Re: Ethernet. shield or module.
Posted: Sat Apr 05, 2014 6:01 pm
Awesome. Works a treat.
Many thanks!
https://forum.reefangel.com/
excellent! sounds like the problem is solvedsabo wrote:Awesome. Works a treat.Many thanks!
Hmmrimai wrote:This is independent of the libraries.
This code goes into the Ethernet board and not on RA.
Program: eth_websrv_page
Description: Arduino web server that serves up a basic web
page. Does not use the SD card.
Hardware: Arduino Uno and official Arduino Ethernet
shield. Should work with other Arduinos and
compatible Ethernet shields.
Software: Developed using Arduino 1.0.3 software
Should be compatible with Arduino 1.0 +
References: - WebServer example by David A. Mellis and
modified by Tom Igoe
- Ethernet library documentation:
http://arduino.cc/en/Reference/Ethernet
Date: 7 January 2013
Author: W.A. Smith, http://startingelectronics.org
#include <SPI.h>
#include <Ethernet.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 0, 0, 20); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
client.println("<!DOCTYPE html>");
client.println("<html>");
client.println("<head>");
client.println("<title>Arduino Web Page</title>");
client.println("</head>");
client.println("<body>");
client.println("<h1>Hello from Arduino!</h1>");
client.println("<p>A web page from the Arduino server</p>");
client.println("</body>");
client.println("</html>");
break;
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
