tunze controllable pumps
Bryan
Re: tunze controllable pumps
Post by Bryan »
Later tonight I will first scope the outputs of the Tunze controller and see what it.
-=Bryan=-
Bryan
Post by Bryan »
Roberto:
Ok, here is the scope results from my 7091 controller. The minimum running voltage for the Tunze is supposedly 30%, which seems to jive with the scope at 3.9v. What is odd is the Full ON voltage was only 7.3, thought it would be 10v, perhaps it's my controller. Would have thought full power would be 10v
The pics should be self-explanatory. Does this help.?
-=Bryan=-
Nice!!!
Thanks Bryan!!!
Just to confirm:
Pin 1 - PWM signal
Pin2 - GND
Is it correct?
Oh, and to explain your question, with PWM signals, the receiver (pump in this case) usually doesn't care how much voltage the controller is sending.
Meanwell drivers are an exception though. They actually built it so it does matter. My theory is that they wanted to make convertion between D and P very simple, so the core electronics actually checks analog signals, instead of just PWM.
So for the receiver, what matters is how long the "Pump On voltage" in your design, stays at that level.
I'm guessing the pump only looks as if is it above 5V or below 5V to determine 0 or 1 binary state.
Bryan
Post by Bryan »
rimai wrote:Oh, and to explain your question, with PWM signals, the receiver (pump in this case) usually doesn't care how much voltage the controller is sending.
Hi Roberto:
I don't think I explained myself and should have documented the scope picture better, but from the picture of the 7091 there is three knobs, Pulse, power1 and power 2. Pulse sets the duty/switching rate between power 1 and power 2. Power 1 setting is between 30-100% in voltage. Power 2 is the same 30-100%. (tunze pumps can't be run below 30%). So in summary the pump will run at 100% for
So from the scope pic Power 1 is on for roughly 2.5 seconds (Pump On time in picture) and at a voltage of ~7.5v (was set to MAX for the test), then it switches to Power 2 for approx 1.75s (Pump Off time in picture) for a voltage of ~3.9v (was set to MIN for the test). Not sure how u would use PWM to control this. Basically the driver needs a voltage from the controller at 0-10v, although my 7091 peaks at around 8v, so I may have that point wrong.
So in summary what u are seeing on the scope is the pump running at full power for 2.5 seconds and then at minimum power for 1.75s. Full power being 7.9v and low power being 3.9v.
Hope this helps
-=Bryan=-
Bryan
Post by Bryan »
rimai wrote:Nice!!!
Thanks Bryan!!!
Just to confirm:
Pin 1 - PWM signal
Pin2 - GND
Is it correct?
Sent PM
-=Bryan=-
Bryan
Post by Bryan »
Hope this helps
Just to add, if I set the power 1 and power 2 knobs to MIN for both the scope would displaya flat line at 3.9v, if set to MAX for both Power 1 and Power 2 the scope would display a flat line of 7.9v.
So if the power 1 and power 2 are set identical there is no switching that takes place between the pumps, as they are running at identical voltage..
-=Bryan=-
Thanks Bryan.
I now understand how they work and I can say for sure it is not PWM, but analog signal.
Bryan
Post by Bryan »
Yup, afraid so, so don't think it would be a easy task on the existing RA hardware.
-=Bryan=-
Oh no, it's still pretty simple.
All we need to do is smooth down the PWM signal.
We already have 0-10VDC PWM signal.
The cable assembly only needs a resistor and a capacitor, which is fairly simple to do.
Tunze pinout
Xender
Post by Xender »
Hi
Do you think I can DIM my TUNZE Nano-Stream 6025 with one of the two PWM channel on the relay box?
Thanks.
Salt Water Aquarium 60*60*60
I sent a cable to cain to test, but it did not work.
Without having one with me to test what kind of load is being applied by the Tunzes on the RC filter I created, it is hard to find out which values to use.
I tried 1uF and 10K and it did not work.
In theory, all you need is to do is convert the PWM signal to analog and plug it in on the Tunze connector.
cain
Post by cain »
Xender wrote:Hi
Thanks.
NO, since a 6025 is not controllable.
Xender
Post by Xender »
thanks cain
symon_say
Post by symon_say »
Have anybody found a solution to control tunze pumps??
I can give it another try.
My last attempt was unsuccessful, but I'm pretty sure I know how to fix the problem now.
PM me if you would like to test the module?
hylik
Post by hylik »
i maybe interested on this module too if it become available
bluwinghawk
Post by bluwinghawk »
following
Ok, so I got ahold of a Tunze :)
I was able to control it this time!!!
Requires the analog dimming version of relay box.
abhi_123
Post by abhi_123 »
rimai wrote:Ok, so I got ahold of a Tunze :)
Which model number of tunze pump mate?
I'll check when get home.
J_C
Post by J_C »
Awesome, so when can I start controlling my 6055?
abhi_123
Post by abhi_123 »
bad luck man.
You should have an idea by looking at the controller, right?
abhi_123
Post by abhi_123 »
do we need tunze controller to control their wavers or simply by using analog RA?
You need their controller.
I mean, you need their driver
abhi_123
Post by abhi_123 »
i was looking into their site havnt find there anything related to drivers.
