Re: Using RA Hardware on a Raspberry Pi / Beaglebone Black
Posted: Tue Nov 17, 2015 5:24 am
Just as a follow up, using the RA hardware from RPI/BBB (in this case ORP module) is great. As expected, you just need to create some interface classes to allow them to be read over I2C.
Here is an example of the ORP class I created to allow the ORP module to be used. In the example I have hard coded the calibration data, but you could also pass it in. You can re-calibrate by instantiating a new object and calling readRaw() to get the unconverted value and then hard coding the value, or override the calibration datain the instances. In the example I had calibrated at 0mv (1480) and 400mv (367).
The class only depends on the Adafruit I2C library for communication.
Dennis
#!/usr/bin/python
from Adafruit_I2C import Adafruit_I2C
class RA_ORP(object):
def __init__(self, address = 0x4C, busnum = 1, calibration = ( 1480, 367, 0, 400 )):
self.i2c = Adafruit_I2C(address=address)
self.address = address
self.calibration = calibration
self.queue = []
self.lastRaw = 0
self.overCnt = 0
self.maxChange = 300
self.maxOverCnt = 20
self.queueLength = 20
self.debug = 0
def readRaw(self):
return self.i2c.reverseByteOrder(self.i2c.readU16(0x00))
def readSingle(self):
return self.convert(self.readRaw())
def read(self):
value = self.readRaw()
if self.debug: print "Raw value read:",value
if self.lastRaw == 0 or abs(value - self.lastRaw) < self.maxChange:
self.queue.append(value)
self.lastRaw = value
self.overCnt = 0
else:
self.overCnt += 1
if self.overCnt > self.maxOverCnt:
self.overCnt = 0
if len(self.queue) > self.queueLength:
self.queue.pop(0)
return self.convert(self.mean())
def convert(self,x):
return (x - self.calibration[0]) * (self.calibration[3] - self.calibration[2]) // (self.calibration[1] - self.calibration[0]) + self.calibration[2]
def mean(self):
n = len(self.queue)
if n < 1:
raise ValueError('mean requires at least one data point')
return sum(self.queue)/n
