Page 1 of 2
Re: Resolution of RF Vortech command
Posted: Sun Nov 04, 2012 4:35 pm
by dedvalson
Hi,
I finally got time to put the new firmware in the RF Module. I ran into several issues with it.
1. In Mode 12 (short pulse) the pulse speed isn't consistent. It seems to pulse 3-4 times at the correct speed and then hesitate and them 3-4 again.
2. Mode 14 doesn't seem to work at all. It will work for a few cycles and then "get stuck". When I power the RA down and up again it will run for a few cycles again and then stick.
3. After uploading the RF module, I now have trouble uploading to the RA. The upload appears to work, but then it reads back a ton of data (takes several minutes) and then says the data doesn't match the upload. The upload seems to work fine. I tried re-installing the RA software but it didn't make any difference. Some setting must have been changed.
Don
Posted: Sun Nov 04, 2012 5:49 pm
I don't think #3 is related.
Can you restore the RF back to original firmware?
Posted: Sun Nov 04, 2012 9:21 pm
Ok, so I went and sniffed the driver to confirm.
The driver cannot do any less than 60ms resolution.
It broadcasts data every 60ms.
So, let's take the short pulse as an example...
With 12 bubbles, it takes the driver 21 broadcasts to invert from 0% to 100% and another 21 broadcasts to invert back from 100% to 0%, making a total of 42 broadcasts, which is equal to 2.52s
With 1 bubble, it takes 4 broadcasts each for a total of 8, which gives 0.48s
0.24s is the minimum you can have each half of the cycle.
It explains why it is skipping cycles.... We were trying to send data too fast and overshooting ourselves.
Posted: Mon Nov 05, 2012 4:51 am
by dedvalson
rimai wrote:I don't think #3 is related.
I don't think this is related to the RF firmware at all. I think some setting got changed when I unzipped the software to update the RF firmware. Is there a file that tells how to manage the upload? I think it is trying to do a verification of the uploaded code that it didn't used to do.
I just wondered where that setting might be so I can fix it.
Don
Posted: Mon Nov 05, 2012 4:59 am
by dedvalson
rimai wrote:Ok, so I went and sniffed the driver to confirm.
Hi,
I assume that a "bubble" in this case means intermediate speeds that are sent out, so that the speed is ramped up and then back down instead of "on" and "Off". Is that correct?
Is the 60ms number a characteristic of the Ecotech RF environment or the RA RF Module firmware? It seems like that when one Vortech controls the othe Vortech the available resolution is very high. The steps from one speed to another are imperceptable and that allows me to tune the speed to cause standing waves in the system.
I am guessing that what the Vortech must do is that it goes ahead and uses a smaller number of "bubbles" but varies the timing of them. For instance, if it takes 60 mSec to send a command, you can send a command every 60 mSec or every 65 mSec or every 70 mSec, giving you 5 mSec resolution. I think that they must be varying the "dead" time between the commands.
I am quite familiar with low level firmware of this nature and would be glad to help work on this if you would like.
Don
Posted: Mon Nov 05, 2012 9:18 am
The bubble I mentioned is the led lights in the driver.
There are 12 leds for that goes up as you increment the duration.
The 60ms is default and does not change. It only sends every 60ms, no matter which duration you have.
It sends a payload every 60ms for every mode actually, even the constant mode.
So, there is no variation of "dead" time.
What we can do though is make it a uneven waveform.
I did see this in the sniff too, but I thought it was a glitch.
Let's use the lowest level as an example. It changes speed every 4 broadcasts, which is 240ms with total cycle at 480ms.
The master sometimes would change speed with 5 broadcasts for on time and 4 for off time, which would make the cycle be completed in 9 broadcasts, instead of 8 resulting in a total cycle duration would be 540ms.
Posted: Mon Nov 05, 2012 10:15 am
by dedvalson
So I gather that what you are telling me is that the master sends a "current speed" to the slave every 60 mSec, is that correct?
What I am seeing though on the Vortech Master is much finer control than 60 mSec intervals.
Based on that, I wonder if maybe the Vortech master is using non-integral number of broadcasts per cycle. By that I mean that the master could creates a waveform of some arbitrary frequency determined by the current pulse settings. That wave could then be "sampled" every 60 mSec and the result sent to the slaves. That way the pulse cycle could be any frequency, not just a multiple of 60 mSec, much like digital audio can be any frequency, not just a multiple of the sampling frequency.
Does that make any sense?
Don
Posted: Mon Nov 05, 2012 10:34 am
Yes, correct. The master sends the current speed every 60ms.
The slave becomes a dumb terminal when it is set as slave... It can only do what it is told :(
If the master stops sending data, the slave stops at its last state.
So, the master needs to send what speed the slave needs to be at any given time.
Posted: Mon Nov 05, 2012 10:38 am
However, now thinking of it, we can make it a really fine tuning machine.
We don't really need to send the payload every 60ms.
We can send it at whatever frequency we want.
So, if we send a payload to put the slave at 0% and send another payload to put the slave at 100% after 342ms, we got a really precise control of the cycle.
What do you think?
Posted: Mon Nov 05, 2012 11:22 am
by dedvalson
That makes sense to me.
That was kind of what I meant by the "dead time". If it takes 60 ms send a command then we wait 5 ms that is a 65 msec cycle. Your example would be a 282 msec dead time (342 - 60).
I wonder if the slave mode isn't more active in the "Smart" modes. I ask that only because the slave flashes white / orange / teal in the ecosmart modes where it is on solid in the other modes.
Don
Posted: Wed Nov 07, 2012 2:00 pm
by dedvalson
Would you like me to take a look at doing this?
Don
Posted: Fri Nov 09, 2012 10:00 am
I'll try to get something put together over the weekend.
Posted: Sun Nov 11, 2012 12:22 am
Try this one.
Use mode 12 (Short Pulse).
It is still using 8ms resolution.
The minimum pulse is 240ms, which would be duration=30.
Posted: Sun May 19, 2013 8:24 am
by dedvalson
So, more than six months later I finally get back to you on this. Life has been very busy.
Anyway, I downloaded and installed the 1.1 code above and tried running it in Short Pulse mode (12). It appears that it isn't much different from the previous version. The original modes still work fine, but the High Resolution modes (12-14) are sporadic, like we are still missing commands. In mode 12 the Vortech works fine if the duration is set to 30. But if I set it to 31, misses every 5th or 6th cycle.
So it works, but is not regular, it is sporadic.
Don
Posted: Sun May 19, 2013 9:03 am
by dedvalson
It also appears that mode 14 does not work at all. It just turns on and stays on.
Don
Posted: Mon May 20, 2013 10:41 am
Just to try to replicate the same stuff, which libraries version are you running?
Posted: Mon May 20, 2013 1:39 pm
by dedvalson
It looks like 1.0.7.
I can easily change that if it would help.
Don
Posted: Thu May 23, 2013 10:07 am
I did not have time to look into this and test yet, but I'm pretty sure it is because of the Radion integration.
Can you try commenting line 791 on ReefAngel.cpp??
https://github.com/reefangel/Libraries/ ... l.cpp#L791
Posted: Sat May 25, 2013 7:28 am
by dedvalson
You were right. That Fixed Mode 12 (and Probably Mode 13, I didn't test it). But Mode 14 is still totally dead.
This is great, now I can make big waves in the aquarium.
I would love to get 14 going though. If you would like, I can help with that.
Don
Posted: Sat May 25, 2013 9:09 am
14 is long wave. Isn't the original 4 good enough?
It doesn't need the same precision as the 12, right?
I've logged the issue for the Radion integration
https://github.com/reefangel/Libraries/issues/99
Posted: Sat May 25, 2013 2:17 pm
by dedvalson
13 is long pulse, 14 is NTM, at least that is what you had said earlier. I was hoping for an accurate NTM.
Posted: Sat May 25, 2013 3:51 pm
What is the duration you are trying?
Posted: Mon May 27, 2013 7:14 am
by dedvalson
Duration is 68, Speed is 70, Mode is 14.
Posted: Tue Jun 25, 2013 11:08 am
by dedvalson
Any progress on this
Posted: Wed Jun 26, 2013 4:57 am
by dedvalson
If you would like me to, I could look at the firmware for the RF module and see if I can fix this.
Don
Posted: Wed Jun 26, 2013 8:19 am
I'll try to check over the weekend.
Without a RF sniffer, you won't get far :(
Posted: Fri Jul 05, 2013 3:07 pm
Try this one.
