Alexa Control
Seedlessone
Re: Alexa Control
Hmmm. Just changed probe 1 name to display tank.rimai wrote:I used display tank with success
"Alexa, what is the temperature of display tank?"
"Sorry, I didn't find display tank"
Re: Alexa Control
Did you change it on the portal or the Alexa app?
When I changed names, I changed them in the portal then I went to Alexa app and deleted the old name device. Discovered devices again to find the one you deleted. It will come with the new name.
I didn't test if there was an easier way.
Seedlessone
Re: Alexa Control
Good to go now. Didnt even think about pulling the new device name into alexa app....duh!rimai wrote:Did you change it on the portal or the Alexa app?
Re: Alexa Control
I know you can change names on the Alexa app, and theoretically it should work without having to rename in the portal, but I didn't test.
- lnevo
Re: Alexa Control
The only thing I have programmed right now is:
Turn on ...
Turn off ...
Set ... to auto
What is the temperature of ...
Turn on ...
Turn off ...
Set ... to auto
- mav3rick478
Re: Alexa Control
I know this is an Alexa thread but is there any chance of the RA working with Google Assistant?
Sent from my Pixel XL using Tapatalk
Re: Alexa Control
I would need to look into how google handles everything.
Don't hold your breath though. It may take a while.
Seedlessone
Re: Alexa Control
Certainly not trying to rush, but what sort of timeline do you have on feeding and water change mode?rimai wrote:The only thing I have programmed right now is:
Turn on ...
Turn off ...
Set ... to auto
So far it has been 100%!!
- lnevo
Re: Alexa Control
Can you test feeding and water change mode?
You will need to discover devices again to enable the two modes.
- lnevo
89delta
Re: Alexa Control
So i'm trying to enable the skill and after the amazon login screen it takes me to the authorization page i guess and it remains blank. Any ideas?
Re: Alexa Control
I wasn't able to replicate.
I tried it on a new phone with a new amazon account.
icecool2
Re: Alexa Control
I just tried this myself and ran into an error trying to login.
I confirmed my username and password were correct by logging into the forum to double check. Same error comes up using Alexa app, Safari and Firefox. This is on ios12, not that I think that’s the issue.
icecool2
Re: Alexa Control
Just tried again hoping this would clear itself.... no dice. Still the same issue.
Re: Alexa Control
I just tested the amazon/reef angel skill linking and it went through just fine.
Try resetting the forum password and try again.
icecool2
Re: Alexa Control
That did the trick! Got the skill installed, but I'm getting device is unresponsive. I have the Wifi adapter, not the cloud adapter. Is that a problem?
It also only discovered my second relay box, not the first.
Re: Alexa Control
It actually only works with RA*.
I never tested with the cloud wifi attachment. It should work, but definitely not with the regular wifi attachment.
icecool2
Re: Alexa Control
Oh.... didn't see any mention of that in this thread. That stinks
Are there upgrade options from the RA+ to the RA*? I have everything but the head unit, I suppose.
Re: Alexa Control
We don't have it in the store, but I can probably work it out with you.
You will also need the old relay expansion module because the RA* only has expansion bus and doesn't have the svga connection.
Send me a PM.
Send me a PM.
89delta
Re: Alexa Control
It does work with the cloud attachment. Works fine for me. When I ask for pH I have to ask it as what is the pH temp?
Sent from my SM-N920T using Tapatalk
libertyaquarium
Re: Alexa Control
Hi there
Just trying Alexa with RA*. Any reason to just show my 1o relay box?
libertyaquarium
Re: Alexa Control
Any idea? Is it something wrong?
Piper
Re: Alexa Control
Is this still supported after the server migration?
- brennyn21
Re: Alexa Control
It's on the to do list for sure, but I don't believe it is working since the migration happened
Sincerely, Brennyn
Piper
Re: Alexa Control
Got it. Thank you.
