 pm
by Reefology
happy new year
Im having a similar problem as the original post except it just the antisync pump running full throttle and doesn't respond to commands such as feeding mode?
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port2 );
//ReefAngel.StandardLights( Port4, 19,0,7,0); //Skimmer, Reactor 7pm-7am
ReefAngel.StandardLights( Port5 );
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DosingPumpRepeat2( Port7 );
ReefAngel.DosingPumpRepeat3( Port8 );
ReefAngel.DCPump.LowATOChannel = Sync; // WP40
ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
ReefAngel.DCPump.AntiSyncOffset = 110; // % (0-255) of main pump (Sync)
// koralia 1150
// if (hour()>=23 || hour()<11) ReefAngel.Relay.Off( Port5 );
// else ReefAngel.WavemakerRandom( Port5, 120, 1800 );
// DC pumps
// To run this code must choose Custom in portal
static int rmode;
byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
if (now()%3600==0 || changeMode==true) { // Change every 60 mins (3600seconds) or controller reboot
rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
changeMode=false;
static unsigned long feeding;
// Continue NutrientTranspot Mode for 30 minutes after feeding
if (now()-feeding<1800) {
ReefAngel.DCPump.Mode=NutrientTransport;
// Night mode (go to 30%)
} else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11pm to 11am
ReefAngel.DCPump.Mode=Gyre;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
already changed this line based on the info above:
to:
thanks
Posted: Tue Jan 03, 2017 7:15 am
by Reefology
fyi, both cables working on the ATO low, tried switching sync with antisync and it appears to be the ATO high pin just sending a constant 5v signal???
any input would be great.
thanks
Posted: Wed Jan 04, 2017 6:26 pm
by Reefology
bump
thanks
Posted: Sat Jan 07, 2017 9:05 pm
by Reefology
bump
