To give you a idea, this is the code EXACTLY as I will upload it to the PWM module now
//By Matthew Hockin 2012.
//SWFLTEK library functions, #includes, and #define were copied directly from the Epherma library
//Epherma (SWFLTEK.com) was written by Michael Rice- thanks Michael it works great.
//If you copy from this (its all open source) please
//acknowledge Michael for SWFLTEK library code (obviously labeled) or Matthew Hockin (for the rest).
//You MUST have installed the SWFLTEK Ephmerma library- this library was written by Michael Rice (swfltek.com)
//its source code and distribution rights are stated in the .h file - Thanks to Michael for doing such a great job
#include <avr/wdt.h>
#include <stdlib.h>
#include <math.h>
//***********************************ARRAYS YOU MUST MODIFY TO MAKE YOUR TANK SET UP WORK*********************
//CHANGE this to the number of seconds your time zone is offset from GMT (WITHOUT REGARD TO DAYLIGHT SAVINGS TIME)
int GMToffset=0;//USA MST time zone is 25,200 if that helps you
//GLOBAL Variables YOU NEED TO CHANGE
boolean ApplyDST=false;//CHANGE THIS IF YOUR NOT USING DST
byte ChMax[]={225,225,225,225,225,0,0,0};//Incremental value (Max-flicker) above flicker you want as max intensity-
byte flicker[]={30,30,30,30,30,30,0,0};//need to input actual values here for flicker point on all channels in PWM expansion box
boolean Wchannel[]={1,1,1,1,0,0,0,0}; //use 1 to designate white channel (i.e. off during storm and used for lightning). Array corresponds to PWM channel 0-5 in order
//Array to give direction to dimming. e.g. DimOrder[]={0,0,1,1,0,0} (cloud chase effects, just group channels you want to dim together during a cloud or storm
//(which is zero or 1 will change who dims first). set them all to 0 if your tank has no left/right or front/back lights.
byte DimOrder[]={0,1,0,1,0,0,1,1};
//**********************************DONE CHANGING THINGS HERE BUT YOU MUST CHANGE ChOffset array IN CalcSUN function******
// arc-seconds per radian
#define _sec_rad 206264.806247096370813
// axial tilt of earth at epoch, in radians
#define _tilt 0.409092804222329
// tropical year in seconds... rounding error accumulates to 26 seconds by the year 2136
#define _tropical_year 31556925
// 'zenith' of rising (setting) sun in radians (360 - 2 * 90.833 degrees)
#define _zenith 3.11250383272322
//Unless your planning on editing the program DO NOT CHANGE ANYTHING HERE
long latitude, longitude;
byte TrueIntensity[8];//array used to place hold values calculated by insolation
long elapsedTime;//used multiple places as elapsed since new day.
//Globals Vavriables for ReefAngel PWM Cloud, PWM Settings, Epherma Lat/Long Sunrise/Sunset
unsigned long rise;//time in seconds from midnight for sunrise today
unsigned long set;//time in seconds from midnithgt for sunset today
unsigned long newDay;// time in seconds since 2000 adjusted for DST (if used) at a new day (12:00:00am)
long CloudMaster[20];// Set up array to hold start and end times for clouds for the day- dont size it dynamically make it big enough for any day
long midDay;// exactly 1/2 way between rise and set, i.e. my take on solar noon- which its not...
byte PWMports[] ={
3,5,6,9,10,11};
byte ChannelValue[8];// Array to store current setpoint for PMW control of output to ch (0,1,2,3,4,5)
byte cmdnum=255;
byte datanum=255;
byte dow=0;//day of week
boolean trigger; //used a few places as a switch to ensure things only run 1x when needed trigger 2 is for daily reset of sunrise sunset
boolean isDST;//are we in DST
boolean InsolationAdvance;//when true we recalculate light intensity during clear sky
//END HEADER/Global Variable declaration//
//Setup
void setup(){
Serial.begin(57600);
Wire.begin(8);
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
wdt_enable(WDTO_1S);
randomSeed(analogRead(0));//start random generator at a different point each time (not perfect but whatever its gonna be pretty damn random)
isDST=false;//set day light savings time correction to false, is overridden by DST function if you choose to use it
//End Setup
//Loop
void loop(){
wdt_reset();
if (cmdnum!=255){
ProcessCMD(cmdnum,datanum);
cmdnum=255;
datanum=255;
if (dow!=day()){ //be aware that during DST times the new day calculation will occur 1 hour early....but its corrected out
trigger=true;//on reset this will also be true as numbering is 1-31 max
//Serial.println("We set trigger to true");
dow=day();//now set dow to actual day numbering so that at midnight/new day we again calc sunrise sunset
//this will ensure at least minimally 1 sec intervals but may be longer if program is slow during a long calculation but at least never shorter.
if ((millis()-lastmillis)>=300){
counter+=1;
StormAdvance=true;
if (counter==0) InsolationAdvance=true;//so that it runs on start up to provide light immediately
if (counter%10==0){
//Serial.println (elapsedTime);
if (counter==230) counter=0;
// now run through rise/set calculation and then intensity set and finally weather overlay when required
if (trigger==true) CalSun();
if (InsolationAdvance==true) Insolation();
Weather();//due to variable storm vs cloud update timing this must be run from loop without condition
if (StrikeNow==true){
byte intensity;
intensity=random(150,256);// this little bit should generate a randomly bright flash variation between the series of flashes in StrikeMaster
for (byte b=0; b<6; b++){
if (Wchannel[b]==1) analogWrite(PWMports[b],intensity);// set all whites to whatever random intensity was generated
if (StrikeCount==(StrikeNumber-1)) StrikeNow=false;
//track time in seconds-dont move this part up in the loop it really should stay below the rest as DST is not calculated until CalSun is run 1 time.
elapsedTime=((now()-946684800)-newDay);//this is uncorrected for DST, the ONLY thing that is, since its all relative... is the actual sunrise and set seconds
//Now that we have generated our sun pattern, Weather as clouds, and possibly a storm, and possibly lightning each of which override the prior channel setting
//lets actually make some light.
for (byte a=0;a<6;a++){
//End Loop
//Standard PWM Functions Receive/Process
wdt_reset();
if (howMany==5){
cmd1=Wire.read();
cmd2=Wire.read();
cmd3=Wire.read();
cmd4=Wire.read();
cmd5=Wire.read();
cmdnum=cmd4;
datanum=cmd5;
//Serial.println(cmd4,DEC);
//Serial.println(cmd5,DEC);
else{
for (int a=0;a<howMany;a++){
Wire.read();
wdt_reset();
//End Standard Functions
void CalSun(){
trigger=false;
// Every day at midnight, we calculate rise, set, time of highest sun, moon phase, or we do this if system has reset
if (ApplyDST==true){
CalcDST(day(),month(),weekday());
//Calculate Latitude and Longitude converting from Degree, Minute, Seconds to decimal
latitude=dmsToSeconds(-25,87,13); //Set to about the latitude of Salt Lake City
longitude=dmsToSeconds(29,23,32); //Set to Salt lake City, or MST zone, USA or there abouts- actually the AT921 remote weather station in Salt Lake City UT. Random web grab.
unsigned long SecInput;//intermediate variable to set rise and set input times
unsigned long hours;//avoid casting and use UL
unsigned long minutes;//avoid casting and use UL
time_t t=now();
hours=hour(t);
minutes=minute(t);
//Serial.println("Hours:Mins");
//Serial.println(hours);
//Serial.println(minutes);
//Serial.print("CalSun now()=");
//Serial.println(now());
//Using time library from Arduino.time_t now(); returns seconds since 1970 in local time with NO DST correction
//Arduino Time.h Library states #seconds to subtract to bring to Jan 1 2000 as origin for time is
//#define SECS_YR_2000 (946684800) the time at the start of y2k
//Seems weird, but actually DO NOT correct new Day for DST
hours=(hours*3600);//seconds conversion saving a variable
minutes=(minutes*60);//seconds conversion saving a variable
newDay=(now()-(946684800+hours+minutes));//local time uncorrected for DST- hours and minutes were just converted to seconds in prior step
SecInput=(newDay+GMToffset);
rise=SecInput;// Dont screw with DST in sunrise sunset input its NOT part of GMT
set=SecInput;//were not converted yet- library uses POINTERS.. to modify these values
//Calculate rise time and set time using Epherma Library
SunRise(&rise);//call to Epherma Library using reference- memory is modified by Epherma
SunSet(&set);//Call to Epherma library using reference- memory position is modified by Epherma
if (isDST==true){//must correct DST NOW by subtracting 1 hour from the offset (i.e. clocks are 1 hr ahead and thus closer to GMT)
rise=(rise-(GMToffset-3600));//during DST rise is 1 hour earlier than calculated i.e. clocks ahead 1 hour 6 am occurs "at 5am" if that makes sense
set=(set-(GMToffset-3600));
else if (isDST==false){
rise=(rise-GMToffset);
set=(set-GMToffset);
//Serial.print("newDay=");
//Serial.println(newDay);
rise=(rise-newDay);//set to elapsed seconds today
set=(set-newDay);
Serial.println("Local Elapsed Seconds from NewDay--rise=");
Serial.println(rise);
Serial.println("Local Elapsed Seconds from NewDay--set=");
Serial.println(set);
//DONT MOVE THIS LINE ABOVE FINAL rise and set decleration it will SCREW up your rise and set during DST by 1 hour
if (isDST==true) newDay-=3600;//subtract an hour from the time that will be subtracted from GMT i.e. were one hour closer during DST
//*********************UNLESS YOUR TANK LIGHTING IS IDENTICAL IN EVERY WAY TO MINE----YOU NEED TO CHANGE THESE VALUES***************************
int Choffset[]={
900,-3600,1800,-2700,2700,-1800,3600,-900,0,0,0,0,0,0,0,0,0};
//**********************ok now were done changing things here********************************************
midDay=(((set-rise)/2)+rise);
//Serial.print("MidDay");
//Serial.println(midDay);
if (b%2==0){
ChRiseSet[b]=rise+(Choffset[b]);
ChSlope[b]=(deltaY/(float)(HalfDayLength-(Choffset[b])));
//Serial.print("Rise/Set a=");
//Serial.println(b);
//Serial.print("Value=");
//Serial.print(ChRiseSet[b]);
//Serial.print("Slope");
//Serial.println(ChSlope[b], 12);
else if (b%2==1){
ChRiseSet[b]=set+(Choffset[b]);
ChSlope[b]=(deltaY/(float)(HalfDayLength+(Choffset[b])));
byte CloudChance=0;//% Chance of a Cloud every day
//once a day, after rise set has been calculated and populated we need to trigger a reset to the Cloud time calculation loop
byte RainMaker=random(1,101);
if (RainMaker<=CloudChance){
//Serial.print("no cloud today");
return;
// to "simplify" things and avoid redundant calculation loops all cloud times are in fraction of day lengths
//*********** this is only executed 1x /day unless power outage and ONLY if last statement is true****************
///ALl cloud set up is done here... weather subroutine just implements it
/*The general strategy for this algorithim is as follows. Calculate random cloud cover as percent of day,
then randomly generate the # of discreet cloud instances for the day,
then determine cloud length by (daylight seconds * percent overcast)/#clouds
then randomize cloud lengths by splitting into groups of twos correcting for if we have odd # of clouds today*/
long dayLength=(set-rise);
//Serial.println("DayLength");
//Serial.println(dayLength);
byte CloudsMax=10;//DONT INCREASE BEYOND 11 or it will DIE, or increase array size to handle it
byte CloudsMin=4;//dont use 1 it may or may not work in the next loops and the cloud will likely be very long, i.e. daylength*overcast fraction
//Serial.println("CloudsTotal");
//Serial.println(CloudsTotal);
Overcast=(Overcast/100);
//Serial.println("Overcast");
//Serial.println(Overcast);
// set up start time for clouds
//The way this is done is to split the total lenght of time for clouds into equal segments and then to randomly chop or add time to the
//segments such that cloud length is variable. Then distribute into random parts of the day and fill array with start,duration pairs for clouds
int CloudLength;
float CloudFraction=0;
float SunFraction=0;
/*Serial.print("CloudLength=");
Serial.println(CloudLength);
Serial.print("SunSegment=");
Serial.println(SunSegment);*/
for (byte a=0; a<20; a++){
CloudMaster[a]=0;
if ((CloudsTotal%2!=0) && (a==((CloudsTotal*2)-1))){//if were at the last cloud in an odd cloud day make it full length
CloudMaster[a]=CloudLength;
else if (a%2==0){
if (b==0){
b++;
else if (b==1){
if (c==0){
c++;
else if (c==1){
//serial debugging to examine array
for (byte a=0;a<20;a++){
// now we have CloudMaster constructed as SunSegment,CloudLength,SunSegment,CloudLength....
//reframe it to generate cloud start, cloud end, cloud start, cloud end
else {
/*Serial.println("here is cloud master in is entirety as start and end pairs");
}//END SunCalc FUNCTION
void Insolation()
/*Serial.println("Insolation 3 sec elapsed");
Serial.print("Elapsed Time is=");
Serial.println(elapsedTime);*/
use flicker points to adjust minimum intensity to stable light. Turn off lights after set or before rise etc.
if (elapsedTime<=midDay){
//Serial.println("in first half of day");
for (byte b=0;b<16;b=(b+2)){
if (elapsedTime>=ChRiseSet[b]){
secSoFar=(elapsedTime-ChRiseSet[b]);//just account for length of every channel 1/2 day and switch at midDay
switch (b){
case 0:
ChannelValue[0]=flicker[b]+ChMax[b]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
//Serial.println(-cos(PiHalf+(ChSlope[b]*secSoFar)),4);
//Serial.println((float)ChMax[b],4);
//Serial.println(ChannelValue[0]);
break;
case 2:
ChannelValue[1]=flicker[(b-1)]+ChMax[(b-1)]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
//Serial.println(ChannelValue[1]);
break;
case 4:
ChannelValue[2]=flicker[(b-2)]+ChMax[(b-2)]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
//Serial.println(ChannelValue[2]);
break;
case 6:
ChannelValue[3]=flicker[(b-3)]+ChMax[(b-3)]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
//Serial.println(ChannelValue[3]);
break;
case 8:
ChannelValue[4]=flicker[(b-4)]+ChMax[(b-4)]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
//Serial.println(ChannelValue[4]);
break;
case 10:
ChannelValue[5]=flicker[(b-5)]+ChMax[(b-5)]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
//Serial.println(ChannelValue[5]);
break;
case 12:
ChannelValue[6]=flicker[(b-6)]+ChMax[(b-6)]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
//Serial.println(ChannelValue[6]);
break;
case 14:
ChannelValue[7]=flicker[(b-7)]+ChMax[(b-7)]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
//Serial.println(ChannelValue[7]);
break;
switch (b){
case 0:
ChannelValue[0]=0; //to enable moon phase lighting for any channel comment out this part and uncomment the next 2 lines
//ChannelValue[0]=MoonPhase(); //this is the after sunset part I told you to look for when you set the before sunrise moon phase channels
//if (ChannelValue[0]<flicker[0]) ChannelValue[0]=0;
break;
case 2:
ChannelValue[1]=0;
//ChannelValue[1]=MoonPhase();
//if (ChannelValue[1]<flicker[1]) ChannelValue[1]=0;
break;
case 4:
ChannelValue[2]=0;
//ChannelValue[2]=MoonPhase();
//if (ChannelValue[2]<flicker[2]) ChannelValue[2]=0;
break;
case 6:
ChannelValue[3]=0;
//ChannelValue[3]=MoonPhase();
//if (ChannelValue[3]<flicker[3]) ChannelValue[3]=0;
break;
case 8:
ChannelValue[4]=0;
//ChannelValue[4]=(MoonPhase()/2);
//if (ChannelValue[4]<flicker[4]) ChannelValue[4]=0;
break;
case 10:
//ChannelValue[5]=0;
ChannelValue[5]=MoonPhase()/2;
if (ChannelValue[5]<flicker[5]) ChannelValue[5]=0;
break;
case 12:
ChannelValue[6]=0;
//ChannelValue[6]=MoonPhase();
//if (ChannelValue[6]<flicker[6]) ChannelValue[6]=0;
break;
case 14:
ChannelValue[7]=0;
//ChannelValue[7]=MoonPhase();
//if (ChannelValue[7]<flicker[7]) ChannelValue[7]=0;
break;
else if (elapsedTime>midDay){
//Serial.println("were in the second half of the day");
for (byte b=1;b<12;b=b+2){
switch (b){
case 1:
ChannelValue[0]=flicker[(b-1)]+ChMax[(b-1)]*(-cos(Pi+(ChSlope[b]*secSoFar)));
//Serial.println(-cos(Pi+(ChSlope[b]*secSoFar)),4);
break;
case 3:
ChannelValue[1]=flicker[(b-2)]+ChMax[(b-2)]*(-cos(Pi+(ChSlope[b]*secSoFar)));
break;
case 5:
ChannelValue[2]=flicker[(b-3)]+ChMax[(b-3)]*(-cos(Pi+(ChSlope[b]*secSoFar)));
break;
case 7:
ChannelValue[3]=flicker[(b-4)]+ChMax[(b-4)]*(-cos(Pi+(ChSlope[b]*secSoFar)));
break;
case 9:
ChannelValue[4]=flicker[(b-5)]+ChMax[(b-5)]*(-cos(Pi+(ChSlope[b]*secSoFar)));
break;
case 11:
ChannelValue[5]=flicker[(b-6)]+ChMax[(b-6)]*(-cos(Pi+(ChSlope[b]*secSoFar)));
break;
case 13:
ChannelValue[6]=flicker[(b-7)]+ChMax[(b-7)]*(-cos(Pi+(ChSlope[b]*secSoFar)));
break;
case 15:
ChannelValue[7]=flicker[(b-8)]+ChMax[(b-8)]*(-cos(Pi+(ChSlope[b]*secSoFar)));
break;
switch (b){
case 1:
ChannelValue[0]=0;
break;
case 3:
ChannelValue[1]=0;
break;
case 5:
ChannelValue[2]=0;
break;
case 7:
ChannelValue[3]=0;
break;
case 9:
ChannelValue[4]=0;
break;
case 11:
break;
case 13:
ChannelValue[6]=0;
break;
case 15:
ChannelValue[7]=0;
break;
/*Serial.println("Insolation settings=");
Serial.println("ChMax Settings");
Serial.println(ChMax[0]);
Serial.println(ChMax[1]);
Serial.println(ChMax[2]);
Serial.println(ChMax[3]);
Serial.println(ChMax[4]);
Serial.println(ChMax[5]);
Serial.println(ChMax[6]);
Serial.println(ChMax[7]);*/
}//END function
//This is where modification of insolation by clouds or a storm occurs
//Its worth noting that the clouds simply modify (depending on how much cloud cover there is) the existing light set by insolation as a fractional value
void Weather ()
static float PriorCloudCover; //used to "delay" one side of the tank from the other in cloud passing effects
static long StormStart;
static long StormEnd;
static long CloudEnd;
static byte Severity;
if (Cloud==false){
CloudEnd-=10;//remove 10 sec from cloud end to clear sky when done...
Cloud=true;//Clear sky function resets to false at time end of cloud
CloudCover=50;
Counter=0;
break;//were starting this cloud so stop looking for another one
//just write ChannelVales to TrueIntensity without modification so that cloud/storm can later modify them
for (byte a=0; a<8; a++){
return;
//Serial.println("in a cloud doing stuff");
if (elapsedTime>=CloudEnd){
return;
/*Use fractional intensity to set minimum value for any channel. Dimming is proportional to actual intensity output
and constrained by flicker point. Random walk uses static variable "CloudCover" constrained to 0-100 to represent fractional intensity (i.e. (1-(CloudCover/100))*Insolation SetPoint
int stepsize;
stepsize=random(-15,16);// in Percent% (0-100) This is how much light intensity can change every 1 or 2 seconds (Whatever CloudAdvance is in this case);
//Serial.print("Stepsize=");
//Serial.println(stepsize);
PriorCloudCover=CloudCover;//this way its going to change every 250 msec
//Serial.print("PriorCloudCover=");
//Serial.println(PriorCloudCover);
CloudCover=(CloudCover+stepsize);//Now add the % increment or decremement to intensity
//Serial.print("CloudCover=");
//Serial.println(CloudCover);
if (CloudCover>=100){ //arbitrary "STORM" cutoff... i.e. if the sky gets dark enough we must be having a storm- if you dont get enough storms increase stepsize boundry or change this value
CloudCover=100;//since we see dark clouds better let it just sit here until it walks away
Counter++;
//Serial.print("CLoudCover was over 100 and got corrected to=");
else if (CloudCover<=0){//i.e if were bright sky in a cloud.. uhh.. we need a cloud
//Serial.print("Cloud cover was negative so I fixed it and its now=");
CloudCover-=(stepsize*1.5);// since we are supposed to be cloudy if we get too bright correct it down by amplifying the change that got us to a clear sky and inverting it
if (Counter>=2) Counter-=random(0,2); //reflect to less positive value, i.e. we had to be adding a negative so subtract it instead (i.e. add a positive)
if ((Counter>=115) && ((CloudEnd-elapsedTime)>=500)) {//this is where a storm is triggered. Counter indexes when cloud cover reaches 100 on the random walk
if (StormCount>0){
byte RandomStorm;
RandomStorm=random(0,11);//counter at 250 msec timing yeilds a storm in about 7 minutes.. this randomizes for longer clouds without storm, avg cloud is much longer
if (RandomStorm>=6){
IsStorm=true;
StormCount-=1;//count down by 1 the number of storms in this cloud
wtrigger=true;
Counter=0;
// Serial.print("we started a storm");
// Serial.print("Random call was missed- not a storm");
else if ((Counter>=115) && ((CloudEnd-elapsedTime)<500)){
Counter=0;
for (int a=0;a<8;a++){
if (DimOrder[a]==0){
//Serial.print("Initial Channel setting is= ");
//Serial.println(a);
//Serial.println(FullSun);
TrueIntensity[a]=(flicker[a]+(((float)(ChannelValue[a]-flicker[a]))*(1-((CloudCover/100)))));//max intensity is 65% of initial for better visual dimming performance
//Serial.print("DimOrder 0 setting is");
//Serial.println(TrueIntensity[a]);
else if (DimOrder[a]==1){
TrueIntensity[a]=(flicker[a]+(((float)(ChannelValue[a]-flicker[a]))*(1-((PriorCloudCover/100)))));//max intensity is 65% of initial for better visual dimming performance
//Serial.print("DimOrder 1 setting is");
//do this next part exactly once per storm then loop past
if (wtrigger==true){
StormStart=elapsedTime;
LongestStorm-=120;//remove 2 mins from longest storm so that we end up with 2 minutes of cloud after the storm before the sky clears to daylight
//*****************To CHANGE THE LENGTH OF THE LONGEST POSSIBLE STORM DURING A CLOUD read next line comments****************************
if (LongestStorm>500) LongestStorm=500;//YOU CAN CHANGE THE value in the comparison and the define to be whatever you want your max lenght to be
////*************************EDIT ABOVE***************************************************************************************************
int StormDuration=random((LongestStorm/4),(LongestStorm+1));//set (min,max) seconds any single Storm can exist currently 1/4 length to full length remaining cloudtime
StormEnd=(StormStart+StormDuration);
Severity=random(2,9);//changes lightning strike frequency in a storm from very frequent (every 10-15 sec or less) to about once in a minute or maybe less
Counter=0;
return;
//Serial.print("in a storm now");
IsStorm=false;
Counter=0;
return;
int stepsize;
stepsize=random(-19,20);
Counter++;
if (Counter>(Severity+1)) Counter=0;//allow if to accumulate on ocassion to train strike sequences 2-3 in a row but then dump it
CloudCover-=(1.5*stepsize);//stay within bounds
if ((Counter>=(Severity+random(-2,4))) && (StrikeNow==false)) {//this is where a storm is triggered. Counter indexes when cloud cover reaches 100 on the random walk
byte RandomStriker;
RandomStriker=random(0,11);
if (RandomStriker>3){
if (a>=(StrikeNumber*2)){
StrikeMaster[a]=0;
if (a%2==0){
if (a==0){
StrikeMaster[a]=random(300,1601);//no need for random here but I am leaving it since I wrote it that way. This must be independent from a=2,4,6 etc...
else {
StrikeMaster[a]=(StrikeMaster[(a-2)]+random(160,1201));//position 0,2,4,6,8.. is strike delay
else if(a%2!=0){
StrikeMaster[a]=random(45,100);//position 1,3,5,7,9... is strike duration (I tried real lightning strike durations and its too short this is adjusted for visual effect
StrikeCount=0;
for (int a=0;a<8;a++) {
if (Wchannel[a]==1){//if were white we need to be off in a storm
TrueIntensity[a]=0;
//Serial.print("In a storm and DimOrder0 channel values were");
//Serial.println(ChannelValue[a]);
TrueIntensity[a]=(flicker[a]+(((float)((ChannelValue[a]-flicker[a])))*(1-((CloudCover/100)))));
//Serial.print("and now the channel is set to");
//Serial.print("In a storm and DimOrder1 channel values were");
TrueIntensity[a]=(flicker[a]+((((float)(ChannelValue[a]-flicker[a])))*(1-((PriorCloudCover/100)))));
}//end of storm if loop
}//End Weather function
//THE LAST 2 mins of ANY Storm, or cloud, are used to ramp linearlly to full daylight setting, whatever that is at the given time of day
void ClearSky(float CloudCover, int CloudEnd)
// no need to restrict time to avoid resource hogging, its only called every x seconds from weather.
//basically, add 120 seconds to every cloud and use it to bring light up to full
int elapsed=(elapsedTime-CloudEnd);//counts up from zero forever... but we stop it by 120 to end cloud
//Since CloudCover is amount taken away as decimal fraction of InsolationSetting (i.e. 70 produces light at 30% of insolation setpoint... we need to come up 70 to get back.
float slope=(CloudCover/10);//cloud cover goes from 0 (Clear) to 90 (storm) in a cloud, since storms are forced to end before the cloud we know this is the limit
if (elapsed<=120){//at this point lights are back full on so cancel the cloud and start waiting for the next one
Cloud=false;
return;
byte LightAdvance;
LightAdvance=(CloudCover-(slope*elapsed));//were reducing CloudCover from start to zero over 120 seconds seconds...
TrueIntensity[a]=(byte)(((ChannelValue[a]-flicker[a])*(float)(1-((float)(LightAdvance/100))))+flicker[a]);
}//End Clear Sky function
byte MoonPhase()
int m,d,y;
int yy,mm;
long K1,K2,K3,J,V;
byte PWMvalue;
m = month();
d = day();
y = year();
yy = y-((12-m)/10);
mm = m+9;
if (mm>=12) mm -= 12;
K1 = 365.25*(yy+4712);
K2 = 30.6*mm+.5;
J = K1+K2+d+59-K3;
V -= int(V/100)*100;
V = abs(V-50);
PWMvalue = 4*abs(50-V); // 5.12=100% 4=~80%
//pinMode(lowATOPin,OUTPUT);
//return (PWMvalue*100)/255; //output is 0-100
return PWMvalue;
void CalcDST(byte D, byte M, byte dow)
//January, february, and december are out.
if (M < 3 || M > 11){
isDST=false;
//April to October are in
else if (M > 4 && M < 11){
isDST=true;
else{
int previousSunday=(D-dow); // Sunday=1 Sat=7
if (M==3 && previousSunday>7){
isDST=true;
else if (M==11 && previousSunday<=0){
isDST=false;
// A big thank you for these library functions. Its great!
//convert degrees to seconds of arc
// decimal degrees
long ddToSeconds(float dd){
return dd * 3600.0;
//Degrees, minutes, seconds
long dmsToSeconds(int d, unsigned char m, unsigned char s){
long ret;
ret = labs((long)d);
ret = ret * 3600L + 60L * m + s;
ret = (d<0L) ? -ret : ret;
return ret;
'Equation of Time'
We use the 'short for' equation, which has a theoretical accuracy of about 40 seconds.
The returned value is in seconds.
int equation_of_time(unsigned long dt){
double t;
dt -= 192540UL; // refer to Jan 3 2000 05:29 (first periapsis)
dt %= _tropical_year;
t = dt;
t /= _tropical_year;
t *= 6.283185307179586;
t = -459.27672 * sin(t) + 575.333472 * sin(2.0 * t + 3.588414);
return t;
'Solar Noon' adjusts the passed time stamp to the time (GMT) of local solar noon.
The accuracy is about 40 seconds (set by the equation of time).
void SolarNoon(unsigned long * dt){
long r;
// Set stamp to noon GMT
*dt /= 86400UL;
*dt *= 86400UL;
*dt += 43200UL;
// adjust for equation of time, at noon GMT
*dt -= equation_of_time(*dt);
// rotate to our longitude
r = longitude / 15L;
*dt -= r;
'Solar Declination'
Returns declination in radians
Accurate to within 50 arc-seconds
double SolarDeclination(unsigned long dt){
double y;
y = dt;
y /= _tropical_year; // fractional year
y *= 6.283185307179586;
y=0.006918-0.399912*cos(y)+0.070257*sin(y)-0.006758*cos(y*2)+0.000907*sin(y*2)-0.002697*cos(y*3)+0.00148*sin(y*3);
return y;
Return the period between sunrise and sunset, in seconds.
At high latitudes around the time of the solstices, this could be zero, or all day.
unsigned long daylightseconds(unsigned long dt){
float l, d, e;
long n;
d = -SolarDeclination(dt); // will be positive in Northern winter
l = latitude / _sec_rad; // latitude in radians
e += 60.0 * l * tan(l + d); // latitudinal error
d = tan(l) * tan(d); //
if(d>1.0) return 86400UL;
if(d < -1.0) return 0UL;
d = acos(d);
d /= _zenith;
n = 86400UL * d;
n += e;
return n;
Modify the passed time stamp to the time of sunrise (or sunset if 'set' is non-zero).
Returns 0 to signal 'normal' completion. If the position is in a polar circle, 1 will be
returned if the sun is above the horizon all day, and -1 if the sun is below the horizon
all day.
char SunRiseSet(unsigned long * dt, char set){
unsigned long daylen;
daylen = daylightseconds(*dt);
if(daylen == 86400UL) return 1; // there is no 'night' today (midnight sun)
if(daylen == 0UL) return -1; // there is no 'day' today
*dt /= 86400UL;
*dt *= 86400UL;
*dt += 43200UL; // set the time stamp to 12:00:00 GMT
*dt -= daylen / 2; // sunrise at the prime meridian
if(set) *dt += daylen; // sunset at the prime meridian
*dt -= longitude / 15.0; // rotate to our own meridian
return 0;
// 'short' forms of SunRiseSet
char SunRise(unsigned long* when){
return SunRiseSet(when, 0);
char SunSet(unsigned long* when){
return SunRiseSet(when, 1);
So on this exact code aove the sun is now setting in my tank 12:51 pm South Africa time.. LoL, I am confused about the GMT Offset
