Re: JEBO WP-40
Posted: Fri Mar 29, 2013 3:03 pm
Roger that!rimai wrote:So, do we have the first person reporting RA controlling Jebao pump ???
Only with you guys holding my hand!
https://forum.reefangel.com/
Both 220&221 would not reflect the change last night.lnevo wrote:What memory location are you trying to change that isn't working and you need to reboot?
ReefAngel.PWM.SetActinic(InternalMemory.LEDPWMActinic_read());
ReefAngel.PWM.SetDaylight(InternalMemory.LEDPWMDaylight_read());
#2 here! Have it running opposite my MP-10 with both pumps using the wave patters from the other thread.rimai wrote:So, do we have the first person reporting RA controlling Jebao pump ???
So far, yes. I was saving the output for each pump in a customer var for the last 4 or 5 days now. I got some weird numbers at first (130% - 550%) but I think it had to do with the way I was assigning the variables. I made a couple of changes and it seems to have a normal output now.rimai wrote:Cool!!
Are those functions working as intended???
I already added them to the libraries, but wanted to confirm they are working before I release.
You are close. But you will need to use numerical values for mode or the defined nickname in Globals.h. Also, i would pass duration%2 which would change whatever duration is set to either 0/1 for even/odd numbers since the second arg in Tidal Swell is a boolean.Paulturner911 wrote:Got it! Ive added it to my code Im compiling for the next upload.
Can anyone confirm if my "guess" on how to code the RF/Portal was going to work as intended? I dont want to do all 7 and find that Im COMPLETELY wrong
I dont.... All I do is ask, ask and ask again. Could you modify the code I posted to be correct so that I could then take the changes and make them to the other codes?lnevo wrote:You are close. But you will need to use numerical values for mode or the defined nickname in Globals.h. Also, i would pass duration%2 which would change whatever duration is set to either 0/1 for even/odd numbers since the second arg in Tidal Swell is a boolean.Paulturner911 wrote:Got it! Ive added it to my code Im compiling for the next upload.
But looks like you have the idea.
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.StandardFan( Port2 );
ReefAngel.WavemakerRandom1( Port5,180,900 );
ReefAngel.WavemakerRandom2( Port6,90,900 );
ReefAngel.DayLights( Port7 );
ReefAngel.DayLights( Port8 );
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Pump Delay and Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 20sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<22);
//Feed Mode Delay on Pump
static boolean feeding=false;
static unsigned long feedingstarted = now();
if (!feeding)
feeding=true;
if (now()-feedingstarted>900)
bitSet(ReefAngel.Relay.RelayMaskOff,Port5-1);
bitSet(ReefAngel.Relay.RelayMaskOff,Port6-1);
/* Reference for possible modes...
#define Constant 0
#define Lagoon 1
#define Random1 1 // Lagoonal
#define ReefCrest 2
#define Random2 2 // Reef Crest
#define ShortPulse 3
#define ShortWave 3
#define LongPulse 4
#define LongWave 4
#define NutrientTransport 5
#define Smart_NTM 5 // Nutrient Transport Mode
#define TidalSwell 6
#define Smart_TSM 6 // Tidal Swell Mode
// Read memory for RF Wave Settings
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
if (mode=TidalSwell) {
ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,duration%2) );
} else {
ReefAngel.PWM.SetDaylight( speed / 2 );
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
//Tidal Swell
byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync)
static unsigned long lastwavemillis=millis();
static byte WavePhase=0;
static time_t WaveStart=0;
static byte speed=0;
static byte anti_speed=0;
if (WavePhase==0)
WavePhase++;
WaveStart=now();
else if (WavePhase==1)
if (now()-WaveStart>900) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,0,900,0,90))))/10;
speed+=WaveMaxSpeed/2;
anti_speed=(WaveMaxSpeed*2*sin(radians(map(now()-WaveStart,0,900,0,90))))/5;
anti_speed+=WaveMaxSpeed/2;
else if (WavePhase==2)
if (now()-WaveStart>1800) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
speed+=WaveMaxSpeed/20;
anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
anti_speed+=WaveMaxSpeed/4;
else if (WavePhase==3)
if (now()-WaveStart>2700) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
else if (WavePhase==4)
if (now()-WaveStart>3600) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
speed+=(WaveMaxSpeed*3)/20;
anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
anti_speed+=(WaveMaxSpeed*3)/20;
else if (WavePhase==5)
if (now()-WaveStart>4500) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
else if (WavePhase==6)
if (now()-WaveStart>5400) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
speed+=(WaveMaxSpeed*5)/20;
anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
anti_speed+=WaveMaxSpeed/20;
else if (WavePhase==7)
if (now()-WaveStart>6300) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
else if (WavePhase==8)
if (now()-WaveStart>7200) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/20;
speed+=(WaveMaxSpeed*7)/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/10;
else if (WavePhase==9)
if (now()-WaveStart>8100) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/2;
else if (WavePhase==10)
if (now()-WaveStart>9000) WavePhase=0;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,8100,9000,90,180))))/2;
anti_speed=speed;
if (PulseSync)
return speed;
return anti_speed;
Change thisPaulturner911 wrote:Thanks. Maybe Tidal was not a good one for me to start with. I really just needed the changes with in what I had posted at 5:05. In order to help me identify where I needed the numerical values and the definitions. You DA man. I was also trying to figure what to type in feed mode toggle ports to turn off the PWMDaylight. I tried PWMDaylight, LEDPWMDaylight, PWM.SetDaylight (0)? IDK how else I would do it.
Some people got theirs from the initial batch.jayathome wrote:Wow, moving fast here.
Are you guys using the harness or doing your own cables mods?
Also, any idea on when the pre-ordered cables will be ready for delivery?
I'm using the harness. I was refreshing the order page for two hours straight waiting for them to show up just to make sure I got in on the initial batchjayathome wrote:Wow, moving fast here.
ReefAngel.PWM.SetActinic ( ReefCrestMode(50,20,true) ); // ReefCrest at 50 +/- 20 in sync mode
ReefAngel.PWM.SetDaylight ( ReefCrestMode(50,20,false) ); // ReefCrest at 50 +/- 20 in anti-sync mode
//ReefCrest
if (mode == ReefCrestMode) {
} else {
Piper wrote:Try this:
//ReefCrest if (mode == ReefCrestMode) { ReefAngel.PWM.SetDaylight ( ReefCrestMode(50,20,false) ); // ReefCrest at 50 +/- 20 in anti-sync mode } else { ReefAngel.PWM.SetDaylight( speed / 2 ); }
I tried this an got an error of "mode was not declared in this scope". Any ideas? I pasted this code in the custom code section....Paulturner911 wrote:Piper wrote:Try this:
Errors
ISO C++ forbids comparison between pointer & integer
//ReefCrest
if (mode == ReefCrest) {
} else {
This works...I removed the word MODE in this line
if (mode == ReefCrestMMode) {
As for the speed/2 Im not sure what it does( I think it runs at 50%) I just pulled it from the tidal swell that Lee was kind enough to provide.
[quote]
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <[color=#006699]LED[/color].h>
#include <[color=#006699]Relay[/color].h>
#include <[color=#006699]Timer[/color].h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
[color=#7E7E7E]// This must be the first line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color](); [color=#7E7E7E]//Initialize controller[/color]
[color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = [color=#006699]Port5Bit[/color] | [color=#006699]Port6Bit[/color];
[color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port5Bit[/color] | [color=#006699]Port6Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
[color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = [color=#006699]Port1Bit[/color];
[color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port2Bit[/color] | [color=#006699]Port7Bit[/color];
[color=#7E7E7E]// Use T1 probe as temperature and overheat functions[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T1_PROBE[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T1_PROBE[/color];
[color=#7E7E7E]// Ports that are always on[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port5[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port6[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port8[/color] );
[color=#7E7E7E]////// Place additional initialization code below here[/color]
[color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
[color=#CC6600]ReefAngel[/color].[color=#CC6600]DayLights[/color]( [color=#006699]Port1[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]ActinicLights[/color]( [color=#006699]Port2[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Set[/color]( [color=#006699]Port3[/color], ![color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Status[/color]( [color=#006699]Port1[/color] ) );
[color=#CC6600]if[/color] ([color=#CC6600]ReefAngel[/color].[color=#006699]HighATO[/color].[color=#CC6600]IsActive[/color]())
[color=#CC6600]ReefAngel[/color].[color=#CC6600]SingleATOLow[/color]( [color=#006699]Port4[/color] );
[color=#CC6600]else[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Off[/color]( [color=#006699]Port4[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardHeater[/color]( [color=#006699]Port7[/color] );
[color=#7E7E7E]////// Place your custom code below here[/color]
[color=#7E7E7E]////// Place your custom code above here[/color]
[color=#7E7E7E]// This should always be the last line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Portal[/color]( [color=#006699]"SeedlessOne"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
[color=#CC6600]void[/color] DrawCustomMain()
[color=#CC6600]int[/color] x,y;
[color=#CC6600]char[/color] text[10];
[color=#7E7E7E]// Parameters[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 20, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color],
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetDaylightValue[/color](), [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetActinicValue[/color]() );
#else [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 20, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color] );
#endif [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
[color=#CC6600]pingSerial[/color]();
[color=#7E7E7E]// pH Expansion[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, [color=#006699]"PHE:"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,66, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color].[color=#006699]PHExp[/color] );
[color=#7E7E7E]// Water Level[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, [color=#006699]"WL:"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, [color=#CC6600]ReefAngel[/color].[color=#006699]WaterLevel[/color].[color=#CC6600]GetLevel[/color]() );
[color=#7E7E7E]// Main Relay Box[/color]
[color=#CC6600]byte[/color] TempRelay = [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayData[/color];
TempRelay &= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOff[/color];
TempRelay |= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOn[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawOutletBox[/color]( 12, 92, TempRelay );
[color=#7E7E7E]// Date and Time[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawDate[/color]( 6, 122 );
[color=#CC6600]void[/color] DrawCustomGraph()
[/quote]Sadly I've read that more than once. Still missing something. Back to the chalk board.lnevo wrote:Take a look at the code here...and try reading the past couple of pages.,, we just did the same
http://forum.reefangel.com/viewtopic.php?p=22903#p22903
Sent from my GT-P31 thing... 13 using Tapatalk 2
