Page 1 of 3
Re: I can't find the WifiSendAlert() function in the librari
Posted: Tue May 21, 2013 9:43 pm
by mudcat1
Roberto or Lee,
Did you ever finish the coding for WifiSendAlert that will allow me to add a few custom SMS alert messages? If so, will it be released in the next library version? Or is it available for download on github?
I can't find the WifiSendAlert() function in the libraries.
Posted: Wed May 22, 2013 5:23 am
Havent had time to touch it yet, but you should be able to modify the url being called to hit the new page and then send whatever custom message you like :)
Posted: Fri May 24, 2013 7:45 pm
by mudcat1
lnevo wrote:Havent had time to touch it yet, but you should be able to modify the url being called to hit the new page and then send whatever custom message you like :)
Sorry Lee, I don't understand what you mean. Do you want me to copy these statements somewhere after my condition that determines when to send the SMS alert?
Serial.print("GET /status/alert.asp?e=314123456@vtext.com&id=");
Serial.println(alert_status,DEC);
Serial.println("\n\n");
I need a little more to go on.
John
Posted: Sat May 25, 2013 1:12 am
rimai wrote:Ok, I created a new webpage wifialert.aspx
It will use the same email address set on your portal notifications.
Parameters:
id - your forum username
key - your portal key (optional)
msg= your custom message
Just be careful not to spam your own mailbox.
You have to use this new wifialert.aspx
Change the line you have that calls alert.aspx to the new syntax above.
Maybe I'll have some time next week to play with this...
Posted: Sat May 25, 2013 10:57 am
by mudcat1
Parameters:
Lee,
Thanks for the clarification.
Posted: Sun May 26, 2013 11:05 pm
by mudcat1
I still can't figure out how to use wifialert.aspx. When I compile it says it has not been declared. Can someone please provide an example of how the wifialert.aspx is used in the sketch.
thanks,
John
Posted: Mon May 27, 2013 2:02 am
Did you not have it working with the other page before?
Posted: Mon May 27, 2013 10:47 am
by mudcat1
lnevo wrote:Did you not have it working with the other page before?
Yes, the WifiSendAlert() function was working, but I am not sure how to pass the parameters that you and Roberto suggested in this section of the code.
I am assuming that you wanted me to replace "alert.asp?" with "wifialert.aspx", but I am not sure how to specify the ID, Key and Message parameters.
I was hoping that you or Roberto could supply some sample code that I could modify.
John
Posted: Mon May 27, 2013 12:58 pm
Try this:
Serial.print("GET /status/wifialert.aspx?id=mudcat1&msg=ato_alert");
Posted: Mon May 27, 2013 1:00 pm
You can comment the second line as well. I'm going to work on this soon where you can pass the alert string to the function.
Posted: Mon May 27, 2013 7:08 pm
Ok, the previous function was using a byte to hold 8 bit flags on when an alert was sent or not. It also had a delay(900) which should be avoided if possible. I created a new class called WiFiAlert that stores when it was last sent and waits a set delay. Each class you instantiate will maintain its status. So you will need to declare one for each type of alert you want to send.
Usage looks like this:
// This line in globals or declared as a static
WiFiAlert atoAlarm;
// This part inside loop()
if (ReefAngel.LowATO.IsActive()) {
  atoAlarm.Send("Sump_WaterLevel_is_low");
You can also pass a portal key as a second argument to Send(). Also since this gets translated to a web request you can not have spaces. You will need to use %20 or + if you want a space. You should also be able to use strcat to build a custom message to the alert. Like if you want to add your params or debug info. Is streams in the arduino libraries yet?? :)
Here's the code. I have not tested it yet... :)
class WiFiAlert
public:
  WiFiAlert();
  void Send(char *message, char *key);
  inline void Send(char *message) { Send(message,""); }
  inline void SetDelay(int delay) { AlertDelay=delay; }
private:
  int AlertDelay;
  time_t LastAlert;
  boolean IsAlert();
  void WiFiSendAlert(char *message, char *key);
WiFiAlert::WiFiAlert()
  AlertDelay=900;
  LastAlert=0;
boolean WiFiAlert::IsAlert()
  if (now()-LastAlert >= AlertDelay)
    return true;
  return false;
void WiFiAlert::Send(char *message, char *key)
  if (IsAlert())
    LastAlert=now();
    WiFiSendAlert(message, key);
void WiFiAlert::WiFiSendAlert(char *message, char *key)
  Serial.print("GET /status/wifialert.aspx?id=");
  Serial.print(ReefAngel.portalusername);
  Serial.print("&key=");
  Serial.print(key);
  Serial.print("&msg=");
  Serial.println(message);
Posted: Mon May 27, 2013 7:48 pm
by mudcat1
Thanks Lee. I attempted to modify the original code using your previous suggestions but I could not get it working correctly. I also only have a Reef Angel basic so I kept getting the sketch too large error. I will try your new code and let you know how it works out.
Thanks again for your assistance,
John
Posted: Mon May 27, 2013 7:52 pm
My code may not be basic version friendly..especially if your already close to memory limits.
Posted: Mon May 27, 2013 9:35 pm
by mudcat1
Lee,
This code goes beyond my current level of knowledge. I have not used the class statement in any of my previous sketches so I am not sure exactly where to place it in my sketch. I copied the code section that begins with class at the end of my sketch. When I compile it, I receive the error "'atoAlarm' was not declared in scope".
Here is where I placed the other code within my loop.
   if (!ReefAngel.LowATO.IsActive() && ( hour() >= 7 && hour() < 22)) {
      atoAlarm.Send("ATO_container_is_empty");
 } else {
      ReefAngel.PWM.SetDaylight(0);
      if (!ReefAngel.HighATO.IsActive()) {
        atoAlarm.Send("Sump_WaterLevel_is_to_high");
    } else {
Posted: Mon May 27, 2013 10:44 pm
You shouldnt have to escape the quotes. You should be getting an error where you declare atoAlarm. Try pasting it above the setup function. It may need to be moved to its own files. Like i said, havent tried yet.
I updated my ino to use it, ill try compiling it up tomorrow..
Posted: Tue May 28, 2013 6:06 am
Ok, I had one typo needed a ; after the class statement. Anyway a class is not much different from a struct except that it has functions (methods) tied to it and not just variables.
In any event, I tested just pasting this to the top of my code and it compiles nicely. Just put it after your includes.
Edit: Was also missing the declaration for the constructor (the WiFiAlert() function)
Posted: Tue May 28, 2013 8:03 am
mudcat1 wrote:Lee,
} else {
} else {
One thing to note is you are using the same instance "atoAlarm" for two conditions. If they both happen at same time you will only be alerted for the first. But that isn't the cause of your errors. I believe it's where you are declaring the atoAlarm object.
Posted: Tue May 28, 2013 11:15 am
Ok, I have this compiling properly now as a seperate entity. You can either download the attached file and just #include it, you can copy the code above and paste it in the top of your INO, or you can checkout the wifialert branch from my github repo http://github.com/lnevo/Libraries.
The one added to the Repo also adds a portalkey variabe to the ReefAngel class and so I took out the functions that Send using a key. This way you set your portal key once when you do a SendPortal and the function uses it if it's there.
I'll be uploading this code later today. I've converted all the alerts that I was using CustomVars for to use this method now. I've also add a few alerts to some of my interactive functions like RefillATO and AutoWaterChange. We'll se force if these stay.
The only thing that I've yet to do is add support for sending an all clear. If it happens within the delay then it won't send an alert so not very useful, yet I'd like to know when it's all set. I could instantiate another alert type but at the same time, we don't want an all good status to keep sending either... so I may add a ForceSend, or a boolean to Send to tell it not check LastAlert. You'll want to be careful with using any type of force though so I like the idea of the seperate function for it...
Anyway, feedback, comments, etc are welcome.
Posted: Tue May 28, 2013 11:40 am
Well, my first alert test didn't work. Will need to check the serial output to see whats going on...
Posted: Tue May 28, 2013 12:57 pm
by mudcat1
Lee,
I copied the code to the top of my INO file after the #include statements. I tested the sump overflow first without attaching the wifi attachment so that I could see the serial monitor output as you suggested. This was logged...
GET /status/wifialert.aspx?id=mudcat1&key=&msg=Sump_WaterLevel_is_to_high
Which is what I would have expected. Unfortunately when I attempted to try it a second time nothing else appeared in the serial monitor log. Is it designed to send only one alert and then it needs to be reset? I also tried the ATO container empty but it did not send an alarm either.
I powered off the Reef Angel and performed a subsequent test of the ATO container empty test and it also worked correctly the first time sending GET /status/wifialert.aspx?id=mudcat1&key=&msg=ATO_container_is_empty.
But again if I tested perform another test immediately it did not send a second alert. I will hook up the wifi attachment and perform the test to see if I receive the SMS page.
John
Posted: Tue May 28, 2013 1:07 pm
by mudcat1
Lee,
Using the portal will it send the alert immediately or does it delay it some period of time (ex. 5 minutes or 1 hour)? I did not receive the immediate SMS text as I expected. I manually tested sending an SMS text using the email address that I specified in the portal and received the text within a few seconds.
Posted: Tue May 28, 2013 1:08 pm
Its set to only page once every 15 minutes. You can change it with .SetDelay(int)
I wonder if the empty key is causing an issue. Can you try appending that output to http://forum.reefangel.com and see if you get a page? Try without the &key=
Posted: Tue May 28, 2013 1:11 pm
mudcat1 wrote:Lee,
Yeah this is the part that didn't work for me either. The serial output looks good though except for the empty key.
I need to look at the original code again and make sure I didn't miss anything.
Posted: Tue May 28, 2013 1:35 pm
by mudcat1
lnevo wrote:Its set to only page once every 15 minutes. You can change it with .SetDelay(int)
Lee,
I did not see your message in time. I added a portal key to see if that might be the issue. It will take me a few minutes to put it back to its original state. But i did just try your suggestion...
http://forum.reefangel.com/status/wifia ... with%20key
...with a portal key and the portal did send me a SMS text message.
Posted: Tue May 28, 2013 1:39 pm
Alright, i know the page works and i know the code is working to some degree...we'll get this going tonight... :)
Posted: Tue May 28, 2013 1:41 pm
by mudcat1
Lee,
I also tried sending this command after removing the portal key.
wifialert.aspx?id=mudcat1&msg=Test%20without%20key (URL trimmed to prevent spam)
It successfully sent the SMS text too.
Posted: Tue May 28, 2013 2:02 pm
I tested also with a blank key and it was fine...so our syntax is good...
Posted: Tue May 28, 2013 4:53 pm
Roberto... I think this time it's your fault ;)
If I go to the IP that is set on the wifi module and try the URL I'm generating, I get a 404 that the resource is not found...
URL removed to prevent spamming!
If I use forum.reefangel.com which is a different IP it works. So it looks like we just need to copy the aspx file over... hopefully simple :)
Posted: Tue May 28, 2013 5:12 pm
I think you are right :oops:
I'll fix it shortly....
Posted: Tue May 28, 2013 5:20 pm
Cool. I think that should take care of the issue :) Btw, I also added a force option just do object.Send("Msg",true); and it will bypass the time check. Make sure you put some type of flag that this was done once. I am using it for my power outage check. So it's nice to know when power is restored. I'm sure others will find good use for it.
Also, some notices, I needed a lot less time (30 seconds...during WC mode...) between notifications or wanted a lot more time (like once per hour), so the SetDelay should be nice feature for all of those. The default in the class is currently 15 minutes.
