Page 7 of 9
Re: PaulTurner911 Code
Posted: Mon Jun 23, 2014 4:27 pm
by Sacohen
lnevo wrote:Lol what was the issue that you couldnt set the % on the 2nd pump differently?
That was one issue, but the one that didn't get resolved is that the portal shows every option available to the RA when it is in Else Mode.
I started a new thread so we don't fill up Paul's thread with this issue,
http://forum.reefangel.com/viewtopic.php?f=12&t=4696
Posted: Mon Jun 23, 2014 4:48 pm
by Paulturner911
if (rmode==Else) {
    ReefAngel.DCPump.Mode=Constant;
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
  } else {
Should this call "else" when "constant" is selected?
Posted: Mon Jun 23, 2014 7:09 pm
Its constant because we want the pump set at the speed that elsemode calculates. We could also put it in Custom mode here but then you would have to call the pwm commands directly.
Posted: Mon Jun 23, 2014 7:17 pm
by Paulturner911
OK, I was trying to replicate his portal issue showing EVERYTHING, since I am running pretty much the same code.
Lee, If you get a min, please glance over my code and tell me if you see any issues in the stuff I cut and pasted from Sacohens code. Like I said, it uploaded :) Ive run feedmode and all seemed well.
Ill keep an eye out for else mode and wonky portal display. Is it only the day (in my case) that random calls ELSEMODE that the portal shows this?
Posted: Tue Jun 24, 2014 4:30 am
Where is it?
Posted: Tue Jun 24, 2014 5:01 am
by Paulturner911
lnevo wrote:Where is it?
Sorry Lee, I must have neglected to attach it. Ill plug it in later this evening.
Everything seems ok, I just took my old code and added a few things I saw in Sacohens code that seemed like it was needed for Else mode.
Just kept clicking away and reading bits and pieces of threads.
Posted: Thu Jun 26, 2014 5:32 pm
by Paulturner911
This is current:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
ReefAngel.DayLights( Port6 );//Port 6 Skimmer
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 4, MoonPhase() );
ReefAngel.PWM.SetChannel( 5,(0) );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
// Add random mode if we set to Mode to Custom in portal
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { Lagoon, Else, ReefCrest, TidalSwell, ShortPulse, LongPulse, NutrientTransport };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
  // First 15 minutes after feeding mode stops. Return Pump is off
  // First 15 minutes after feeding mode stops. Smart_NTM
  ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
  // Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
  if (rmode==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
  } else {
    ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Posted: Fri Jun 27, 2014 9:51 am
Change this line
  if (rmode==Else) {
to
  if (modes[rmode]==Else) {
Posted: Fri Jun 27, 2014 3:40 pm
by Paulturner911
Posted: Wed Jul 23, 2014 2:43 pm
by Paulturner911
Current code below. I am having an issue with the 2 DC pumps, sometimes the screen on the controller shows values but the pumps arent working. Its random, maybe an issue with else mode?
How can I activate else mode to see?
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
const int Else=16;
changeMode=false;
  } else {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Posted: Wed Jul 23, 2014 3:18 pm
by Sacohen
Remove everything else from the list of options except else mode and then that will be the one that it chooses.
Posted: Wed Jul 23, 2014 3:41 pm
by Paulturner911
I'm not sure how to.
No way to call it from a memory location manually?
Ok, I think I understand.
Posted: Wed Jul 23, 2014 3:54 pm
by Sacohen
Change this...
To this...
byte modes[] = { Else };
Posted: Wed Jul 23, 2014 4:20 pm
+1
Posted: Tue Aug 05, 2014 1:43 pm
by Paulturner911
Could someone refresh my memory on how to have Relay 6 run constant, unless Im in feed mode?
I didnt realize it but when I added the skimmer it runs on the same schedule as my MH lamps. I would like it to be on all of the time unless its in feed mode.
Any help is greatly apprerciated.
Thank you
Posted: Tue Aug 05, 2014 2:00 pm
by Sacohen
You need 2 things....
This in // Ports toggled in Feeding Mode
ReefAngel.FeedingModePorts = Port6Bit;
And then in // Ports that are always on
If you want to delay the start after feeding mode by 10 min so your main pump gets up to speed and your water leve gets back to normal you can add this in the loop section...
ReefAngel.Relay.DelayedOn( Port6,10 );
Posted: Tue Aug 12, 2014 3:28 pm
by Paulturner911
Great! Thank you
Posted: Tue Oct 28, 2014 12:14 pm
by Paulturner911
I HAVE PICKED UP A NEW TANK!!!
Im wondering if I should just run the wizard and start over, but cut and paste some "custom lines" ??? Please advise which would be easier.
Ditching a few things -
MH (port7&8)
FANS (port2)
ACTINIC (port3)
I have a few things that Id like to add-
3 Ecoray112DX whites/red (port7) Actinics (port8)
Chiller (port2) Should function similar to the fan settings? * NEEDS TO SHUT DOWN IN FEED/WATERCHANGE MODES
Skimmer (port3) ** Id like it off for 2 hours after feedmode activation
ANY AND ALL INPUT IS WELCOMED AND VERY APPRECIATED
Posted: Tue Oct 28, 2014 12:18 pm
by Sacohen
I would keep what you have and go in and manually cut out what you don't want.
Then use the wizard to create the code you want to add and paste it in to your existing code.
Posted: Tue Oct 28, 2014 12:49 pm
by Paulturner911
Ill give it a try!! thanks
Posted: Tue Nov 04, 2014 4:53 pm
by Paulturner911
I decided to keep my code and change a few relays and make it work for the most part. I have the following questions:
Chiller will now be on port 2. It has a 2 deg variance, if I want the tank at 78 i would set this to 80?
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
Wouldnt it then turn the chiller off when it goes to 79?
Skimmer is on port 6- Does shut off in feedmode , but I would like this to have a 2 hour delay after feed mode. How would i code this?
Thanks guys!
Posted: Wed Nov 05, 2014 5:36 am
No that code is for screen drawing. Post your code and I'll be able to help
Posted: Wed Nov 05, 2014 6:56 pm
by Paulturner911
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.LightsOnPorts =  Port3Bit | Port7Bit ;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit ;
//Port 2 Chiller
//Port4 Kalk/ATO
//Port5 Kalk Stir
ReefAngel.DayLights( Port6 );// Skimmer
ReefAngel.DayLights( Port7 ); // White LEDS
//Port8 Empty
//ATO Protection
ReefAngel.Relay.Set(Port4, now()%900<65);
static int rmode;
const int Else=16;
byte modes[] = { Else, Lagoon, Else, ReefCrest, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
  } else {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Posted: Thu Nov 06, 2014 8:33 am
by Paulturner911
I've noticed that the skimmer (port6) is functioning like the old mh ports 7/8 as far as off and on schedule.
Is like this to run 24/7 unless water change or feed mode has been activated.
Posted: Thu Nov 06, 2014 8:52 am
by Sacohen
Port 6 is included in Feeding, Water Change and Overheating off.
You also have it as Always on.
The one line of code that refers to Port 6 that I see has no time associated to it.
it just this...
Posted: Thu Nov 06, 2014 10:16 am
by Paulturner911
Port 6 definatly does not run 24/7
It does shut off for WC and feed mode correct.
I would like it to stay off for 2 hours after either.
What should it read? It's currently shitting down with the "daylight" LEDs.
Thank you
Posted: Thu Nov 06, 2014 12:47 pm
by Sacohen
I think it has to do with this ReefAngel.DayLights( Port6 );// Skimmer
Just remove this line ReefAngel.DayLights( Port6 );// Skimmer and it should stay on all the time except Feeding, Water Change and Overheat because of this...
You can probably remove i the Port6Bit from the Overheat as well, you don't need to turn off the skimmer during an overheat situation.
Posted: Thu Nov 06, 2014 4:19 pm
He wanted a delay so use DelayedOn instead of On and put 120 as the second argument for 2 hours.
Posted: Thu Nov 06, 2014 5:55 pm
by Paulturner911
ReefAngel.Relay.DelayedOn( Port6 );120;
will this work?
Posted: Thu Nov 06, 2014 8:36 pm
ReefAngel.Relay.DelayedOn(Port6, 120);
