Sunrise / sunset code based on location
thekameleon
Re: Sunrise / sunset code based on location
Post by thekameleon »
Fun times... Well Let me take a look how NOAA does it... I am sure it is similar but maybe if I play around with moving the decimal point... I can figure something out... Do you know the floating point precision limitations or a link to them?
Truthfully i think its good enough. I would think time would better be spent making it an easy package to add to the libraries and all the other stuff. You could always fine tune the times with the offsets...
thekameleon
Agreed. If accuracy is not important, do you think it might be just easier to just re-write this as a simple sin wave for seasonal changes of sunrise and sunset. Provide a parameter that can adjust the amplitude and another as the start date of the wave? i.e. the crest of the wave could be on 12/21 and the trough on 6/21.
I just double checked my rise/ set which is coming up as 9:10-11:10 currently and compared to Bahamas rise / set.. Bahamas is:
Jun 8, 2013 6:19 AM 7:58 PM 13h 39m 20s + 24s 1:08 PM 87.8° 94.362
So I'm 10 minutes each direction 20 minutes total...I personally like being tied to gps coordinates event though its a bit wacky with the way the GMT time is in the
RA. If I had to do it over again a sine wave would be fine...a similar function would work for moon, but I'm not so sure on that implementation..l
thekameleon
I took a look an NOAA's website and I might try converting it to javascript. My thinking was to create it as a Sin Wav and then have templates for the caribeean, barrier reef, Hawaii, etc... While not 100% accurate, it would be simple for the average reefer to implement.
clw143
Post by clw143 »
Please look at my code below, the on time for today for my lights is 10:46 and off time of 00:00.
What did I miss?
#include <SunLocation.h>
byte wp40mode; //Mode Byte
SunLocation sl;
  // Add Standard Menu
  ReefAngel.AddStandardMenu();
  ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit;
  ReefAngel.Relay.On( Port3 ); //Mag 12 Return Pump
    ReefAngel.Init();
    // initialize the sunrise / sunset location
    sl.Init(28.253831, -81.264846); // Latitude , Longitude values set
  ReefAngel.DayLights( Port1 ); //T5HO Day Lights (Whites)
  ReefAngel.ActinicLights( Port2 ); //T5HO Actinic Lights (Blues)
  ReefAngel.Relay.DelayedOn( Port4 );  //Reef Octopus NW150 Skimmer and Phosban
  ReefAngel.StandardFan( Port6 ); //Cooling Fans
  ReefAngel.DosingPumpRepeat1( Port7 ); //Dosing Pump
  ReefAngel.StandardATO( Port8 ); //ATO Pump
    // handle updating sunrise and sunset values
    sl.CheckAndUpdate();
  // Dimmable royal blues 100% if actinics (relay port 2) are on, else moonlight
  if ReefAngel.Relay.IsMaskOn(Port2); {
    ReefAngel.PWM.SetActinic( 100 );
  else {
  //Start Feeding Mode at 17:00 (hour*60*60)
  if ( (now()%86400==61200) /*|| (now()%86400==39600) */) {
    ReefAngel.FeedingModeStart();
  //Hydor Evolution 1400 Circulation Pump Port5 Off Between 10pm and 8am
  if (hour()<8 || hour()>=22)  {
    ReefAngel.Relay.Off(Port5);
  else {
    ReefAngel.Relay.On(Port5);
  //assignmenets are = and comparisons are ==
  if (hour()>=8 && hour()<12) wp40mode=7; //8am - 11:59am
  else if (hour()>=12 && hour()<17) wp40mode=6; //12pm - 4:59pm
  else if (hour()>=17 && hour()<18) wp40mode=5; //5pm - 5:59pm
  else if (hour()>=18 && hour()<24) wp40mode=3; //6pm - 11:59pm
  else wp40mode=4; //12am - 7:59am
  if (wp40mode==9) ReefAngel.PWM.SetDaylight( 100 ); //Full Speed
  if (wp40mode==8) ReefAngel.PWM.SetDaylight( 100/3 ); //Third Speed
  if (wp40mode==7) ReefAngel.PWM.SetDaylight( millis()%1100>800?75:0); //Custom "W1"
  if (wp40mode==6) ReefAngel.PWM.SetDaylight( TidalSwellMode(80,true ) ); //WaveMaxSpeed, PulseSync
  if (wp40mode==5) ReefAngel.PWM.SetDaylight( NutrientTransportMode(0,65,2000,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==4) ReefAngel.PWM.SetDaylight( LongPulseMode(0,50,3,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (s), PulseSync
  if (wp40mode==3) ReefAngel.PWM.SetDaylight( ShortPulseMode(0,80,1200,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==2) ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true ) ); //WaveSpeed, WaveOffset, PulseSync
  if (wp40mode==1) ReefAngel.PWM.SetDaylight( SineMode(0,100,10,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==0) ReefAngel.PWM.SetDaylight( TideMode(20,100,20 ) ); //WaveSpeed, minOffset, maxOffset
  ReefAngel.Portal( "clw143" );
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.Clear(DefaultBGColor,0,0,132,132);
  ReefAngel.LCD.DrawDate(6, 3);
  ReefAngel.LCD.DrawText(0,255,18,14,"Jebao WP40 Mode:");
  if (wp40mode==0) ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,42,25,"Tide");
  else if(wp40mode==1) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,42,25,"Sine");
  else if (wp40mode==2) ReefAngel.LCD.DrawLargeText(COLOR_ORANGE,255,23,25,"Reef Crest");
  else if (wp40mode==3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,23,25,"Short Pulse");
  else if (wp40mode==4) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,23,25,"Long Pulse");
  else if (wp40mode==5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,25,"Nutrient Trnsp.");
  else if (wp40mode==6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,25,"Tidal Swell");
  else if (wp40mode==7) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,40,25,"Custom");
  else if (wp40mode==8) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,25,25,"1/3 Power");
  else if (wp40mode==9) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,23,25,"Full Power");
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 34, 132, 34);
  ReefAngel.LCD.DrawText(0,255,10,37,"Disp");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 8, 45, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,53,37,"Room");
  ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 50, 45, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,95,37,"Sump");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 93, 45, text, Num8x8);
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 53, 132, 53);
  ReefAngel.LCD.DrawText(0,255,10,56,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 27, 56, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,67,56,"WP40");
  ConvertNumToString(text, ReefAngel.PWM.GetDaylightValue(),1);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 95, 56, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,118,56," %");
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 65, 132, 65);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,7,85,"Shaun");
  ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 50, 88,"&");
  ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,70,98,"Kerri's");
  ReefAngel.LCD.DrawLargeText(0,255,7,108,"90Gal Reef Tank");
    char buf[16];
    sprintf(buf, "%02d:%02d", sl.GetRiseHour(), sl.GetRiseMinute());
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,10,67,"Sunrise: ");
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,58,67,buf);
    sprintf(buf, "%02d:%02d", sl.GetSetHour(), sl.GetSetHour());
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,10,75,"Sunset:  ");
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,58,75,buf);
  ReefAngel.LCD.DrawOutletBox(12, 118, TempRelay);
Where are those coordinates supposed to be and what timezone are you in?
One thing to note is that the controller assumed it is in GMT timezone so whatever coordinates you calculate the time will be set accordingly. You also probably need to adjust the offset so it's in the window you want your lighting schedule to be.
Also your code is a bit odd in that the check and update is combined with showinterface and inside { } which changes the scope. I dont think thats interfering but i wouldnt do that and you should only have showinterface called once at the end of loop which you do.
clw143
Post by clw143 »
location is in Florida EST -5
All the code added was from a post on usage from Binder on page 5, maybe that was wrong.
Try this code
http://forum.reefangel.com/viewtopic.php?p=17804#p17804
I think there were some bugs in the initial version. Otherwise start setting an offset so that it gets earlier and see how many hours you need to pull back to not have midnight as the set time.
clw143
Post by clw143 »
What is the difference in what you have done here
ReefAngel.StandardLights( Port1 );
And what the wizard has done here
If you look inside the ReefAngel.cpp line 1054, you will see that they are the exact same thing :)
void ReefAngelClass::DayLights(byte Relay)
	StandardLights(Relay);
Latest version I'm using
SunLocation.zip
(4.17 KiB) Downloaded 530 times
DesignInstinct
Re: Dawn/dusk simulator
Post by DesignInstinct »
Hi, I'm looking for somebody to assist with a standalone Arduino project using this code to control LED lights.
Want to simulate accurate sunrise/set times...and *proper* twilight length of 60-90 minutes.
Need to ramp the LED lights smoothly over this time period. Just like what happens when looking out a window at the sun. Want to match real life fairly closely.
I'm also going to purchase a Reef Angel Plus anyway to do aquaponics/greenhouse control.
I'm NOT a programmer...but very computer literate.
Would NOT like to become a programmer ;)
Far too busy with other projects in other fields.
Will gladly pay to have this "done" for me.
Would like to do a lot of it over Team Viewer in realtime (voice/video).
I can work faster this way. Yes, they have Team Viewer for Linux. I'm on Win 8.1.
"Several inexpensive “light alarm clocks” have been marketed, cloning the DDS concept, but with rapid dawn ramps (far faster than natural dawns) and restricted fields of illumination. These mass-market products have not yet received adequate clinical evaluation. "
Yeah...that's an understatement.
Can't post links here so PM me for similar devices and why they fail at doing this.
This will benefit reef tanks, greenhouse applications, and humans living in dark houses up North.
I want to simulate sunrise/sunset and evening lighting no matter what the cloud cover outside. May be moving from New Mexico back to the frozen North and will need this badly. Most people need this and don't even know it.
Any improvements to the Reef Angel code and the standalone Arduino version code would be kept open source. This stuff is too important to be proprietary.
Google gizmag NASA led lights
Gonna let NASA and Boeing steal our thunder?
Any takers? Reply here, PM me whatever!
89delta
Post by 89delta »
lnevo....
I've just finished compiling my sketch for my RA+ I recently got and it works great. Am using the Clouds and weather patterns on the standard pwm channels from http://forum.reefangel.com/viewtopic.ph ... 8&start=50. ButI was wondering how to incorporate the location based sunrise/sunset code into it as i've only seen it being used for the standard lights on relays. Thanks for any help.
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 6, 4, " Martin's BC29");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, " Display      PH");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text);
y += MENU_START_ROW*2;
x = 10;
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"Hood:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor,
9, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"Room:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], T3TempColor,
x+9, y+35, 10);
//ReefAngel.LCD.DrawText(0,255,20,80,MoonPhaseLabel());
    //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port2 );
    ReefAngel.DosingPumpRepeat1( Port4 );
    ReefAngel.DosingPumpRepeat2( Port5 );
    ReefAngel.StandardATO( Port6 );
    //ReefAngel.PWM.SetDaylight( MoonPhase() );
    //ReefAngel.PWM.SetActinic( MoonPhase() );
    ReefAngel.Portal( "89delta" );
  ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(10,00,22,15,0,50,40,DaylightPWMValue);
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 5
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
You would use it in the section that says Calculate your regular sunrise/sunset PWM value. The sunlocation class which i dont see declared will have methods to get the rise hour/minute and set hour/minute. You'll plug those into the pwmslope function arguments.
89delta
Post by 89delta »
Thanks for the fast reply lnevo...I know i've still gotta add the rest of the code to my sketch, but something like this:
SunLocation sl;
byte x = 6;
byte y = 2;
byte t;
x = 12;
char text[7];
x = 10;
x += (16*4) + 8;
9, y+35, 10);
x+9, y+35, 10);
  sl.Init(-18.285833, 147.699722); // In decimal numbers (i.e. -18.285833, 147.699722)
    sl.SetOffset(0,0,0,0); // rise_hour, rise_seconds, set_hour, set_seconds
  ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,50,40,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,50,40,DaylightPWMValue);
  CheckCloud();
void CheckCloud()
#define Min_Cloud_Duration 6
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
I see you figured it out! Yes exactly :) let us know if that worked for you?
89delta
Post by 89delta »
Nice....thanks for looking lnevo. My other question is in regards to the moon phases. Can I use sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute() in switching over to the moonphase() for my blue leds after the day has finished.
Yes, but you might want to also look at my moon rise/set class that you can use too which calculates the rise/set times for the the Moon :) However, you can use the sl.GetXXX() for whatever scheduling you want. You could also look at the option sl.UseMemory=true which will set the StandardLight schedule into memory so you could have other devices that aren't dimming let's say based off the sunrise/sunset schedule.
89delta
Post by 89delta »
How would I incorporate your moon class into it lnevo.....thanks for your help.
89delta
Post by 89delta »
Sweet....thank lnevo. Will try it out tonight when i get home.
Sent from my SAMSUNG-SGH-I717 using Tapatalk
89delta
Post by 89delta »
So everything is working correctly with my sketch, Sunrise/sunset, Weather and moon phases. Although i've noticed that the sunrise/sunset times don't really change but by +/- 2 minutes. Is that normal for the most part? My Long/Lat is set to the GBR between Paul Reef and Storm Reef off of Queensland,AU.
sl.Init(-21.285833, 150.999722); // In decimal numbers (i.e. -18.285833, 147.699722)
sl.SetOffset(11,0,11,0); // rise_hour, rise_seconds, set_hour, set_seconds
Yep, try tracking it over the course of a month or two. Area's closer to the equator are going to have the smallest amount of shift daily as the fluctuation is only going to be +/- 2 hours or so over the course of the seasons.
89delta
Post by 89delta »
Ok, thanks for the clarification lnevo. Love everything you guys have done with coding and everything else.
