Page 5 of 12
Re: Did someone say iPhone app?
Posted: Thu Oct 27, 2011 3:17 am
by wolfador
Yes it is 24hr time, I will make it more clear in the next update.
Posted: Thu Oct 27, 2011 3:19 am
by Xender
Good!
It would be great to have the possibility to add custom menu as "Feeding Mode" button.
Posted: Sat Oct 29, 2011 8:18 am
by dedvalson
Hi,
I downloaded the new iPhone app and got the latest development libraries this morning.
There appears to be a problem with the new Mode buttons.
Pressing either "Feeding Mode" or "Water Change" on the iPhone app puts the RA into "Water Change" mode. I verified this by looking at the front panel of the RA controller.
I tried sending the /mf and /mw commands manually with my browser and they worked properly.
Don
Posted: Sat Oct 29, 2011 4:42 pm
by wolfador
sorry bout that, both buttons were linked to the waterchange. Just submitted a bug fix to Apple. Hopefully we get the same turn around as last time and it is available tomorrow. I will let you know.
Thanks again for finding that.
Posted: Mon Oct 31, 2011 10:18 am
by wolfador
Update was approved and should be available.
Posted: Tue Nov 01, 2011 7:51 pm
by wolfador
Did a fairly quick conversion to iPad and submitted it to Apple. This one will be called ReefAngel-HD. I think we can make nice use of the larger real estate on the iPad to do some cool things so this is currently just a clone of the iPhone with the UI tweaked to support vertical / horizontal screen.
Posted: Wed Nov 02, 2011 12:26 am
by Francois
Hi
Thanx for the great work, would it be possible if we can edit the temp. names in the application like you would edit the Realys names in settings. As it is on Water, Room1, Room2 by defualt in My Tank.
Thanx
Francois
Posted: Wed Nov 02, 2011 7:41 pm
by wolfador
Francois wrote:Hi
Thanx
Francois
just finished adding this in, will be in next update, probably early next week.
Posted: Wed Nov 02, 2011 10:11 pm
by Francois
wolfador wrote:
Francois wrote:Hi
Thanx
Francois
Cool Man :D
Keep up the great work
Francois
Posted: Thu Nov 03, 2011 1:13 am
by Xender
Hello!
binder wrote:
  • Switched to use HttpURLConnection, allows for read and connect timeouts
  • Added connect & read timeouts to host class
  • Added ability to enter in userid for web banner on reefangel.com
  • Added ability to choose to query controller directly or reefangel.com for values
Can you add the same features? :roll:
Posted: Thu Nov 03, 2011 7:52 pm
by wolfador
I added in the ability to pull the temp/relay names from the web banner. so instead of having to type them in manually it will grab them from there. Saves a bit of time.
Posted: Mon Nov 07, 2011 12:09 pm
by wolfador
ReefAngel-HD for iPad was just approved, should be available in the App Store soon.
Posted: Sun Nov 20, 2011 12:12 pm
by Cruzer
Hello,
So is the DYN email server thing a paid service? I have registered with the site and do not have a problem paying a small fee for this APP to work, but wanted to check and see before buying a years subscription to the site.
Posted: Sun Nov 20, 2011 2:17 pm
Posted: Sun Nov 20, 2011 4:06 pm
by Cruzer
Chris, first thing you want to do is go to http://www.dyndns.org, create a new account and setup a new hostname. By doing this, you will create a new host address. Something like "chris.dyndns-remote.com". What this will do is bind the chosen host address (chris.dyndns-remote.com) to your IP address that your ISP will give to you. This gives you a way to access your home network outside of your home.
When you start to set up one of these accounts they ask you for an IP address, right below it they show your current IP address, do I use that one, or do I need to contact my cable provider to get a different one?
Posted: Sun Nov 20, 2011 4:30 pm
by Sebyte
Just use the one you see, the DYNDNS service will take care of the rest.
Posted: Sun Nov 20, 2011 6:39 pm
by Cruzer
Okay,
I have the WiFi adapter configures with the computer as the tutorial stated. I have a domain with Dyndns. I have gotten into my router and set up the DDNS to reflect the domain. I think I need to find the WiFi adapter on the network now but I have several things on the network and I do not know which one is the adapter. Do you know what the generic name that is wouldshow as?
Posted: Sun Nov 20, 2011 6:41 pm
Should show as Wifly
Posted: Sun Nov 20, 2011 6:52 pm
by Cruzer
Thanks, do not see anything like that. It is connected to the controller and is doing the slow green blink. Maybe it is not on the network? I do not remember configuring it onto the network. Will keep working it. The other stuff is all working great, thank you for all the help Roberto.
Posted: Sun Nov 20, 2011 6:58 pm
Cool.
Let me know when you feel everything is working as expected and we can go and start coding the Kalk stuff.
Slow green blink is good. It means it is connected to your network.
Did you use the wifi graphical utility to setup the wifi attachment?
You can use it again and click the button "View wifi settings" to see which ip address it picked up.
Posted: Sun Nov 20, 2011 7:06 pm
by Cruzer
I used the wifi graphical utility to set it up. I will run it again and see. I am just trying to get the controller steady for now. Would like to get the remote monitoring done since I am going out of town for a few days next week. Not going to start a dosing other than ATO till I am back and can be around if something goes wrong.
Posted: Sun Nov 20, 2011 7:22 pm
by Cruzer
When I try to run the graphical utility again it will only let me choose comm port 1. When I set up the controller it was on com port 3. Now when I do things following the directions in the utility nothing gets sent to the wifi adapter. It still sits there blinking the green light though.
Posted: Mon Dec 19, 2011 3:56 pm
by Ace25
Is there a reason this requires IOS 4.3? Is there something in 4.3 that makes this work? Reason I ask is I have an iPod Touch 2nd Gen, works fantastic, but I just learned Apple doesn't support it any longer and the last IOS I got on it was 4.2.1. I can't go any higher. This is the first App I have tried to download that said "No, 4.3 is required". Kind of.. actually, extremely bummed out that I can't use this, been looking forward to something like this for over a year now.
Posted: Mon Dec 19, 2011 7:35 pm
by wolfador
Ace25 wrote:Is there a reason this requires IOS 4.3? Is there something in 4.3 that makes this work? Reason I ask is I have an iPod Touch 2nd Gen, works fantastic, but I just learned Apple doesn't support it any longer and the last IOS I got on it was 4.2.1. I can't go any higher. This is the first App I have tried to download that said "No, 4.3 is required". Kind of.. actually, extremely bummed out that I can't use this, been looking forward to something like this for over a year now.
There are a number of things that require 4.3. I can try and build you a custom one that would work on 4.2, might take me a bit as I am currently working on a big update.
Posted: Tue Dec 20, 2011 8:57 am
by Ace25
You don't have to do that. I was more curious if there was actually anything in the App that required 4.3 in order to work or if this was just Apple's way of making an older/working product instantly obsolete.
I just discovered I have many other apps that have now been "updated" and require 4.3 just to install (tells you how long I updated my iPod, Apple stopped supporting 2nd Gen iPods March 2011 and I just discovered this when I tried to download your App), even though I paid for them years ago and they work fine. I know those apps/games have nothing that requires 4.3 on those, but I had no idea about your App which is why I asked. If your app uses features that 4.3 provides I will just have to bite the bullet and get a new Apple product. I was waiting for the iPod Touch 5th Gen to come out but I still do not see a release date for them so I may have to grab a 4th gen. Thanks for the reply.
Posted: Tue Jan 17, 2012 2:57 pm
by serhiyi
Does this work with WiFi Authentication? I saw some posts about issues, but not sure if that was resolved.
I was testing app inside the house with local IP and it works. But I want to be able to access controller from anywhere using phone (android). Before setting up router to handle redirect I added security to controler.
I'm able to use access by 192.168.1.100:2000/wifi and it asks for user and password. Works great.
Now with my iPad I can't access controler from app. It was working great untill that one line of code for wifiauthentication.
My code:
    WifiAuthentication("ra:test");
    ReefAngel.SetTemperatureUnit(0);
    ReefAngel.PWM.SetActinic(0);
    ReefAngel.PWM.SetDaylight(0);
It does not even ask for user and password. Am I missing somehting?
Posted: Wed Jan 18, 2012 6:31 am
by wolfador
The wifi authentication is changing in the upcoming library release so it was not added into the iPad app.
Posted: Sun Jan 22, 2012 11:34 am
by Cruzer
I have the app working and it is great, thank you for all your work. Is it possible to have the app display the same information but not be able to change anything, just monitor? I ask because my Daughter is a great help with the tank and would be great if I could put the app on her phone also but not allow her to make any changes to anything.
Posted: Sun Jan 22, 2012 3:23 pm
by wolfador
currently there would not be a way to do that. If there is enough interest I can make a display only version.
Posted: Sun Jan 22, 2012 3:33 pm
I thought you had implemented pulling data from webbanner too, didn't you?
