Page 5 of 7
Re: Time for additional Ethernet add-on with PWM output
Posted: Thu Jan 31, 2013 12:23 pm
by DrewPalmer04
lnevo wrote:Real NTP you give multiple nodes and both times are compared and sync'd accordingly. Maybe you should adapt that approach rather than primary / backup.
Good plan. I'll see which is easier lol
Posted: Thu Jan 31, 2013 2:39 pm
by DrewPalmer04
NTP primary and failover/backup server implemented. Edited code on page 12 of thread.
Posted: Thu Jan 31, 2013 3:54 pm
DrewPalmer04 wrote:Then they will just have to adjust the off set for -6, -4 etc
You could just split the difference...
Posted: Thu Jan 31, 2013 4:07 pm
by DrewPalmer04
I'm not sure anyone will even use this code or module. But I figured it was worth posting. I've got the backup NTP server in the code. Which reduces odds of NTP time failure. Might add a few more to completely remove the possibility
Posted: Wed Feb 13, 2013 10:03 am
by DrewPalmer04
Roberto: One last thing I would like to do...
Any way for the ethernet module to send a PWM percentage to make the portal "think" it is a Radion value? I would like the percentage to display on the portal under "Red" for PWM pin 9 value and "Green" for pin 6 value.
I've tried to think of ways to accomplish this, but I'm coming up short
Thanks as always!!
P.s. the code has change a bit versus page 12 of the thread..but it's basically still the same as what you see on page 12 at the top.
Posted: Wed Feb 13, 2013 12:15 pm
You need to do that in the main unit for it to work.
Posted: Wed Feb 20, 2013 9:27 am
by DrewPalmer04
CODE UPDATE:
Corrected code for potentiometers to override PWMParabola to allow for manual dimming of pin 9 and pin 6.
Return both potentiometers to "0" to have PWMParabola take back over...
Posted: Wed Feb 20, 2013 11:15 am
by DrewPalmer04
Also looking for suggestions/improvements/thoughts. If you have implemented this let me know too!!!
Posted: Fri Feb 22, 2013 7:29 am
by DrewPalmer04
I've been playing with the idea of how to send info from one arduino to the RA. I'll use the serial communications. I need to send a BYTE and then have the RA receive the byte incomingbyte incomingbyte=Serial.read();
But here is where I'm coming up short. What do I do with the byte once it is read? How do I get this to replace the "0" on RFR and RFG (radian values). of course I'll have different bytes of info for each.
Also, related to this thread:
I've gotten a Chinese version of the Uno/Ethernet combo. It is working great thus far and is a CHEAPER option for everyone at $25 (shipping included) versus $60(+or-) +shipping for the one I've been using so far. Super easy to patch the wifi cable into it FYI.
Posted: Fri Feb 22, 2013 8:24 am
SetChannel(byte channel, byte value) seems to be the function to write your byte to whichever radion channel you want. The rest of the functions in the RF class are for setting slopes.
Posted: Fri Feb 22, 2013 8:47 am
by DrewPalmer04
hmmm...so in theory. I write the received byte to SetChannel() and it'll display on the portal? This is me trying to "fool" the portal after all to know my % of brightness off my ethernet module lol...I'd just prefer to know my % values at a glance versus Serial.print() I have to use now.
Posted: Fri Feb 22, 2013 11:07 am
Yeah, it should set the channel even though nothing is written there.. Theoretically, there may be other code in the way that Im not aware of.
Posted: Thu Mar 14, 2013 8:40 am
by DrewPalmer04
Updated page 12 to include the link to the build list/materials needed.
Posted: Thu Mar 14, 2013 8:43 am
Posted: Thu Mar 14, 2013 8:47 am
by DrewPalmer04
Hey, thanks...it's been updated!
Posted: Thu Mar 28, 2013 10:39 am
by DrewPalmer04
Sorry losing my mind....
Updated page
12 of thread.
Posted: Thu Mar 28, 2013 11:30 am
Which thread? what did you update?
Posted: Thu Mar 28, 2013 11:33 am
by DrewPalmer04
EDIT:
I should have been more clear...
Security option issue with the portal and Ethernet module. It
must [<--Not 100% true] be disabled. That's all I added
I don't use security....but anyone can add this to the RA side of the code...
Use below for security option (IF needed):
ReefAngel SIDE
"key" must match on code and portal
ReefAngel.Portal("username","key");
Posted: Tue Apr 09, 2013 5:07 pm
by topjimmy
I have been using this for a few weeks and it really does work well. I am having a problem with the pwm for my Leds. They light up fine, but they flash, it's so fast that I thought it was just glimmer at first. I am using steve's led drivers. They work fine straight off of the RA dimming. Any suggestions?
Posted: Tue Apr 09, 2013 6:10 pm
by DrewPalmer04
Sounds like you don't have enough LEDs in the string. The driver is "protecting" itself. Either reduce the mA output from the driver or add more LEDs. That's what it sounds like to me
Posted: Tue Apr 09, 2013 6:46 pm
by topjimmy
can't be that. They work fine off the RA, and the drivers are maxed out as far as capacity.
Posted: Tue Apr 09, 2013 6:52 pm
by DrewPalmer04
Could be that you need an opamp to boost from 0-5vdc to 0-10vdc. Roberto posted a circuit for how to do it
Posted: Tue Apr 09, 2013 6:57 pm
by DrewPalmer04
Or make sure they don't send more than 40mA to the arduino. I don't use Steve's so I'm not sure.
Posted: Tue Apr 09, 2013 7:09 pm
by topjimmy
DrewPalmer04 wrote:Could be that you need an opamp to boost from 0-5vdc to 0-10vdc. Roberto posted a circuit for how to do it
That might be it. I wonder what he uses for the relay that makes it work.
Posted: Tue Apr 09, 2013 7:22 pm
by DrewPalmer04
Lm358 opamp. Two 10k resistors make a gain of 1.
Posted: Wed Apr 10, 2013 7:09 am
by topjimmy
The drivers I am using will work straight off an Arduino pwm. In fact they can even supply +5v to power the board. I think it is either some sort of noise induced from the power supply, or the pwm freq. is too low?
Not sure.
Posted: Wed Apr 10, 2013 7:31 am
by DrewPalmer04
Try to remove this line or //comment it out:
bitSet(TCCR1B, WGM12); //force fast PWM
And check this page out:
http://arduino.cc/en/Tutorial/SecretsOfArduinoPWM
Posted: Wed Apr 10, 2013 9:57 am
by topjimmy
Commented out, same problem. There must be something causing it.
Posted: Wed Apr 10, 2013 9:59 am
If I remember correctly, Steve's drivers accept 0-5V PWM too, doesn't it?
Can you describe or post a video of such flickering effect?
Do you have access to a scope to check the signal?
Posted: Wed Apr 10, 2013 10:22 am
by topjimmy
No, scope available. The drive does except 0 - 5v pwm. I can record it, but it looks like a strobe light a very fast flicker with no perceived off.
