Page 1 of 2
Re: Reef Angel Malfunctioning
Posted: Mon Sep 23, 2013 7:29 am
I'm going to lower the refresh rate in the libraries to see if we can get better results.
Posted: Mon Sep 23, 2013 10:19 am
by ecam
Okay FYI.
Im not sure if this is relevant. But its never happened before. After removing the RF switch I went out. I came back home around 3:15pm to see my fish tank in the dark (the lights don't go out till 8:15). The head unit was saying the time was 8:30pm. I promptly pulled the plug and its been working fine since.
As for the library update please let me know when i can but the RF switch back online.
Posted: Wed Sep 25, 2013 8:57 am
by ecam
Roberto, any updates?
Posted: Wed Sep 25, 2013 9:51 am
It is going to be on the next release.
There is no target date for next release yet though.
Posted: Wed Sep 25, 2013 12:29 pm
by ecam
So is there anything I can do for my RF module. or is it just useless, till the new update (say it aint so Roberto). I really like my mode switching.
Please help!!!!
Posted: Wed Sep 25, 2013 1:29 pm
Try to find out where you are picking up the noise that is causing the issue.
I also checked the libs code and found out that if you use UseMemory=false, which I think you are, you can change the refresh yourself.
Can you post your code?
Posted: Thu Sep 26, 2013 5:32 am
by ecam
here you go roberto. Also what noise are you referring to for the RF switch. The only change to my setup has been that I now run 4 MP40s as opposed to 2.
#include <RF.h>fa
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
  ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
  ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
    // Setup ATO Port for AI communication
    ReefAngel.AI.SetPort( lowATOPin );
{   //Port1 Return pump...  on all the time!!!
    ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge
ReefAngel.Relay.Off( Port3); // Start with the relay off
if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Port3); // Moonlight Between 5-10am turn the relay on
if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Port3); // From 8pm-Midnight turn the relay on
   ReefAngel.StandardLights( Port4,10,0,20,0 ); //ATI Actinic
    ReefAngel.StandardLights( Port5,11,0,19,0 );  //ATI Daylight
    ReefAngel.StandardLights( Port6,10,0,20,0 );  //ATI Fan
    ReefAngel.StandardHeater( Port7,778,790 ); //Heater
    ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
//    ReefAngel.AI.SetChannel( White, PWMParabola(11,0,17,0,0,75,0) );
//    ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,0) );
//    ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(9,0,20,0,15,100,(MoonPhase()/5)<3 ? 3:MoonPhase()/5) );
    ReefAngel.RF.SetMode( ReefCrest,85,10 );
  //  ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
  //  ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
  //  ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
  //  ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
  //  ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
 //   ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,94,15) );
  //  if ( second()==0 ) ReefAngel.RF.RadionWrite();
if (hour()>=6 && hour()<11)
  ReefAngel.RF.SetMode(ReefCrest,85,10);
else if (hour()>=11 && hour()<13)
else if (hour()>=13 && hour()<16)
  ReefAngel.RF.SetMode(Smart_NTM,85,15);
else if (hour()>=16 && hour()<19)
  ReefAngel.RF.SetMode(ReefCrest,65,10);
  ReefAngel.RF.SetMode(Lagoon,40,10);
    // Hardcode PH calibrations
     //ReefAngel.PHMin=544; // PH7.0
     //ReefAngel.PHMax=830; // PH10.0
    ReefAngel.Portal( "ecam" );
    int x,y;
    // Aqua Illumination
    x = 10;
    y = 20;
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
    for ( int a=0;a<3;a++ )
      ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
      x += 38;
    ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
Posted: Thu Sep 26, 2013 9:04 am
To use the new code, you will need to return the RF module to the original firmware.
Posted: Thu Sep 26, 2013 9:05 am
Try this code:
#include <RF.h>fa
byte myRFMode=0;
byte myRFDuration=0;
byte myRFSpeed=0;
  //  ReefAngel.RF.UseMemory = false;
  //  ReefAngel.RF.SetMode( ReefCrest,85,10 );
    myRFSetMode(ReefCrest,85,10);
    myRFSetMode(Smart_NTM,85,15);
    myRFSetMode(ReefCrest,65,10);
    myRFSetMode(Lagoon,40,10);
  int x,y;
  x = 10;
  y = 20;
    x += 38;
void myRFSetMode(byte m, byte s, byte d)
  if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
    myRFMode=m;
    myRFSpeed=s;
    myRFDuration=d;
    ReefAngel.RF.SetMode(m,s,d);
Posted: Thu Sep 26, 2013 10:28 am
by ecam
rimai wrote:To use the new code, you will need to return the RF module to the original firmware.
Roberto, i was regarding in one of the post that you thought the dimming home might be having adverse affects with the Angel. Should i try disconnect the hub and finding out if that works?
http://forum.reefangel.com/viewtopic.php?f=12&t=3865
Cause this same thing happened to me last weekend. With the time changing on me.
Posted: Thu Sep 26, 2013 10:46 am
Yes, same problem. It's related to the expansion bus signal.
The 2 modules that can do that are the old dimming module and the RF module.
But if you replaced the twi.c, you should not see the controller blinking and the time changing. Your controller should reboot instead.
I'm thinking some interference noise is causing your RF module to lockup, which causes all that.
Posted: Thu Sep 26, 2013 10:56 am
by ecam
rimai wrote:Yes, same problem. It's related to the expansion bus signal.
What kind of interference, am i looking for?
I haven't really added any electric devices in my tank area, expect for the new MP40s and your new modules
Posted: Thu Sep 26, 2013 3:31 pm
by ecam
rOBERTO I RAN THIS UPDATE I SAW THE INITIAL 3 LIGHT FLASH AND THE ENDING AND NOTHING IN BETWEEN.. dID IT WORK?
Posted: Thu Sep 26, 2013 3:50 pm
Yes, that's how the original firmware is.
Posted: Sat Sep 28, 2013 7:01 pm
by ecam
Roberto just happened again with the old firmware restored. Any other ideas?
Posted: Sat Sep 28, 2013 7:54 pm
Did you load the code I posted?
Does it work ok without the RF module?
Posted: Sat Sep 28, 2013 8:32 pm
by ecam
yes to both
Posted: Sat Sep 28, 2013 9:59 pm
What is it actually doing?
Posted: Sat Sep 28, 2013 10:45 pm
by ecam
Dont understand the question.. but will try to answer a few possible version;
When the RF module fails. It puts my RA into a flashing red status on the head unit at which points it no longer takes instructions. whatever it is doing at the time of the freeze will continue. (i.e: my lights were on for over 18 hrs one day!!!! i disconnect the module and everything goes back o normal.
Posted: Sat Sep 28, 2013 10:46 pm
by ecam
    #include <DS1307RTC.h>fafa
    #include <RF.h>fa
      byte myRFMode=0;
        byte myRFSpeed=0;
    //    ReefAngel.AI.SetPort( lowATOPin );
        ReefAngel.Relay.On( Box1_Port2 );  // Razor Led
        ReefAngel.Relay.On( Box1_Port4 ); // Sump Equipment - UV, Pump
        ReefAngel.Relay.On( Box1_Port5 ); // MP40s
        ReefAngel.Relay.On( Box1_Port6 ); // JBJ
      //  Port1 Return pump...  on all the time!!!
      //  Port3 ...  not used
          //box 2
          ReefAngel.Relay.Off( Box1_Port1); // Lunar Hub Not used   Port #9
    //   Box1_Port2 Razor_LED (Sump)...  on all the time!!!      Port #10
          ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off       Port #11
                  if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
                  if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay on
    //   Box1_Port4 Ecotech MP_40 Pumps  on all the time!!!      Port #12
    //   Box1_Port5 Razor_LED (Sump)...  on all the time!!!      Port #13
    //   Box1_Port6 JBJ ATO ...          on all the time!!!      Port #14
         ReefAngel.Relay.Off( Box1_Port7);  // ALK Doser ...      Port #15
         ReefAngel.Relay.Off( Box1_Port8);  // Calc Doser ...     Port #16
    // ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
    // Define Your dosing pumps
    #define numDPumps 2
    byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8 };
    int DPVolume[numDPumps]={ 30, 30 } ; // 30ml for each alk and calcium
    int DPRepeat[numDPumps]={ 60, 60 } ; // Repeat every 60 miniutes
    // Define Calibration here
    int CalTime[numDPumps]={ 600, 600 }; // 10 minutes / 10 minutes
    int CalVol[numDPumps]={ 350, 300 }; // 350ml / 300ml
    // Function: RunDosingPumps()
    void RunDosingPumps() {
      float rate;
      int calcTime[numDPumps];
      for (int i=0;i < numDPumps; i++) {
        rate=(float)CalVol[i]/CalTime[i];
        calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
        // Run the pumps
        ReefAngel.DosingPumpRepeat(pumpRelays[i], i*20, DPRepeat[i], calcTime[i]); // Offset between each pump is 20 minutes
      // Display Time calculated in portal
      ReefAngel.CustomVar[0]=calcTime[0];
      ReefAngel.CustomVar[1]=calcTime[1];
    // Function: LogDosingPumps()
    void LogDosingPumps() {
      static time_t pumpTimer[numDPumps];
      static boolean pumpStatus[numDPumps];
      float rate;
      for (int i=0;i< numDPumps;i++) {
        if (ReefAngel.Relay.Status(pumpRelays[i])) {
          if (!pumpStatus[i]) {
            pumpStatus[i]=true;
        } else {
          if (pumpStatus[i]) {
            pumpStatus[i]=false;
            // Report How much volume has been dosed per day.
            // Could make this in minutes... excercise for the reader..
            ReefAngel.CustomVar[2]=pumpTimer[0]*rate;
            ReefAngel.CustomVar[3]=pumpTimer[1]*rate;
        // Clear timer at end of day
        if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
        int x,y;
        x = 10;
        y = 20;
          x += 38;
            myRFMode=m;
            myRFSpeed=s;
            myRFDuration=d;
here is my code with ur update
Posted: Sat Sep 28, 2013 10:58 pm
If it is still doing that, you didn't replace the twi.c correctly.
That would only happen if you didn't do it. With the one I posted earlier, the controller would reboot.
Posted: Sun Sep 29, 2013 6:25 am
by ecam
Roberto. I told you the light sequence when I uploaded. And u mentioned that it seemed like it work. Is there anyway I can ping the unit to see what version of the twi file it is running. So that we can confirm
Posted: Sun Sep 29, 2013 8:07 am
The light sequence you mentioned was in the RF module.
I'm talking about the red status led on RA.
An easy way to know is to open the head unit and move the SDA and SCL jumpers on the head unit.
They are in the vertical position now. Moving them to the horizontal position will cause the bus to lock.
Also, I just remember you should not have the Radion code either, even if commented. The auto-feature selection is enabling the code and you are just going back to square one.
#include <RF.h>fa
byte myRFMode=0;
byte myRFSpeed=0;
  int x,y;
  x = 10;
  y = 20;
    x += 38;
    myRFMode=m;
    myRFSpeed=s;
    myRFDuration=d;
Posted: Sun Sep 29, 2013 11:16 am
by ecam
So im running this code now. Removing all AI and ECOtech radion references \
    #include <RF.h>fa
      byte myRFMode=0;
        byte myRFSpeed=0;
          //box 2
         RunDosingPumps();
         LogDosingPumps();
    #define numDPumps 2
    int DPVolume[numDPumps]={ 3, 3 } ; // 1ml for each alk and calcium
    int DPRepeat[numDPumps]={ 240, 240 } ; // Repeat every 4 hrs 5x a day
    int CalVol[numDPumps]={ 350, 300 }; // 350ml / 300ml... .58 / .5
      float rate;
        // Run the pumps
      float rate;
            pumpStatus[i]=true;
        } else {
            myRFMode=m;
            myRFSpeed=s;
            myRFDuration=d;
Posted: Sun Sep 29, 2013 3:13 pm
You must remove this:
The whole idea is to not use the SetMode function and you introduced it again, which will bring you right back to square one again.
Also, make sure that your RF module is connected when you reboot the controller or it will only change mode in the next mode change time.
Posted: Sun Sep 29, 2013 3:40 pm
by ecam
Done. good thing cause it was just time-travelling on me
Posted: Thu Oct 03, 2013 12:01 pm
by ecam
Roberto, it appears that code did the trick. its been connected to the RA for a week with no issues. i will now put the pumps under the control of the RA and see what happens
Posted: Sat Apr 26, 2014 4:59 pm
by Veeresh
Hi Guys
I got my unit last month with the following configuration
RA Plus
Expansion Hub
Expansion Relay 1
Salinity Expansion
Wifi Module
RF Module
I have having the same problem. THE RA bus lock up cause the Radion Light to stay on and the Relay box also hangs. My chiller freeze the tank to below 23 C.
The moment I unplug the RF module from the Expansion hub all revert to normal. When I connect the RF module back to the Expansion hub, I have the bus lock after several hours.
I remove the Ecotech Tech pump and radion led light code and disconnect the RF module and the problem disappears.
I also tried to recompile with the old twi.c and the bus lock still up..
Can anybody help ? Could this be hardware problem ? I did not flash the RF module with the firmware because the problem still persist according to ecam...
Veeresh
version 1.1.0
Posted: Fri May 16, 2014 3:37 pm
by Veeresh
Hi Guys
I had my Hub Expansion module replaced and he problem disappear.
No more "Bus Lock Error"
Veeresh
Just Sharing
