Re: Cannot write to new RA with webwizard
Posted: Sat Jan 14, 2017 9:07 pm
by GermanDude
This is the error I get when I try to download the plugin from within the webwizard.
HTTP Error 404.3 - Not Found
The page you are requesting cannot be served because of the extension configuration. If the page is a script, add a handler. If the file should be downloaded, add a MIME map.
Most likely causes:
It is possible that a handler mapping is missing. By default, the static file handler processes all content.
The feature you are trying to use may not be installed.
The appropriate MIME map is not enabled for the Web site or application. (Warning: Do not create a MIME map for content that users should not download, such as .ASPX pages or .config files.)
If ASP.NET is not installed.
Things you can try:
In system.webServer/handlers:
Ensure that the expected handler for the current page is mapped.
Pay extra attention to preconditions (for example, runtimeVersion, pipelineMode, bitness) and compare them to the settings for your application pool.
Pay extra attention to typographical errors in the expected handler line.
Please verify that the feature you are trying to use is installed.
Verify that the MIME map is enabled or add the MIME map for the Web site using the command-line tool appcmd.exe.
To set a MIME type, use the following syntax: %SystemRoot%\windows\system32\inetsrv\appcmd set config /section:staticContent /+[fileExtension='string',mimeType='string']
The variable fileExtension string is the file name extension and the variable mimeType string is the file type description.
For example, to add a MIME map for a file which has the extension ".xyz": appcmd set config /section:staticContent /+[fileExtension='.xyz',mimeType='text/plain']
Warning: Ensure that this MIME mapping is needed for your Web server before adding it to the list. Configuration files such as .CONFIG or dynamic scripting pages such as .ASP or .ASPX, should not be downloaded directly and should always be processed through a handler. Other files such as database files or those used to store configuration, like .XML or .MDF, are sometimes used to store configuration information. Determine if clients can download these file types before enabling them.
Install ASP.NET.
Create a tracing rule to track failed requests for this HTTP status code. For more information about creating a tracing rule for failed requests, click here.
Detailed Error Information:
Module StaticFileModule
Notification ExecuteRequestHandler
Handler StaticFile
Error Code 0x80070032
Requested URL http://forum.reefangel.com:80/webwizard ... taller.pkg
Physical Path D:\Inetpub\wwwroot\webwizard\download\plugininstaller.pkg
Logon Method Anonymous
Logon User Anonymous
More Information:
This error occurs when the file extension of the requested URL is for a MIME type that is not configured on the server. You can add a MIME type for the file extension for files that are not dynamic scripting pages, database, or configuration files. Process those file types using a handler. You should not allows direct downloads of dynamic scripting pages, database or configuration files.
View more information ยป
Posted: Sat Jan 14, 2017 9:33 pm
You may have the wrong link.
It's a dropbox link in the original post.
http://forum.reefangel.com/viewtopic.php?f=8&t=6199
Are you not getting a dropbox link?
Posted: Sun Jan 15, 2017 7:14 am
by GermanDude
That worked. Plugin installed on my Mac.
After reading the thread you pointed me too, I realize now that the web wizard is a work in progress. Overall it works great. I do have issues in the morning here on the east coast, with it not wanting to compile. It just shows the progress bar but never finishes compiling.I have to hard exit out of the wizard. In the afternoon it works better.
Posted: Sun Jan 15, 2017 9:47 am
Ok, what time in the morning?
I have to see why that is.
Posted: Sun Jan 15, 2017 11:23 am
by GermanDude
It was around 9 AM eastern time. I am in Florida.
Posted: Sun Jan 15, 2017 11:26 am
by GermanDude
I just did a compile at 1:24PM eastern time and it worked. Just took 30 seconds or so. I am compiling code done with the wizard.
Posted: Sun Jan 15, 2017 5:50 pm
by GermanDude
Quick update.
I finally am able to upload code to my RA+. Out of all my computer gear a cheap Acer windows tablet works the best. Most likely because there is very little software loaded on it.
I am happy.
Posted: Mon Jan 16, 2017 7:16 am
by GermanDude
I just tried to compile code again at 9AM, and problem still exists. Will not compile and hangs up the wizard.
I will try again after 12 PM.
Posted: Mon Jan 16, 2017 8:53 am
by GermanDude
Ok, 10:53AM and the code compiled very quickly.
Posted: Mon Jan 16, 2017 11:47 am
Thanks for the troubleshooting.
I'll have to check what is up in the morning.
