Re: Custom Main Screens
Posted: Tue Apr 02, 2013 1:56 pm
You will need to copy/paste your custom screen everytime.
https://forum.reefangel.com/
byte x;
byte y = 2;
char text[7];
// *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
int TempColor; // Color for drawing temperature
boolean FanOn = ReefAngel.Relay.Status(Port1); // Get the status of the fan relay
boolean HeatOn = ReefAngel.Relay.Status(Port2); // Get the status of the heater relay
if (HeatOn)
TempColor = COLOR_NAVY; // Blue text, too cold, heater is on
if (FanOn)
TempColor = COLOR_RED; // Red text, too warm, fan is on
if (!HeatOn && !FanOn)
TempColor = COLOR_GREEN; // Green text, no fan or heater on
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Colin's Reef"); // Put a banner at the top
ReefAngel.LCD.DrawDate(6, 119); // Put the date and time at the bottom
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11); // Draw a black line under the banner
x = 12;
y += MENU_START_ROW+1; // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp pH");
ConvertNumToString(text, ReefAngel.Params.PH, 100); // Get pH reading and convert
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16); // Put pH on the screen
ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); // Get T1 temp and convert
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, TempColor, x, y, text); // Draw the temperature, white numbers on a colored background
x += (16*4) + 8;
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,8,y+25,"White %");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, 24, y+35, 1); // Draw the white light %
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+8,y+25,"Blue %");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+24, y+35, 1); // Draw the blue light %
// Code for drawing the relay box
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
Thanks! And thanks for the templates. I'm having a blast with my Reef Angel. I doubt this is the final version of my main screen.binder wrote:I had NO IDEA that all these awesome designs and ideas would come from me creating these template functions to allow people to customize their displays.
Great idea for your display. Simple and clean. Looks great!
byte x;
byte y = 2;
char text[7];
if (HeatOn)
if (FanOn)
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLACK, 0, 1, " Colin's Reef "); // Put a banner at the top
pingSerial(); // Hit the Wifi Attachment
x = 12;
x = 10;
ReefAngel.LCD.Clear(TempColor, x, y-1, x+63, y-1); // Draw a line above and below the temp
ReefAngel.LCD.Clear(TempColor, x, y+16, x+63, y+16); // To make it look nicer and easier to read
x += (16*4) + 8;
ReefAngel.LCD.Clear(COLOR_BLACK,5,y+22,127,y+22); // Draw a box around the light area
ReefAngel.LCD.Clear(COLOR_BLACK,5,y+22,5,y+46); //
ReefAngel.LCD.Clear(COLOR_BLACK,127,y+22,127,y+46); //
ReefAngel.LCD.Clear(COLOR_BLACK,5,y+46,127,y+46); //
ReefAngel.LCD.DrawOutletBox(14, 92, TempRelay);
Add this to the very end of the code posted above:Bo0sted_Rafi wrote:im trying to use the custom screen that showed here but when I upload the code, still showing the graph of the standard screen. Where in the code i remove that graph?
#define SIMPLE_MENU
#define NUMBERS_8x16
int avgph[10];
unsigned long totalavgph=0;
byte avgindex=0;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port3Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port3Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port7Bit ;
ReefAngel.Relay.On( Port5 );
for (int a=0;a<10;a++) avgph[a]=analogRead(PHPin);
totalavgph=0;
avgph[avgindex]=analogRead(PHPin);
avgindex++;
if (avgindex==10) avgindex=0;
totalavgph+=avgph[a];
totalavgph/=10;
totalavgph=map(totalavgph, ReefAngel.PHMin, ReefAngel.PHMax, 700, 1000); // apply the calibration to the sensor reading
totalavgph=constrain(totalavgph,100,1400);
if (totalavgph <= 645) ReefAngel.Relay.Off(Port3);
if (totalavgph >= 660) ReefAngel.Relay.On(Port3);
// ReefAngel.CO2Control( Port3,645,660 );
ReefAngel.StandardFan( Port4,780,788 );
ReefAngel.WavemakerRandom( Port6,600,180 );
ReefAngel.StandardLights( Port7,0,30,12,30 );
ReefAngel.StandardLights( Port8,12,0,2,30 );
ReefAngel.Portal( "Bo0sted_Rafi" );
byte x;
byte y = 2;
char text[7];
boolean FanOn = ReefAngel.Relay.Status(Port4); // Get the status of the fan relay
boolean HeatOn = ReefAngel.Relay.Status(Port7); // Get the status of the heater relay
if (HeatOn)
if (FanOn)
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Rafi's Reef"); // Put a banner at the top
x = 12;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp CA pH");
x = 10;
x += (16*4) + 8;
#define SIMPLE_MENU
int avgph[10];
byte avgindex=0;
byte x;
byte y = 2;
char text[7];
if (HeatOn)
if (FanOn)
x = 12;
x = 10;
x += (16*4) + 8;
totalavgph=0;
avgindex++;
totalavgph/=10;
// Autogenerated file by RAGen (v1.2.2.171), (05/14/2012 18:11)
// RA_051412_1811.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x8
ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,DefaultBGColor,15,5,"Ariel's Reef");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,1,30,"Vortech:");
byte vtechmode = InternalMemory.RFMode_read();
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,DefaultBGColor,50,30,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night");
ReefAngel.LCD.DrawOutletBox(12, 97, TempRelay);
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.MHLights(Port1);
ReefAngel.MHLights(Port2);
ReefAngel.StandardHeater(Port3);
ReefAngel.StandardHeater(Port4);
So "Constant" should be "Constant " and "Lagoon" should be "Lagoon ".
Yeah i like the date and time at the bottombinder wrote:One thing I noticed is that you will want to make all these strings the same length:The "Constant", "Lagoon", etc. should be the same length and if they are not, then you should pad them. Looks like "Short Pulse" is the longest at 11 chars.Code: Select all
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant"); else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon"); else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest"); else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,DefaultBGColor,50,30,"Short Pulse"); else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse"); else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night");
The reason for this is when you change the modes and go from a larger text string to a smaller text string, there will be "ghosting" occurring from the extra characters not being overwritten.Code: Select all
Thanks for pointing that out! So let me just make sure i understand, I should rather have all the vortech modes lined up in the code? (im not so savvy when it comes to coding and terms used, what is padding? the gap between the end of the word and the quotations? )
E.G:
"Lagoon "
"Constant "
"Reef Crest "
Secondly, you say you want to change the layout of what is displayed? Do you not like having the 3 rows of 2 columns in the middle? Does that need to be changed for you?
I like the 3x2 layout, just would like to be able to change the paramaters viewed to something like this:
Ariel's Reef
Vortech : Reef Crest
Temp 1: 26 PH: 8.3
White : 70% Blue: 20%
ATO level : 65% etc
(ATO level will get its data from the pressure sensor)
Did you still want the date to be at the bottom of the screen? If not, you just need to remove this line:from the DrawCustomMain() function and the date will no longer be displayed.Code: Select all
yes, the gap between the end of the word and quotation mark. the padding is simply just spaces. so count the letters and use spaces to fill in the extras like i mentioned.Thanks for pointing that out! So let me just make sure i understand, I should rather have all the vortech modes lined up in the code? (im not so savvy when it comes to coding and terms used, what is padding? the gap between the end of the word and the quotations? )
E.G:
"Lagoon "
"Constant "
"Reef Crest "
the 3x2 layout you like will have to be created manually with copying and updating the function that displays it. i can help with it later tonight or tomorrow when i get home and can have access to a keyboard and look things up better with formatting. you can look at the DrawMonitor function inside the nokialcd.cpp file to get an idea.I like the 3x2 layout, just would like to be able to change the paramaters viewed to something like this:
Ariel's Reef
Temp 1: 26 PH: 8.3
ATO level : 65% etc
// Draw the custom monitor, function listed below
DrawCustomMonitor(15, 60);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant ");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon ");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest ");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse ");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night ");
void DrawCustomMonitor(byte x, byte y) {
// To change the column (move it right or left), you will need to adjust the value for X
// The Labels start at X and the values for them start at X+18.
// If you have to move them farther right (making 18 a larger number), you will need to adjust the values for X below for the second column.
// The 2nd column labels start at X+60 and the values start at X+78
// left column - top item
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,x,y,"T1:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], T1TempColor, x+18, y,10);
// left column - middle item, White LED is on DP Channel
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x,y+10,"White:");
// you may have to move the value farther to the right
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+18, y+10,1);
// left column - bottom item
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x,y+20,"ATO Level:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.WaterLevel.GetLevel(), T3TempColor, x+18, y+20,0);
// right column - top item
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,x+60,y,"PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, x+78, y,100);
// right column - middle item, Blue LED is on AP Channel
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+60,y+10,"Blue:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+10,1);
// right column - bottom item (not used)
//DrawText(APColor,DefaultBGColor,x+60,y+20,"AP:");
//DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+20,1);
binder wrote:Ok, here's some code for you based on what you were wanting. I added comments to it and cleaned up things as well (I fixed the spacing issue). Here's the DrawCustomMain function as well as a helper function for drawing your custom monitor box. So just copy and paste these 2 functions into your INO file and replace the existing .
//Custom Main, Graph & Menu
byte x = 6;
byte y = 2;
byte t;
char text[7];
static byte vtechmode=0;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,30,"pH");
ConvertNumToString(text, ReefAngel.Params. PH, 100);
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,68,"Sump");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 40, 68, 10);
ReefAngel.LCD.DrawText(0,255,70,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 99, 68, 10);
Yes, using this part of the coding.DrewPalmer04 wrote:That will display the mode your mp40 is running? Only if you're controlling it via the RF module? The RA sets the mode and then that code displays it on your custom main. I hope you have the RA+ or you'll run out of space quickly.
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 4);
ReefAngel.LCD.DrawLargeText(0,255,10,16," WP40 Mode:");
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,27,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,26,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,26,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,26,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,26,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255,45,26,"Night");
ReefAngel.LCD.DrawLargeText(0,255,17,49,"Sump");
ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
ReefAngel.LCD.DrawLargeText(0,255,100,40,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 55, text, Num8x8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,89, "WP40L");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,20,100, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,88,89, "WP40R");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,100, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawOutletBox(12, 113, TempRelay);
