Page 5 of 5
Re: Coding Pwm module.
Posted: Tue Jun 05, 2012 10:42 am
by abhi_123
Bump.
Posted: Tue Jun 05, 2012 10:48 am
Did you confirm the drivers are working properly?
Posted: Tue Jun 05, 2012 10:57 am
by abhi_123
Drivers output is ok. I am facing strange problem. When i am using potentiometer or pwm to dim they are getting dim but leds are flashing even i disconnect dimming cable on 100%
Posted: Tue Jun 05, 2012 11:03 am
Maybe you have a bad driver then.
Did you try talking to the manufacturer?
Posted: Tue Jun 05, 2012 11:08 am
by abhi_123
Not yet. I have one little doubt want to clear it before i asked the manufacturer. My driver dimming output is 10v when i am testing it without putting any load on it. Is it ok or should it gives zero reading?
Posted: Tue Jun 05, 2012 11:13 am
Not sure.
I would think that a driver with no load would not do anything.
Posted: Tue Jun 05, 2012 2:45 pm
by Sebyte
I am a little confused are there two threads running on this topic.
I see that you are using LED strips, which are a new product on the Aquastyle site and I have no experience with them, so I can only generalize.
Which driver are you using? I think you said you have the MeanWell LPF-60D-48
The Aquastyle site looks like they use the Maxwellen LED Dimmable Drivers with the LED strips.
If you are using the MeanWell LPF-60D-48 I can only guess that you have a miss match, and you don't have enough LEDs to provide the right load balance for the MeanWell LPF-60D-48.
I would suggest that you contact the supplier and get their advice.
Posted: Wed Jun 06, 2012 8:36 am
by abhi_123
fixed the prob today. these strips are little bit different from the traditional leds.
