Page 1 of 2
Re: Alexa Control
Posted: Mon May 07, 2018 6:26 pm
I used display tank with success
Re: Alexa Control
Posted: Mon May 07, 2018 6:50 pm
by Seedlessone
rimai wrote:I used display tank with success
Hmmm. Just changed probe 1 name to display tank.
"Alexa, what is the temperature of display tank?"
"Sorry, I didn't find display tank"
Re: Alexa Control
Posted: Mon May 07, 2018 8:33 pm
Did you change it on the portal or the Alexa app?
When I changed names, I changed them in the portal then I went to Alexa app and deleted the old name device. Discovered devices again to find the one you deleted. It will come with the new name.
I didn't test if there was an easier way.
Re: Alexa Control
Posted: Tue May 08, 2018 8:24 pm
by Seedlessone
rimai wrote:Did you change it on the portal or the Alexa app?
Good to go now. Didnt even think about pulling the new device name into alexa app....duh!
Re: Alexa Control
Posted: Tue May 08, 2018 8:38 pm
I know you can change names on the Alexa app, and theoretically it should work without having to rename in the portal, but I didn't test.
Re: Alexa Control
Posted: Sat May 12, 2018 8:16 am
Is there a list of the commands anywhere?
Re: Alexa Control
Posted: Sat May 12, 2018 2:06 pm
The only thing I have programmed right now is:
Turn on ...
Turn off ...
Set ... to auto
What is the temperature of ...
Re: Alexa Control
Posted: Sat May 12, 2018 5:16 pm
by mav3rick478
I know this is an Alexa thread but is there any chance of the RA working with Google Assistant?
Sent from my Pixel XL using Tapatalk
Re: Alexa Control
Posted: Sat May 12, 2018 8:00 pm
I would need to look into how google handles everything.
Don't hold your breath though. It may take a while.
Re: Alexa Control
Posted: Mon May 14, 2018 7:15 pm
by Seedlessone
rimai wrote:The only thing I have programmed right now is:
Turn on ...
Turn off ...
Set ... to auto
Certainly not trying to rush, but what sort of timeline do you have on feeding and water change mode?
So far it has been 100%!!
Re: Alexa Control
Posted: Tue May 15, 2018 5:39 am
Feeding mode would be most useful!
Re: Alexa Control
Posted: Sun May 20, 2018 12:04 am
Can you test feeding and water change mode?
You will need to discover devices again to enable the two modes.
Re: Alexa Control
Posted: Sun May 27, 2018 8:15 pm
Feeding mode worked nicely
Re: Alexa Control
Posted: Tue Jun 05, 2018 6:37 pm
by 89delta
So i'm trying to enable the skill and after the amazon login screen it takes me to the authorization page i guess and it remains blank. Any ideas?
Re: Alexa Control
Posted: Tue Jun 05, 2018 9:51 pm
I wasn't able to replicate.
I tried it on a new phone with a new amazon account.
Re: Alexa Control
Posted: Fri Oct 26, 2018 11:45 pm
by icecool2
I just tried this myself and ran into an error trying to login.
I confirmed my username and password were correct by logging into the forum to double check. Same error comes up using Alexa app, Safari and Firefox. This is on ios12, not that I think that’s the issue.
Re: Alexa Control
Posted: Tue Oct 30, 2018 9:50 am
by icecool2
Just tried again hoping this would clear itself.... no dice. Still the same issue.
Re: Alexa Control
Posted: Tue Oct 30, 2018 10:40 am
I just tested the amazon/reef angel skill linking and it went through just fine.
Try resetting the forum password and try again.
Re: Alexa Control
Posted: Tue Oct 30, 2018 1:00 pm
by icecool2
That did the trick! Got the skill installed, but I'm getting device is unresponsive. I have the Wifi adapter, not the cloud adapter. Is that a problem?
It also only discovered my second relay box, not the first.
Re: Alexa Control
Posted: Tue Oct 30, 2018 1:09 pm
It actually only works with RA*.
I never tested with the cloud wifi attachment. It should work, but definitely not with the regular wifi attachment.
Re: Alexa Control
Posted: Tue Oct 30, 2018 1:11 pm
by icecool2
Oh.... didn't see any mention of that in this thread. That stinks
Are there upgrade options from the RA+ to the RA*? I have everything but the head unit, I suppose.
Re: Alexa Control
Posted: Tue Oct 30, 2018 1:15 pm
We don't have it in the store, but I can probably work it out with you.
You will also need the old relay expansion module because the RA* only has expansion bus and doesn't have the svga connection.
Send me a PM.
Re: Alexa Control
Posted: Thu Nov 01, 2018 9:16 am
by 89delta
It does work with the cloud attachment. Works fine for me. When I ask for pH I have to ask it as what is the pH temp?
Re: Alexa Control
Posted: Mon Apr 06, 2020 6:38 am
by libertyaquarium
Hi there
Just trying Alexa with RA*. Any reason to just show my 1o relay box?
Re: Alexa Control
Posted: Wed Apr 08, 2020 12:13 pm
by libertyaquarium
Any idea? Is it something wrong?
Re: Alexa Control
Posted: Wed Apr 08, 2020 1:25 pm
I think only one box is enabled for Alexa
Re: Alexa Control
Posted: Sat Feb 03, 2024 9:14 am
by Piper
Is this still supported after the server migration?
Re: Alexa Control
Posted: Sat Feb 03, 2024 11:26 am
by brennyn21
It's on the to do list for sure, but I don't believe it is working since the migration happened
Re: Alexa Control
Posted: Sat Feb 03, 2024 1:01 pm
by Piper
Got it. Thank you.
Re: Alexa Control
Posted: Sun Dec 07, 2025 2:12 am
by brennyn21
Hi Piper, Alexa Control is now working please follow the instructions below to enable the skill.
To enable the Reef Angel Skill, open Alexa app, click the menu bar and select skills and games, then search "Reef Angel" you should see Reef Angel v2 pop up click that skill to enable and it will prompt you to login with your username and password.
Once added it will do a device discovery, and then you will be able to use voice control. Currently the only supported Parameters are Temp 1, Temp 2 Temp 3, pH, Salinity, ORP, pH Exp, Status Flags (Feeding Mode, Water Change Mode, Lights On Mode) Relay Expansion 1, and Relay Expansion 2. These may all show up in Alexa even if you don't have all these expansions.
The command structure is as follows.
Alexa What is [T1 Label] Temperature where t1 label is what you set in the Uapp for the Temp 1 Label.
For the Modes you will say, Alexa turn on Feeding Mode, or Turn on Water change mode, or Turn on lights on mode, For off you say Turn Off Feeding Mode, etc
For Relay Ports you have 3 commands On, Off and Auto. For Example for lets say Port 11 I named "Return Pump" in the Uapp, I will Say Alexa Turn Return Pump On, Or Turn Return Pump Off, or Turn Return Pump to Auto.
