Time for additional Ethernet add-on with PWM output
- DrewPalmer04
Re: Time for additional Ethernet add-on with PWM output
hmmm...so in theory. I write the received byte to SetChannel() and it'll display on the portal? This is me trying to "fool" the portal after all to know my % of brightness off my ethernet module lol...I'd just prefer to know my % values at a glance versus Serial.print() I have to use now.
- lnevo
Yeah, it should set the channel even though nothing is written there.. Theoretically, there may be other code in the way that Im not aware of.
- DrewPalmer04
Updated page 12 to include the link to the build list/materials needed.
- lnevo
- DrewPalmer04
Hey, thanks...it's been updated!lnevo wrote:Use this URL instead... http://forum.reefangel.com/viewtopic.php?p=18326#p18326
- DrewPalmer04
Sorry losing my mind....
Updated page 12 of thread.
- lnevo
Which thread? what did you update?
- DrewPalmer04
EDIT:
I should have been more clear...
Security option issue with the portal and Ethernet module. It must [<--Not 100% true] be disabled. That's all I added
I don't use security....but anyone can add this to the RA side of the code...
Use below for security option (IF needed):
ReefAngel SIDE
"key" must match on code and portal
ReefAngel SIDE
ReefAngel.Portal("username","key");
topjimmy
I have been using this for a few weeks and it really does work well. I am having a problem with the pwm for my Leds. They light up fine, but they flash, it's so fast that I thought it was just glimmer at first. I am using steve's led drivers. They work fine straight off of the RA dimming. Any suggestions?
- DrewPalmer04
Sounds like you don't have enough LEDs in the string. The driver is "protecting" itself. Either reduce the mA output from the driver or add more LEDs. That's what it sounds like to me
topjimmy
can't be that. They work fine off the RA, and the drivers are maxed out as far as capacity.
- DrewPalmer04
Could be that you need an opamp to boost from 0-5vdc to 0-10vdc. Roberto posted a circuit for how to do it
- DrewPalmer04
Or make sure they don't send more than 40mA to the arduino. I don't use Steve's so I'm not sure.
topjimmy
That might be it. I wonder what he uses for the relay that makes it work.DrewPalmer04 wrote:Could be that you need an opamp to boost from 0-5vdc to 0-10vdc. Roberto posted a circuit for how to do it
- DrewPalmer04
Lm358 opamp. Two 10k resistors make a gain of 1.
topjimmy
The drivers I am using will work straight off an Arduino pwm. In fact they can even supply +5v to power the board. I think it is either some sort of noise induced from the power supply, or the pwm freq. is too low?
Not sure.
Not sure.
- DrewPalmer04
Try to remove this line or //comment it out:
And check this page out:
http://arduino.cc/en/Tutorial/SecretsOfArduinoPWM
bitSet(TCCR1B, WGM12); //force fast PWMhttp://arduino.cc/en/Tutorial/SecretsOfArduinoPWM
topjimmy
Commented out, same problem. There must be something causing it.
If I remember correctly, Steve's drivers accept 0-5V PWM too, doesn't it?
Can you describe or post a video of such flickering effect?
Do you have access to a scope to check the signal?
topjimmy
No, scope available. The drive does except 0 - 5v pwm. I can record it, but it looks like a strobe light a very fast flicker with no perceived off.
topjimmy
I might have found the problem. I don't think that the header pins I am using are in tight enough. What do you think the best way to get a good connection would be?
topjimmy
I am thinking about removing the headers and just soldering the wire to the board. The pins I got from radio shack seem so loose in the header, they just don't make good contact. Maybe the pins I got have to small a diameter.
Do you all just solder your permanent projects?
- DrewPalmer04
DB headers just take them apart and use the pins. They fit very nicely.
topjimmy
DB?DrewPalmer04 wrote:DB headers just take them apart and use the pins. They fit very nicely.
Did you mean MB?
- DrewPalmer04
http://en.m.wikipedia.org/wiki/D-subminiature
The pins out of the header. No need to buy the entire cable. The shack sells just the header for you to use the pins.
topjimmy
Ahh I see, I have a ton of those asking to be sacrificed.DrewPalmer04 wrote:http://en.m.wikipedia.org/wiki/D-subminiature
- DrewPalmer04
topjimmy
If only this could be controlled via the apps or portal. I have half a mind to maybe attach a little LCD and some buttons to change a few settings.
- DrewPalmer04
LCD is a good idea. I'll be working on RA communication with the Ethernet module soon. Just have to finish my other project first. Might be a week or two. But I'll see what I can figure out. Tons of people have been requesting that. I just wasn't sure if Roberto had plans to create a "RA" expansion based on this module or not. I didn't want to double develop it.
topjimmy
Well let me help. Just let me know what you want to try and we can work on it together. Of course it would also be very cool if Roberto wanted to chime in.
I really don't see why they should not communicate like any other expansion. Data is data. It's just sending it to the right place in the right format.
