Page 5 of 5
Re: Wifi Periodically Stops Responding
Posted: Mon Sep 17, 2012 7:58 pm
by 00Warpig00
Posted: Mon Sep 24, 2012 8:24 am
by ramst2
00Warpig00 wrote:Anyone try the 2.3.6/2.4.2/2.4.5 firmware updates yet?
Login: rovin
Password: Pass123
Your login and password does not work. Where do i have to register to download from rn.microchip
Posted: Mon Sep 24, 2012 8:38 am
by ishtak
Read this page on how to change the ftp server. Firmware version 2.4.5 is only for use on a non Ad-Hoc network. If you are connecting the device up to a standard wifi installation then you need to stick to 2.3.6
http://www.rovingnetworks.com/FAQs/How_ ... ft_AP_mode
Posted: Mon Sep 24, 2012 8:40 am
I think it is this:
login: Roving
Pass: Pass123
Posted: Fri Dec 21, 2012 3:01 am
by Appleseed
ishtak wrote:Read this page on how to change the ftp server. Firmware version 2.4.5 is only for use on a non Ad-Hoc network. If you are connecting the device up to a standard wifi installation then you need to stick to 2.3.6
I read this as the code changes from supporting ad hoc to soft ap mode in 245 but still supports connecting to standard access points (infrastructure mode).
Posted: Wed Apr 17, 2013 9:43 am
by Reddy
If by some unfortunate circumstance your unit gets upgraded to version 4.00, you have to reset auto join. It's in the manual, but here are the commands:
The 4.00 firmware breaks the memory tab in the RA Client. That was the only problem I noticed, but I didn't run it long.
The unit saves a couple of old firmware images and you can choose which one to boot from with the command "boot image <FL#>". Find FL# in the file listing.
<4.00> ls
FL# SIZ FLAGS
2 20 3 WiFly_GSX-2.32
22 11 3 wps_app
33 1 10 config
34 1 3 wifly-GSX-400
35 1 3 wifly-GSX-400
36 1 10 user
54 13 3 wps_app
164 Free, Boot=34, Backup=2
boot image 2
save
reboot
factory RESET
Then you can start over with normal setup. If the unit doesn't join, resend the "set wlan join 1" command from above.
Posted: Thu Apr 18, 2013 7:31 pm
Reddy wrote:If by some unfortunate circumstance your unit gets upgraded to version 4.00, you have to reset auto join. It's in the manual, but here are the commands:
<4.00> ls
FL# SIZ FLAGS
22 11 3 wps_app
33 1 10 config
36 1 10 user
54 13 3 wps_app
boot image 2
save
reboot
factory RESET
Man, I gotta say "Thank you, Thank you, Thank you" for posting this here today!!!
I'm so glad you did... I would have spent several hours trying to figure this out.
I'm just programming some new wifi modules I got and the minute I couldn't connect anymore, I immediately remember your post and sure enough... Got connection
This new 4.0 firmware is awesome for setting up your wifi!!!
I'm going to be updating the thread on how to set up the wifi... These new modules are going to make connecting to wifi so much easier for new users.... You have no idea
Posted: Mon Apr 22, 2013 12:01 pm
by Reddy
rimai wrote:Man, I gotta say "Thank you, Thank you, Thank you" for posting this here today!!!
Glad I could help!
The info was on page 7 of the manual, but instead of being in a bright red box titled "BIG CHANGE FROM HOW WE USED TO DO THINGS", it just says in plain old text, "hope you notice this before you bang your head against it for too long!"
Posted: Mon Jul 01, 2013 1:40 pm
by brettb
Hey guys.
I'm also having the issue where my wifi attachment looses connection (blue led flashing) after a day sometimes a few days. Has a solution been found for this?
Posted: Tue Jul 02, 2013 4:41 am
by cjrudy
brettb wrote:Hey guys.
I used to have this problem constantly and always thought it was firmware related. Added the external antenna and have not had a problem since.
http://forum.reefangel.com/viewtopic.php?t=1866
Posted: Tue Jul 02, 2013 5:50 am
by dbmet
I had the same problem. I reset the wifi module to factory defaults, loaded the latest 4.0 firmware, reloaded the code on the controller, and added the external antenna which I really think helped the most.
Posted: Tue Jul 02, 2013 7:11 am
I was getting a lot of interference from my 2.4ghz baby monitor. Updated to 4.0 and no more issues.
Posted: Wed Jul 03, 2013 10:36 am
by avionixx
I'm still not having any luck with my WIFI module, it disconnects randomly and won't reconnect. I've tried all of the methods recommended by others in various threads:
- Update to latest firmware (it already came with the latest)
- Set linkmon to 30 or 50
- Assign static lease to Wifi module
- Set router to use WPA2 only (it was set to mixed before)
I don't know if it just doesn't like my router or what; I'm lucky if it stays connected for a week.
Posted: Wed Jul 03, 2013 11:20 am
For $12 I think, I recommend trying the antenna modification.
Posted: Thu Jul 04, 2013 6:57 am
by Poiromaniax
avionixx wrote:I'm still not having any luck with my WIFI module, it disconnects randomly and won't reconnect. I've tried all of the methods recommended by others in various threads:
I had a similar problem, turns out it was a faulty module.
Maybe ask Roberto? (Rimai)
Posted: Thu Jul 04, 2013 3:03 pm
by avionixx
Yeah what makes it strange is that the module is doing the slow blink green as if it's connected, but can't be pinged and isn't transmitting data from the controller. It has to be disconnected from the controller for a few seconds and then reconnected before it'll start working properly again.
Posted: Thu Jul 04, 2013 6:27 pm
by thekameleon
I get this issue once in a while myself.
