Re: Wifi issue - all LED blinking
Posted: Sat Jan 09, 2016 4:52 pm
Ok I removed the ' in the SSID and ran the Macro fix in Tera Term; but the lights are blinking blue. Here is the code Marco that was config to my Wifi:
CMD
factory RESET
Set Factory Defaults
<4.41> reboot
*Reboot*CMD
set ftp address 198.175.253.161
AOK
<4.41> save
Storing in config
<4.41> set wlan ssid Moes Tavern
AOK
<4.41> set wlan pass ____Hiden__
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name www.reefangel.com
AOK
<4.41> set i h 198.171.134.6
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
<4.41> set u b 57600
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
Any thoughts? Should I run Wifi utility? I thought you run the macro, you don't need to use the wifi utility anymore. It should be already configured.
Troy
CMD
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
AOK
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
AOK
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
Troy
