Page 1 of 5
Re: Custom code, please help
Posted: Mon Apr 23, 2012 12:43 am
by d0lph1n
it looks like it was a weird contact issue. I was able to fix it by taping the t2&t3 cables to the ph connector.
Regarding PWMSlope, after midnight, it doesn't work anymore and the AP & DP are set to zero.
Please advise. Thank you.
if (hour() > 6 && hour() < 22)
ReefAngel.PWM.SetDaylight(PWMSlope(10,0,18,0,0,80,180,0));
ReefAngel.PWM.SetDaylight(PWMSlope(22,0,6,0,0,80,240,0));
ReefAngel.PWM.SetActinic(PWMSlope(6,0,22,0,0,80,240,0));
ReefAngel.PWM.SetActinic(PWMSlope(22,0,6,0,0,80,180,0));
Posted: Mon Apr 23, 2012 9:05 am
The slope can't cross over to next day :(
What is that you are trying to achieve?
Posted: Mon Apr 23, 2012 1:50 pm
by d0lph1n
I'm trying to have different settings between 10pm and 6am next day, for both drivers.
Posted: Mon Apr 23, 2012 2:03 pm
But, is the PWM supposed to be at 80% overnight?
Posted: Mon Apr 23, 2012 2:43 pm
by d0lph1n
probably you don't remember, I have 2 drivers and 2 lights. Each light has A&D circuits. Practically, the drivers are shared by the lights ..on opposite schedule.
Posted: Mon Apr 23, 2012 3:09 pm
Ok, in this case, we will have to do some other logic.
Try this code and let me know if it works:
  ReefAngel.Init();
    ReefAngel.PWM.SetDaylight(PWMSlopeOvernight(22,0,6,0,0,80,240,0));
    ReefAngel.PWM.SetActinic(PWMSlopeOvernight(22,0,6,0,0,80,180,0));
byte PWMSlopeOvernight(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
  unsigned long Start = previousMidnight(now())+NumMins(startHour, startMinute);
  unsigned long StartD = Start + Duration;
  unsigned long End = nextMidnight(now())+NumMins(endHour, endMinute);
  unsigned long StopD = End - Duration;
  if ( now() >= Start && now() <= StartD )
    return constrain(map(now(), Start, StartD, startPWM, endPWM),startPWM, endPWM);
  else if ( now() >= StopD && now() <= End )
    byte v = constrain(map(now(), StopD, End, startPWM, endPWM),startPWM, endPWM);
    return endPWM-v+startPWM;
  else if ( now() > StartD && now() < StopD )
    return endPWM;
  // lastly return the existing value
  return oldValue;
Posted: Tue Apr 24, 2012 8:34 am
by d0lph1n
Thanks Roberto. I'll test it tonight.
Posted: Tue Apr 24, 2012 1:11 pm
by d0lph1n
I tested it and at midnight the ap/dp values go to zero. this is the code:
// Autogenerated file by RAGen (v1.2.2.171), (04/14/2012 20:36)
// RA_041412_2036.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
ReefAngel.FeedingModePorts = Port4Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port1Bit | Port2Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
ReefAngel.PHMin=542;
ReefAngel.PHMax=838;
ReefAngel.TempProbe=T1_PROBE;
ReefAngel.StandardLights(Port1,10,0,19,0);
ReefAngel.StandardLights(Port2,22,0,6,0);
ReefAngel.StandardFan(Port5,787,793);
ReefAngel.StandardHeater(Port7,775,785);
ReefAngel.StandardATO(Port8,60);
if (ReefAngel.Params.Temp[T2_PROBE] >= 1200 || ReefAngel.Params.Temp[T3_PROBE] >= 1200) ReefAngel.Relay.On(Port6);
if (ReefAngel.Params.Temp[T2_PROBE] < 1100 && ReefAngel.Params.Temp[T3_PROBE] < 1100) ReefAngel.Relay.Off(Port6);
return endPWM;
return oldValue;
Posted: Tue Apr 24, 2012 1:59 pm
I changed the function.
It should work now
  unsigned long Start = previousMidnight(now())+((unsigned long)NumMins(startHour, startMinute)*60);
  if (hour()<startHour) Start-=86400;
  unsigned long StartD = Start + (Duration*60);
  unsigned long End = nextMidnight(now())+((unsigned long)NumMins(endHour, endMinute)*60);
  if (hour()<startHour) End-=86400;
  unsigned long StopD = End - (Duration*60);
    endPWM);
    endPWM);
    return endPWM;
  return oldValue;
Posted: Tue Apr 24, 2012 2:22 pm
by d0lph1n
Binary sketch size: 32,378 bytes (of a 32,256 byte maximum)
processing.app.debug.RunnerException: Sketch too big;
Posted: Tue Apr 24, 2012 2:52 pm
You must have more than those features shown on your code.
Those defines are just comments from the time the code was generated.
You must have enabled some other feature since then.
Make sure you only use those.
Posted: Tue Apr 24, 2012 3:40 pm
by d0lph1n
I don't know what to do. This is all the code I have. RAgen features
wifi
date/setup
version
display ap/dp
font 8x8
this is the code i'm trying to upload:
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define FONT_8x8
ReefAngel.Init();
Serial.print(now());
Serial.print("-");
Serial.print(Start);
Serial.print("-");
Serial.print(StartD);
Serial.print("-");
Serial.print(StopD);
Serial.print("-");
Serial.println(End);
endPWM);
endPWM);
return endPWM;
return oldValue;
Binary sketch size: 33,622 bytes (of a 32,256 byte maximum)
Posted: Tue Apr 24, 2012 3:52 pm
remove the date/time and font8x8
and add simple menu
Posted: Tue Apr 24, 2012 4:23 pm
by d0lph1n
1. I tried reloading my old code and it didn't work
2. I went to a dif laptop and tried to upload the old code ...it worked
3. I tried uploading the latest code from that laptop, it worked
4. I enabled web portal from ragen and tried to reload the code...failed...too big
5. disabled the web portal, save features..reload the code..same error...too big
The good news , your code is working..the PWMSlopeOvernight works
The bad news, I can't compile & upload the code..what to do?
..and 10.0.2.22:200/wifi page is generating massive flood of:
1335312804-1335304800-1335319200-1335319200-1335333600
1335312804-1335304800-1335315600-1335322800-1335333600
Posted: Tue Apr 24, 2012 4:47 pm
Sorry... My bad... I left stuff in the code that wasn't supposed to be there.
It was my debugging code :(
Remove these lines:
Serial.print("-");
Serial.print("-");
Serial.print("-");
Serial.print("-");
To get the code to compile, open RAGen.
Go to features tab
Make sure you only have these checked:
Wifi
Watchdog Timer
Simple Menu
Version Menu
Display LED PWM
Click the save button
Now upload your code.
Posted: Sun May 06, 2012 6:16 am
by d0lph1n
Sorry, I didn't see your last reply.
Meantime, I bought a proper router. I'll check again the wifi module in the next few days. Thanks
Posted: Wed May 09, 2012 3:28 pm
by d0lph1n
I've fixed the wifi, I was able to connect the wifi module online, it takes ip, I fwd the port...but when i access either the internal IP:2000 or the external ip:2000 I get a blank page.
What am I doing wrong?
Posted: Wed May 09, 2012 4:44 pm
Does it work when you load the wifi test code?
File->Sketchbook->Example Codes->WifiTestCode
by binder
d0lph1n wrote:I've fixed the wifi, I was able to connect the wifi module online, it takes ip, I fwd the port...but when i access either the internal IP:2000 or the external ip:2000 I get a blank page.
Does the page just say "Reef Angel Web Server"? If so, that's correct. To get your data, you need IP:2000/wifi
Posted: Wed May 09, 2012 5:11 pm
by d0lph1n
I reloaded the code and it works now.
The iPhone app displays the correct values, there external IP too.
But the web portal shows zero values (Check my signature)
What am I missing here?
Posted: Wed May 09, 2012 5:23 pm
Good.
You need to add the Portal() function to your code now.
ReefAngel.Portal("d0lph1n");
Posted: Wed May 09, 2012 5:48 pm
by d0lph1n
Great. Thanks. It's working.
Posted: Thu May 10, 2012 8:58 am
by d0lph1n
is it possible to display the pwm values and labels on the local interface ip:2000/wifi?
Posted: Thu May 10, 2012 9:03 am
by binder
d0lph1n wrote:is it possible to display the pwm values and labels on the local interface ip:2000/wifi?
No, it's not currently possible. It could be done but that page hasn't been updated for a while. Roberto would have to update it on the server to change it.
Posted: Thu May 10, 2012 9:11 am
by d0lph1n
I didn't know it's running code from the reefangel site:
<script language='javascript' src='http://www.reefangel.com/wifi/ra1.js'></script>
K. I'll be waiting for Roberto to update it. Thanks
It's in my list to do :)
I want to make it the same as the portal page
Posted: Sat Jul 28, 2012 1:28 pm
by d0lph1n
hey Roberto,
What's the default Actinic/Daylight PWM value outside the PWMSlop schedule or how can i set it the default value to zero. Thank you
Posted: Sat Jul 28, 2012 1:30 pm
The last parameter on the PWMSlope defines the returned value for outside the slope schedule.
Simply set it to 0.
Posted: Sat Jul 28, 2012 1:32 pm
by d0lph1n
Great. This is how it's setup right now. I just wanted to make sure. Thanks
