Re: Let's Build Troubadour11's Code
Posted: Thu Jul 23, 2015 7:56 am
Thanks so much for the speedy help.
I knew I had to be missing how to input the variables.
So I inserted this into my code between the heater ports and light cycle like in the example from the wizard:
Was I also correct to exclude Port7 from the "always on" list then?
And I also removed Portbit7 from the water change function since I had a different pump on here.
All right. So the code verified and looks like it's good to go. It's time for me to head off to work this morning. So I'm going to upload my modified full code and set up the vinegar dripping into a measuring cup to test it out during the day while at work. Hopefully I come home to the proper amount and will have this all set up and ready to go for my tank sitter
I'll try to report back on the results before I head out of town
Current full code:
ReefAngel.StandardHeater(Port1);
ReefAngel.StandardHeater(Port2);
////// Place your custom code below here //////
//Sets Port 7 on the Power Unit to a dosing pump running for 5 seconds every 2 hours.
ReefAngel.DosingPumpRepeat( Port7,0,120,5 );
//Set up for Refugium and Phytoplankton light cycle
//Ports that are always on
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
//ReefAngel.Relay.On( Port7 );
// Port1 = Heater
// Port2 = Heater
// Port3 = Refugium Light
// Port4 = Phyto Light
// Port5 = Return Pump
// Port6 = Protein Skimmer
// Port7 = Dosing Pump
// Port8 = Refugium Pump
////// Place additional initialization code below here //////Code: Select all
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;All right. So the code verified and looks like it's good to go. It's time for me to head off to work this morning. So I'm going to upload my modified full code and set up the vinegar dripping into a measuring cup to test it out during the day while at work. Hopefully I come home to the proper amount and will have this all set up and ready to go for my tank sitter
Current full code:
//Start of PWM Expansion Code Header
//This is just how we are going to reference the PWM expansion ports within the code.
//You can change the labels if you would like, just as long as they are changed all throughout the code too.
//Standard PowerRelay PWM Daylight = L-DT White/Color
//Standard PowerRelay PWM Actinic = L-DT Blue/UV
#define LEDPWM0 0 // R-DT = White/Color
#define LEDPWM1 1 // R-DT = Blue/UV
#define LEDPWM2 2 // L-DT = MoonLight
#define LEDPWM3 3 // R-DT = Moonlight
#define LEDPWM4 4 // - EMPTY -
#define LEDPWM5 5 // - EMPTY -
//Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={0,0,0,0,0,0};
//End of PWM Expansion Code Header
// - Creates a variable to control a "force cloud function" inside a menu.
boolean ForceCloud=false;
//added for custom menu set up
#include <avr/pgmspace.h>
// Create the menu entries
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "PH Calibration";
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Storm Effect";
PROGMEM const char *menu_items[] = {menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label};
// Creating the custom menu fucntions. menu2_label corresponds to MenuEntry2 funtion
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
// Trying to add a menu to the RA Head Unit so I can trigger a cloud effect on demand.
void MenuEntry8()
ForceCloud=true;
////// Place global variable code below here //////
byte LDT_DaylightPWMValue=0;
byte LDT_ActinicPWMValue=0;
byte LDT_MoonLightANALOGValue=0;
byte RDT_DaylightPWMValue=0;
byte RDT_ActinicPWMValue=0;
byte RDT_MoonLightANALOGValue=0;
////// Place global variable code above here //////
//This must be the first line.
// Initialize the custom menu
// Port1 = Heater
// Port2 = Heater
// ***PLEASE HELP HERE********************************************************************************************************************************************
//Sets values of ALL lighting channels to 0% on Start Up correctly, I think.
ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetChannel(LEDPWM0,0);
ReefAngel.PWM.SetChannel(LEDPWM1,0);
ReefAngel.PWM.SetChannel(LEDPWM2,0);
ReefAngel.PWM.SetChannel(LEDPWM3,0);
ReefAngel.PWM.SetChannel(LEDPWM4,0);
ReefAngel.PWM.SetChannel(LEDPWM5,0);
// I believe using this got rid of my bright flash to 100% when I uploaded new code. Specifically setting the Standard Daylight/Actinic
// Adds the date and time menu to controller so I can change for Daylight Savings Time. **Takes up memory space**
// - Can be removed after change or adding wifi. Time can be changed in portal or through phone app. eventually
//ReefAngel.AddDateTimeMenu();
////// Place additional initialization code above here //////
//USE THIS TO TOGGLE PORTS ON/OFF - ReefAngel.StandardLight(relay,onhour,onminute,offhour,offminute)
//Turns Refugium Light plugged into port3 on at 9:30 pm and off at 9:30 am.
ReefAngel.StandardLights(Port3,21,30,9,30);
//Turns Phyto Light plugged into port4 on at 9:30 pm and off at 9:30 am.
ReefAngel.StandardLights(Port4,21,30,9,30);
//// Calculate your regular sunrise/sunset PWM values ////
//_____________________________________________________________________________________________________________
// - Turns RDT - B/UV channel to 0% power between 8:55 p.m. and 10:00 a.m. to conserve energy
// - Dimming Expansion - LEDPWM1 - RDT Blue/UV -
// - Parabola dimming 11%-100%-11%
if ((NumMins(hour(now()),minute(now())) > NumMins(10,00)) && (NumMins(hour(now()),minute(now())) < NumMins(20,55)))
RDT_ActinicPWMValue=PWMSlope(10,00,20,55,11,100,240,RDT_ActinicPWMValue);
// - Turns LDT - B/UV channel to 0% power between 9:05 p.m. and 10:15 p.m. to conserve energy
// - RA Standard Power Unit - LDT Blue/UV -
if ((NumMins(hour(now()),minute(now())) > NumMins(10,15)) && (NumMins(hour(now()),minute(now())) < NumMins(21,05)))
LDT_ActinicPWMValue=PWMSlope(10,15,21,05,11,100,240,LDT_ActinicPWMValue);
// - Turns RDT - W/C channel to 0% power between 8:30 p.m. and 10:25 a.m. to conserve energy
// - Dimming Expansion - RDT White/Color -
if ((NumMins(hour(now()),minute(now())) > NumMins(10,25)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
RDT_DaylightPWMValue=PWMSlope(10,25,20,30,11,100,240,RDT_DaylightPWMValue);
// - Turns LDT - W/C channel to 0% power between 8:45 p.m. and 10:35 a.m. to conserve energy
// - RA Power Unit - LDT White/Color -
// - Parabola dimming 11%-%100-11%
if ((NumMins(hour(now()),minute(now())) > NumMins(10,35)) && (NumMins(hour(now()),minute(now())) < NumMins(20,45)))
LDT_DaylightPWMValue=PWMSlope(10,35,20,45,11,100,240,LDT_DaylightPWMValue);
//// Set MoonLights Cycles ////
LDT_MoonLightANALOGValue=PWMSlope(10,30,21,00,10,100,240,PWMSlope(21,20,23,15,20,MoonPhase()/5+10,30,LDT_MoonLightANALOGValue=0));
RDT_MoonLightANALOGValue=PWMSlope(10,20,20,50,10,100,240,PWMSlope(21,15,23,15,20,MoonPhase()/5+10,30,RDT_MoonLightANALOGValue=0));
CheckCloud();
ReefAngel.PWM.SetDaylight(LDT_DaylightPWMValue);
ReefAngel.PWM.SetActinic(LDT_ActinicPWMValue);
ReefAngel.PWM.SetChannel(LEDPWM2,LDT_MoonLightANALOGValue);
ReefAngel.PWM.SetChannel(LEDPWM0,RDT_DaylightPWMValue);
ReefAngel.PWM.SetChannel(LEDPWM1,RDT_ActinicPWMValue);
ReefAngel.PWM.SetChannel(LEDPWM3,RDT_MoonLightANALOGValue);
////// Place your custom code above here //////
//Connects Reef Angel Head Unit to the Portal through WiFi Unit.
ReefAngel.Portal("troubadour11");
// - My lighting is set up as:
// - LDT (Left Display Tank) fixture on the "Standard" 2 (PWM signal) slots on my power relay box.
// - RDT (Right Display Tank) fixture on channels 0=daylight and 1=actinic (PWM signal) of the Dimming Expansion.
// - Moonlights = channels 2 and 3 of the PWM expansion. These drivers are Analog and the jumper pins have been set for 0-10v Analog in Dimming Expansion.
// - I'd like to calculate the cloud effect for the LDT lights using the "Weather Sim for Standard PWM" code which I think
// I got copied, set up, and working correctly for the 1 fixture on the Standard Ports.
// - Then find a way to feed those values into the RDT lights with a "Random Sample" of + or - a small time offset for the cloud effect on the RDT
// - This way I could randomly generate a weather sim, and randomly have the cloud move Right-to-Left or Left-to-Right each time a cloud occurs
// - Lightning effect could either be off set with a similar way with +/- value OR left sync'd to LDT lightning (would need to test what looks good).
// - Or possibly more or less lightning per fixture during cloud.
void CheckCloud()
// I should create a random variable here to randomize the days it has clouds?
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
// Minimum number of minutes for cloud duration. Don't use min duration of less than 6.
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 12
#define Min_Clouds_per_Day 5
#define Max_Clouds_per_Day 15
// In this example, start could happen after 11:30am
#define Start_Cloud_After NumMins(13,00)
// In this example, end must be before 6:45pm
#define End_Cloud_Before NumMins(19,45)
// Percentage chance of lightning happening for every cloud
#define Lightning_Change_per_Cloud 50
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
//____________________________________________________________________________________________________________________________________________________________
//***Question***
// Why do you have to double the amount of time from 250 to 500 in your example? - This is just a question to understand the programming better, I don't see why it needs to be doubled.
// I see it in the code dividing by (numclouds*2), etc. What's the purpose of multiplying it up by 2? I'm just trying to learn on this question if you have time to explain. Thanks :-)
//#define forcecloudcalculation // Uncomment this to force the cloud calculation to happen in the boot process.
static byte cloudchance = 255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
//made individual lightningchance for each fixture
static byte LDTlightningchance=0;
//static byte RDTlightningchance=0;
static byte cloudindex=0;
//made separate lightning status for each fixture
static byte LDTlightningstatus=0;
//static byte RDTlightningstatus=0;
static int LastNumMins=0;
// - I created this value to use as +/- offset value to make clouds pass left-to-right or vice-versa.
//static int RDTcloudstartOffset=0;
// - I added this to use as a randomly chosen value between (-)x to y.
// - This will be added to "cloudstart" in order to determine the start time of the RDT cloud effect.
//static byte RDTcloudstart=0;
// - I added this to create a random sample between 80% and 100% dimming power for "random" lightning intensity effect on each fixture.
static byte LDT_LightningFlashPower=0;
static byte RDT_LightningFlashPower=0;
// - I added these to create a variable to randomize when and how long each lightning strike happens for each cloud.
//LDTlightningRandomStart=0;
//LDTlightningLength=0;
//RDTlightningRandomStart=0;
//RDTlightningLength=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
// pick a random number between these values to offset the RDT cloud by this many minutes
//RDTcloudstartOffset=random(-1,1);
// adds the random offset value to "cloudstart" and sets the cloudstart time for RDT light fixture
//RDTcloudstart=cloudstart+RDTcloudstartOffset;
LDTlightningchance=random(100);
//RDTlightningchance=random(100);
// if picked number is greater than Lightning_Change_per_Cloud, we will not have lightning on the next cloud.
if (LDTlightningchance>Lightning_Change_per_Cloud) LDTlightningchance=0;
//if (RDTlightningchance>Lightning_Change_per_Cloud) RDTlightningchance=0;
// Now that we have all the parameters for the cloud, let's create the effect down below.
// Force Cloud from Menu Function jumps to here to start cloud effect immediately for a show!
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
LDTlightningchance=1;
//RDTlightningchance=1;
cloudstart=NumMins(hour(),minute())+2;
//RDTcloudstart=NumMins(hour(),minute())+1;
// - Controls Cloud and Lightning Effect timings for both fixtures
if (cloudchance)
//is it time for cloud yet over Left Display Tank?
// - Dims LDT to create cloud and back up to Daylight Parabola. - maybe change to 11 in order to make minimum cloud power 11% so the lights don't click off.
RDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,10,180);
LDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,10,180);
RDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,20,180);
LDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,20,180);
RDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_MoonLightANALOGValue,11,180);
LDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_MoonLightANALOGValue,11,180);
// To adjust possible length of time of lightning strike, Change the "second()< 5 " ... where 5 is the # of seconds of lightning during cloud.
// and the "minute())=(cloudstart_(cloudduration/2)))" sets start time... dividing by 2 is exactly half way through cloud to trigger 5 seconds lightning.
// if there is lightning and current time is 1/2 way through cloud, but less then 1/2 way through cloud + 5 seconds
// if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/LDTlightningRandomStart))) && second()<LDTlightningLength)
if (LDTlightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<5)
if (random(100)<20) LDTlightningstatus=1;
else LDTlightningstatus=0;
if (LDTlightningstatus)
// - This will correctly flash lightning up to 100% power every lightning strike.
//LDT_DaylightPWMValue=100;
//LDT_ActinicPWMValue=100;
// - Trying to make a random sample between, say 80% & 100% for the brightness of the lightning?
// - If there will be lightning, pick a random number between 80 and 100 for the lightning power.
LDT_LightningFlashPower=random(80,100);
RDT_LightningFlashPower=random(80,100);
RDT_DaylightPWMValue=RDT_LightningFlashPower;
RDT_ActinicPWMValue=RDT_LightningFlashPower;
RDT_MoonLightANALOGValue=RDT_LightningFlashPower;
LDT_DaylightPWMValue=LDT_LightningFlashPower;
LDT_ActinicPWMValue=LDT_LightningFlashPower;
LDT_MoonLightANALOGValue=LDT_LightningFlashPower;
// - Changed these values from 0 to 11 so at end of lightning cycle, the go to min. 11% power
RDT_DaylightPWMValue=11;
RDT_ActinicPWMValue=20;
RDT_MoonLightANALOGValue=11;
LDT_DaylightPWMValue=11;
LDT_ActinicPWMValue=20;
LDT_MoonLightANALOGValue=11;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
//// - I think this resets the random offset and cloudstart time for the RDT Fixture to match the new/next "cloudstart" time if there will be another cloud today ////
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (LDTlightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
