Re: How to setup your wifi attachment
Posted: Mon May 18, 2015 9:12 am
Sounds like you still have that router in there and you probably have two routers, which is complicating things a bit for you.
https://forum.reefangel.com/
it WAS connecting to my router but now with trying all of these tips it wont even connect now. i plug it in now the blue light stays flashing.rimai wrote:Is it working on your wifi network?
If so, you need to setup port forwarding in your router.
ReefAngel.AddWifi(); // Add Wifi
ReefAngel.FeedingModePorts = Port2Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit;
// Define labels for 2014 LCD screen
//box0
ReefAngel.CustomLabels[0]="T5HO";
ReefAngel.CustomLabels[1]="Skimmer";
ReefAngel.CustomLabels[2]="FugeLight";
ReefAngel.CustomLabels[3]="Heater";
ReefAngel.CustomLabels[4]="ScrubLight";
ReefAngel.CustomLabels[5]="Kalk_Mixer";
ReefAngel.CustomLabels[6]="Kalk_ATO";
ReefAngel.CustomLabels[7]="RO_ATO";
//lowers minimum speed for DC pump
InternalMemory.DCPumpThreshold_write(0);
//gives random sopmething to randomize against
randomSeed(now()/SECS_PER_DAY);
ReefAngel.ShowInterface(); //wifi
ReefAngel.MHLights( Port1,12,30,14,30,5 ); //t5ho
ReefAngel.MHLights( Port2,7,0,22,0,5 ); //skimmer
ReefAngel.StandardLights( Port3,18,0,10,0 ); //fugelight
ReefAngel.StandardHeater( Port4,785,788 ); //heater
ReefAngel.StandardLights( Port5,18,0,10,0 ); //scrubber light
ReefAngel.DosingPumpRepeat( Port6,0,240,25 ); // kalk mixing every 6 hours for 25 seconds
////// Wave Pattern Code Start
//Hardcode minimum speed of DC pumps
ReefAngel.DCPump.Threshold=0;
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { ReefCrest, NutrientTransport, TidalSwell, Lagoon, Else, ReefCrest, Else };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
// after feed mode Continue NTM for the 60 minutes
if (now()-feeding<1800) {
ReefAngel.DCPump.Mode=Else;
//7am to 9am - wake up from night mode
else if (hour()>=7 && hour()<9){
ReefAngel.DCPump.Duration=350;
ReefAngel.DCPump.Mode=Sine;
ReefAngel.DCPump.Speed=50;
//9am to 10am - ramp up to random
else if (hour()>=9 && hour()<10){
ReefAngel.DCPump.Mode=Lagoon;
ReefAngel.DCPump.Speed=60;
//10am to 6pm - Random
else if (hour()>=10 && hour()<18) {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
ReefAngel.DCPump.Speed=70;
//6pm to 7pm - slow down from random
else if (hour()>=18 && hour()<19){
//7pm to 9pm - slow down to night mode
else if (hour()>=19 && hour()<21){
// Night mode
else {
ReefAngel.DCPump.Duration=450;
ReefAngel.DCPump.Speed=40;
////// Wave Pattern Code End
////// ATO RO and Kalk Settings
if ((hour()>18 || hour()<9) && (ReefAngel.Params.PH < 822))
ReefAngel.SingleATO( true,Port7,600,0 ); // Sump switch. Kalk schedule 6pm - 7am if pH < 8.25 If ATO/Kalk runs for 10 minutes=600 seconds, then shut off.
ReefAngel.Relay.Off(Port8);
ReefAngel.SingleATO( true,Port8,500,0 ); // Sump switch. If ATO/RoDi runs for 8.20 minutes=480 seconds, then shut off.
ReefAngel.Relay.Off(Port7);
////// End ATO RO and Kalk Settings
rimai wrote:If you are able to access the internal webserver you are all set.
Green light means you are connected to your WiFi network.
It is not supposed to do anything else.
I can browse the above, I just get blank parameters and 'connecting' and unknown forum userlnevo wrote:It depends on your router...
Can you ping the IP address from your desktop (192.168.0.11)?
No, I get 'unable to connect'
Can you browse to http://192.168.0.11:2000/wifi in your browser
Can someone tell me why the graph is lagging by 2 or 3 days and is not accurate? According to the status pH when I've checked, it hasn't been above 8.35, and is showing an impossible reading of 10.23?sophie10 wrote:I think we're good on the local and outside network, thank you! I currently only have the temp probe and pH probe installed. On the status page, data reads exactly what's on the controller screen, however when I click on the pH or Temp number, the graph displayed are way off in temp/pH values. I have calibrated the pH probe. Any thoughts there? You have already been most helpful, thanks again.
ReefAngel.Portal("sophie10");
