Re: Power Control Expansion
Posted: Wed Jul 04, 2018 10:56 am
Can I see the code?
https://forum.reefangel.com/
// Define Relay Ports by Name
#define Return_Pump 1
#define Extra1 2
#define Skimmer 3
#define Heater 4
#define Fuge_Light 5
#define GFO_Pump 6
#define SaltMixPump 7
#define PowerCtlExp 8
//Define Relay 1 Ports by Name
#define FragHeater Box1_Port1
#define FragPowerhead Box1_Port2
#define FragLED1 Box1_Port3
#define WaterChange Box1_Port4
#define FragLED2 Box1_Port5
#define FragFilter Box1_Port6
#define BrutePump Box1_Port7
#define SaltUV Box1_Port8
//Define Power Control Expansion Ports by Name
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit;
ReefAngel.Relay.On( Return_Pump );
ReefAngel.Relay.On( FragPowerhead);
ReefAngel.Relay.On( WaterChange);
ReefAngel.Relay.On( BrutePump);
ReefAngel.Relay.On( FragFilter);
ReefAngel.Relay.On( GFO_Pump);
ReefAngel.Relay.On( SaltMixPump);
ReefAngel.Relay.On( Extra1);
ReefAngel.Relay.On( PowerCtlExp);
ReefAngel.Relay.On( SaltUV);
ReefAngel.Relay.DelayedOn( Skimmer,10 );
ReefAngel.StandardHeater( Heater,750,790 );
ReefAngel.StandardLights( Fuge_Light,21,0,11,0 );
ReefAngel.StandardLights( FragLED1,12,0,21,0);
ReefAngel.StandardLights( FragLED2,15,0,18,0);
//if Display Water Level Sensor Active, then turn off Return pump
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Return_Pump);
else ReefAngel.Relay.On(Return_Pump);
//If Skimmate Water Level Sensor Active, then turn of Skimmer pump
if (!ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Off(Skimmer);
else ReefAngel.Relay.On(Skimmer);
//frag tank heater control with T2 probe
if (ReefAngel.Params.Temp[T2_PROBE]>790) ReefAngel.Relay.Off( FragHeater );
if (ReefAngel.Params.Temp[T2_PROBE]<750) ReefAngel.Relay.On( FragHeater );
//Enter feeding mode to correspond with automatic feeder at 11AM and 2PM
if(hour()==11 && minute()==0 && second()==0) ReefAngel.FeedingModeStart();
if(hour()==14 && minute()==0 && second()==0) ReefAngel.FeedingModeStart();
ReefAngel.Portal( "XXXXXXXXXXX" );
ReefAngel.DDNS( "Reef" ); // Your DDNS is XXXXXXXXXXXXX
#define Extra1 2
#define Skimmer 3
#define Heater 4
#define GFO_Pump 6
#define Dose1 Box2_Port1
#define Dose2 Box2_Port2
#define Dose3 Box2_Port3
#define Dose4 Box2_Port4
ReefAngel.Relay.On( Dose1);
ReefAngel.Portal( "" );
ReefAngel.DDNS( "Reef" ); // Your DDNS is .myreefangel.com
Yes it should be.ucez wrote:The dynamic DNS allows you to control via the universal app? However, the data on the universal app is still correct?
