Page 7 of 8
Re: How to setup your wifi attachment
Posted: Tue Jun 14, 2016 6:45 pm
by slm222
I'm sorry, I'm very dense on the programming side of things. But I cannot access it remotely. Am I missing something
Posted: Tue Jun 14, 2016 6:47 pm
You just said you can access it using the public ip.
That is a remote connection.
Maybe you are not explaining or I'm not understanding what you are trying to do.
Posted: Tue Jun 14, 2016 7:03 pm
by slm222
nevermind. I found it. I added a couple lines into the code I found on here... seems to be working now. im trying to get my phone to pick it up. but on the iPhone app im getting and "Alert: unable to process controller data!"
Posted: Wed Jun 15, 2016 3:31 pm
by slm222
please disregard my comments. another stupid finding. I did not realize the user name on the app was case sensitive.
thank you for the responses.
Posted: Sun Dec 11, 2016 7:31 am
by sophie10
Hello All,
Forgive me if this has been addressed here, but i am having trouble setting up the WIFI. The RA WiFi attachment is flashing green, but won't connect. I've looked in my router (Ubee) and it has assigned 192.168.0.11 for my RA WiFi, but I believe I have to set up port forwarding in my router. Not exactly sure how to do that. See image below! Thank you!
David
Posted: Sun Dec 11, 2016 7:38 am
It depends on your router...
Can you ping the IP address from your desktop (192.168.0.11)?
Can you browse to
http://192.168.0.11:2000/wifi in your browser
Posted: Sun Dec 11, 2016 7:58 am
by sophie10
Thank you for the quick response!
lnevo wrote:It depends on your router...
No, I get 'unable to connect'
Can you browse to
I can browse the above, I just get blank parameters and 'connecting' and unknown forum user
Thank you!
Posted: Sun Dec 11, 2016 7:59 am
Good go into settings and add your controller there. Don't fill in the cloud settings.
Posted: Sun Dec 11, 2016 8:13 am
by sophie10
Thank you, but the similar results... 'disconnected', 'never' update, 'unknown' forum user
Posted: Sun Dec 11, 2016 10:52 am
If you are seeing the cloud server connection status showing up, you may have entered cloud server settings when setting up your controller.
Delete that profile and create a new one, making sure that you don't enter anything on cloud server settings.
Posted: Mon Dec 12, 2016 7:57 am
by sophie10
Thank you Roberto, I've deleted the old profile and created a new one with the same results. I may have to do something with my wifi modem to recognize the RA-wifi. Under the wife status in the image posted above, its says:
DHCP:false and shows the ip address as 0.0.0.0
When I go into the modem, I see the RA-wifi is assigned 192.168.0.11, Do I need to set up port forwarding? I, of course, don't know how to do this. Thanks again,
David
Posted: Mon Dec 12, 2016 9:24 am
You will eventually, but before that, you should be able to access the controller from inside your wifi network.
When you browse to
http://192.168.0.11:2000/wifi delete all profiles and hit refresh.
What happens?
Posted: Fri Dec 16, 2016 9:02 am
by sophie10
Thank you Roberto. OK! I have status! Temp and pH show up! So far so good!
Posted: Fri Dec 16, 2016 9:58 am
Good. That means that you are getting access to your controller inside your own wifi.
Now, if you also want to have control when outside your wifi, you will need to setup port forwarding in your router.
Routers block access by default. All routers do as they treat any incoming access as malicious. So, you need to tell the router that when you come in through port 2000, you want to get access to your controller and that's when port forwarding comes in.
Posted: Sat Dec 17, 2016 9:11 am
by sophie10
I think we're good on the local and outside network, thank you! I currently only have the temp probe and pH probe installed. On the status page, data reads exactly what's on the controller screen, however when I click on the pH or Temp number, the graph displayed are way off in temp/pH values. I have calibrated the pH probe. Any thoughts there? You have already been most helpful, thanks again.
Posted: Tue Dec 20, 2016 7:28 pm
by sophie10
sophie10 wrote:I think we're good on the local and outside network, thank you! I currently only have the temp probe and pH probe installed. On the status page, data reads exactly what's on the controller screen, however when I click on the pH or Temp number, the graph displayed are way off in temp/pH values. I have calibrated the pH probe. Any thoughts there? You have already been most helpful, thanks again.
Can someone tell me why the graph is lagging by 2 or 3 days and is not accurate? According to the status pH when I've checked, it hasn't been above 8.35, and is showing an impossible reading of 10.23?
The temperature is equally inaccurate on the graph, but fine on the status. Any thoughts are appreciated.
Posted: Tue Dec 20, 2016 7:34 pm
Are you sure you have the controller setup correctly?
Do you have this in your code?
There is no data in your portal.
Posted: Fri Dec 23, 2016 9:18 am
by sophie10
Hi Roberto,
I thought I set it up correctly. I set it up using the pre-loaded settings and then had you help me set up the wifi. Attached is a current image of the graph display, the current pH is actually 8.22 and has fluctuated between 8.19 and 8.33 over the last two weeks, but look at the graph (from almost pH 10 dropping to 7.8)! Thanks and happy holidays!
Posted: Fri Dec 23, 2016 10:28 am
The preloaded code is not customized.
You need to generate a code with the wizard to be able to customize your controller to you and add your forum integration.
Otherwise the controller doesn't send information to the portal.
Posted: Fri Dec 23, 2016 12:14 pm
by sophie10
Well that would explain a lot. I will investigate. Thank you!
Posted: Thu Dec 29, 2016 6:31 am
by sophie10
rimai wrote:The preloaded code is not customized.
Hi Roberto, I used the wizard (slick!), and used my 192.168.0.11 for the ddns, and I found my info on the portal (see below)! Everything looks fine, except the connection status shows 'unreachable address', is the norm? The data is accurate!
Posted: Thu Dec 29, 2016 7:46 am
by sophie10
Uh oh, While I see my system in the portal, I notice that while the temp and pH are accurate, the the range is wrong. It only has data to 12/26, but the last update was 12/29 at 9:41 (just did one). I also can no longer access my RA from within my own WIFI using 192.162.0.11:2000/WIFI. What did I do?
Posted: Thu Dec 29, 2016 10:47 am
The path is case sensitive. Sorry.
Also, your address seems wrong. Usually, they are 192.168 and not 192.162 on most routers.
It needs to be
Also, in order for the portal to connect to your controller, that's when port forwarding comes in.
By default, all routers block any external access to inside your wifi network. That's what they are designed for. It's called firewall.
So, the portal has no way to access your controller.
Port forwarding allows a specific port to be forwarded to a specific ip address, which will allow external connections to reach your controller.
You need to setup your router for port forwarding. It needs to forward port 2000 to your RA ip address 192.168.0.11
Posted: Sun Jan 08, 2017 7:30 am
by sophie10
Can you check my status on the portal Roberto? Attached is an image of the status. I think I have everything set right. I get live reports when I access from within and outside my LAN, but I don't have historical data. The iPhone app the same - current data, but nothing after Jan 2. Thank you.
Posted: Sun Jan 08, 2017 10:43 am
Can you send us the "get e" dump from the wifi attachment?
The new server is operational, so there may be something else.
Posted: Mon Jan 09, 2017 3:31 pm
by sophie10
OK, thank you. I may not know how to do that... :/ But will investigate!
Posted: Mon Jan 09, 2017 3:37 pm
Look at this thread:
http://forum.reefangel.com/viewtopic.php?f=15&t=6337
Basically, you need to connect to the COM port at 57600 baud and type $$$ to enter command mode.
Then type get e.
