Client Suite 3.0
Re: Client Suite 3.0
woohoo....and the silent man speaks.
see, the interest is there and people are willing to help.
Just fired it up, first issue was the scan didn't detect it in the internal address space.. Might be router settings, lmk if you need more info.
Nice slick setup so far
I just recently got the RA setup and have been using the client for the past few days. I was curious if the issue in the attachment is related to something I've inadvertently done or just something with the client. If I did it, any idea how to reverse what I've done LOL? The issue is that I have a few lines of the same temp (e.g. two lines of 80°, two lines of 79° etc.). I end up with the same issue on the pH plots as well. If I open and close the app, occasionally I'll get something a little different. I've restarted the computer, stop/started the services etc. but nothing seems to correct it.
- gui.jpg (102.75 KiB) Viewed 21657 times
Just posting to say I really love this application and find it much quicker to use than the portal. I hope development can continue!
How does this work. Is it connected via ttl/usb to windows 10? I want to get a windows 2 in 1 or a full windows tablet and connect to it will this work?
I have it connected to my desktop (works on Windows 7 and 10) via USB/TTL. In the Settings, Notifications tab, you must check the "send parameters to Reef Angel Portal for online viewing." The SMS and email feature is very handy as well.troylong45 wrote:How does this work. Is it connected via ttl/usb to windows 10? I want to get a windows 2 in 1 or a full windows tablet and connect to it will this work?
I want to see my water level on the client. Searched here and found this:
Where do I upload this?
In the code?
Apologies if a stupid question, but am totally new to this
In the code?
I don't see any option in the client settings to view water level expansion, just float switches.#include <ReefAngel_Features.h>
ReefAngel.FeedingModePorts = Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port7Bit;
ReefAngel.PHControl( Port2,818,820 );
ReefAngel.StandardLights( Port4,11,0,21,30 );
ReefAngel.Relay.DelayedOn( Port5,1 );
ReefAngel.WaterLevelATO( Port6,120,42,44 );
ReefAngel.StandardHeater( Port7,255,265 );
ReefAngel.Relay.DelayedOn( Box1_Port5,1 );
The client is no longer being developer. It still works but I believe the water level sensor came after the client's last release. There is nothing to add to your code for the chart I posted.
Anyone else having issues with the checkbox for send parameters to Reef Angel Portal for online viewing? I keep trying to click it but nothing happens.
