Page 4 of 5
Re: Custom code, please help
Posted: Mon Dec 02, 2013 11:00 pm
That is an old internal memory file.
Use this instead:
InternalMemory.LCDID_write(255);
InternalMemory.HeaterTempOn_write(765);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(785);
InternalMemory.ChillerTempOff_write(775);
InternalMemory.OverheatTemp_write(800);
InternalMemory.IMCheck_write(0xCF06A31E);
ReefAngel.Init();
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+20, MENU_START_ROW*3, "Memory Updated");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*6, "You can now");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*7, "upload your");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+33, MENU_START_ROW*8, "INO code") ;
wdt_reset();
It will also configure the board for your old screen.
Posted: Tue Dec 03, 2013 10:16 am
by d0lph1n
Thank you Roberto. It works great. I appreciate it
Posted: Thu Dec 05, 2013 6:32 pm
by d0lph1n
For the past weeks i switched from dosing Ca & Alk to dosing Kalk + vinegar solution. Now that the Ph probe is working properly with the new RA plus board i'd like the ato sensor(s) to control the kalk + vinegar dosing pump instead of water if the ph is lower than lets say 8.1
This the current config:
ReefAngel.SingleATO(true,Box1_Port2,180,2);
ReefAngel.DosingPumpRepeat(Port8,1,120,4);
If the ph is smaller than 8.1 then ReefAngel.SingleATO(true,Port8,180,1) else ReefAngel.SingleATO(true,Box1_Port2,180,2);
Is this doable? What are the risks?
Posted: Thu Dec 05, 2013 7:11 pm
Not sure what you are trying to do...
Posted: Fri Dec 06, 2013 5:37 am
He wants to ato the vinegar+kalk when ph is less than 8.1 and ato ro/di otherwise
Posted: Fri Dec 06, 2013 9:26 am
Ahh... I don't think it would work though.
I think the port would never shut off if it was on and ph raised above 8.1
Try like this:
if (ReefAngel.Params.PH <= 810)
ReefAngel.SingleATO(true,Port8,180,1);
ReefAngel.Relay.Off(Box1_Port2);
ReefAngel.Relay.Off(Port8);
Posted: Fri Dec 06, 2013 11:09 am
by d0lph1n
Right, Inevo. Perfect. Roberto. Thanks. I'll give it a try asap.
Maybe I'm over complicating things. Maybe I should stay with the classic dosing method.
Posted: Fri Dec 06, 2013 12:23 pm
by d0lph1n
It works but it needs more tweaking.
If pH <=818 & ATO ON then the ATO controls the Kalk pump but if during this process ph>818 and the ATO still on, it stops pumping kalk and it doesn' start pumping fresh water without manually resetting the ATO sensor On/OFF
This is the existing code:
if (ReefAngel.Params.PH <= 818)
ReefAngel.SingleATO(true,Box1_Port7,70,0);
ReefAngel.SingleATO(true,Box1_Port8,120,0);
I think we have to introduce another IF that checks the ATO status.
We have the following variables:
Ph <= 818
Single ATO status = On/Off
ATO pump port = Box1_Port8
Kalk pump port = Box1_Port7
If ph <= 818
then
check ATO Status
{If ATO ON then
ReefAngel.SingleATO(true,Box1_Port7,70,1); # ATO pumps kalk
ReefAngel.Relay.On(Box1_Port7); #Kalk pump ON
ReefAngel.SingleATO(true,Box1_Port8,120,1); # ATO pumps fresh water
It needs a check ATO Status refresh at this point.
What do you think?
Posted: Fri Dec 06, 2013 3:33 pm
I think it is your restriction on the single ato function.
The last 1 means it will have to wait another hour to pump again.
Try zero instead.
Posted: Fri Dec 06, 2013 5:40 pm
by d0lph1n
Anyway, lets disregard this idea for now. It doesn't make too much sense in practice.
What's the safest way to dose kalk via Box1_Port7 if the ph drops below 818 but I also need a time out and a waiting period similar to the ATO function?
I built this code for now, is it ok? It will dose kalk for 20 seconds every 10 min until pH goes above 818, I hope. For my 8-9 gal of water, a 20 sec dose of kalk + vinegar+water (2g+15ml+1l) will increase the pH by 0.01-0.02
if (ReefAngel.Params.PH <= 818){ReefAngel.DosingPumpRepeat(Box1_Port7,0,10,20);}
if (ReefAngel.Params.PH >= 820){ReefAngel.Relay.Off(Box1_Port7);}
if (ReefAngel.Params.PH < 800){ReefAngel.Relay.Off(Box1_Port7);} #if it runs out of kalk or if the pH probe is damaged
Posted: Sun Dec 08, 2013 1:52 am
by d0lph1n
For the past 24h the dosing worked great.
Posted: Sun Dec 08, 2013 7:37 am
Nice! Just keep your eyes on the probe and double check it once in a while so you don't end up doing something bad
but way to control that swing!
Posted: Mon Dec 16, 2013 11:34 pm
by d0lph1n
Look what happend when it ran out of kalk + vinegar.
I left home for a couple of days and i forgot to refill the kalk+v container. When I realized why the pH was dropping I turned on an air pump to push more air into the skimmer. It helped for a while...but it was not enough.
Posted: Tue Dec 17, 2013 4:33 am
Thats not too bad...should see what my ph dropped to on thanksgiving with everyone over my house!
