ATO Timeout question
westonhull
Re: ATO Timeout question
Post by westonhull »
Hello,
First I want to thank you for sticking through this with me. Well I swapped around the lines and changed the highfloatflag. So the outlet is correct when it goes high it does shut off but the buzzer goes to 100% when the switch is low and goes to 0% on High. :evil: Not to sure what's the deal.
Thanks again!
Wes
I told you what to do if that happens. Change == to !=
Can you please post the current code. And confirm that you tried both scenario?
westonhull
Sorry thought I did...
Here is the current code.
byte buzzer=0;
byte highfloatflag=0;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.CO2Control( Port1,638,678 );
    highfloatflag = ReefAngel.HighATO.IsActive();
    ReefAngel.Relay.Set(Port2, highfloatflag);
    if (highfloatflag) buzzer = 100; else buzzer=0;
    ReefAngel.Portal( "westonhull" );
I tried the != 1 and that was 100% on high and 1% on low.
I thought I tried the == but I guess, I didn't write that one down on my pad. I'll let you know in a sec.
There can be no 1% with the code we have:
Because no matter what it's getting set to 100 or 0.
From the conversations we had, the 1% was when we were doing < and > comparisons...
Looking at your code if the outlet is working properly we will want to do this:
    if (highfloatflag) buzzer=0; else buzzer=100;
We took away the == and != comparison...so that wasn't relevant. Sorry my bad.
westonhull
Hello,
Well that worked! You are way better at this than I am. Where did you learn this language from? Do you have any books for dummy's for this stuff, if so I need them to get them? Anyways, Here is the final code. Thanks for helping me!
byte buzzer=0;
    if (highfloatflag) buzzer = 0; else buzzer=100;
The language is C. You can find many books and sites on the language. It's pretty straight forward. The challenge here I think was just the different approach that was taken with the comparison and a bit of brain fart on my end. :)
