Ok, let's try using the standard main screen.
If it still gives you problems, PM me to arrange replacement.
ATO alarm putting RA into overheat mode
Sebyte
Re: ATO alarm putting RA into overheat mode
I have run RAgen and built a PDE with standard menu, but retaining my custom code. Lets see how that works!
If this proves to be the issue, does that mean that I will not be able in the future to have custom screens? My next project is to build a custom LED lighting system and then implement the RA control and I thought that I might need to have custom screens to free up memory. That project is at least a month away.
Thanks for your help on this and I will PM you with update.
Absolutelly not.
If this turns out to be the case, we know for sure that the bug is in the Custom Main part of the code.
What I'm trying to do here is to identify where the problem lies.
Once the bug is found, we can fix it. The problem is that we don't know where it is at this point.
Sebyte
I have sent you a couple of PMs, not sure if they have been sent as they are still showing in my out box.
I'd like you to load this code. It will display the max temp registered for each T1 and T2 probes.
I modified from the previous one you posted.
ReefAngel_Features.h file:
PDE file:
* Copyright 2010 Curt Binder
* Licensed under the Apache License, Version 2.0 (the "License");
#define DateTimeSetup
#define VersionMenu
#define wifi
#define CUSTOM_MAIN
#define WDT
// Autogenerated file by RAGen (v1.1.0.126), (11/28/2011 13:34)
// RA_112811_1334.pde
// gold_build.pde
#define DisplayImages
#define WavemakerSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define wifi
#define SingleATOSetup
#define StandardLightSetup
#define WDT
#define CUSTOM_MAIN
#define ENABLE_ATO_LOGGING
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "sebyte";
prog_char probe3_label[] PROGMEM = "Not%20Used";
prog_char relay1_label[] PROGMEM = "Skimmer";
prog_char relay2_label[] PROGMEM = "ATO";
prog_char relay3_label[] PROGMEM = "Heater";
prog_char relay4_label[] PROGMEM = "Chiller";
prog_char relay5_label[] PROGMEM = "Wave%20Maker";
prog_char relay6_label[] PROGMEM = "Pumps";
prog_char relay7_label[] PROGMEM = "Actinics";
prog_char relay8_label[] PROGMEM = "Daylight";
relay3_label, relay4_label, relay5_label, relay6_label, relay7_label, relay8_label};
int t1max=0;
int t2max=0;
if (t1max<ReefAngel.Params.Temp1) t1max=ReefAngel.Params.Temp1;
if (t2max<ReefAngel.Params.Temp2) t2max=ReefAngel.Params.Temp2;
ConvertNumToString(text, t1max, 10);
strcat(text," ");
ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 10, 10, "T1 Max:");
ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 55, 10, text);
ConvertNumToString(text, t2max, 10);
strcat(text," ");
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 10, 20, "T2 Max:");
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 55, 20, text);
// Initialize and start the web banner timer
ReefAngel.Timer[4].SetInterval(180); // set interval to 180 seconds
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B00110001;
ReefAngel.WaterChangePorts = B00111111;
ReefAngel.OverheatShutoffPorts = B11000001;
ReefAngel.LightsOnPorts = B11000000;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port6);
// ***************** commented out at request of Roberto 28/11/11 *******************
// Change Overheat Temperature Probe from (default Temp2) to Temp1
// ReefAngel.OverheatTempProbe = &ReefAngel.Params.Temp1;
// Specific functions
// ReefAngel.SingleATOLow(Port2); // commented out 28-11-11 - rimai saying not needed
ReefAngel.StandardFan(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.StandardLights(Port7);
ReefAngel.MHLights(Port8);
// ATO available 6 times per day - 00:00 to 01:00, 04:00 to 05:00, 08:00 to 09:00, 12:00 to 13:00, 16:00 to 17:00, 20:00 to 21:00,
if (hour() % 4 == 0 && ReefAngel.LowATO.IsActive()) //Rev made 19/11/11
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
// Kalk Reactor available 6 times per day - 01:30 to 2:00, 05:30 to 06:00, 09:30 to 10:00,
// 13:30 to 14:00, 17:30 to 18:00, 21:30 to 2:00.
if (hour() % 4 == 1 && minute()>30)
pinMode(highATOPin,OUTPUT);
digitalWrite(highATOPin,HIGH); // Turn on Solid State Relay
digitalWrite(highATOPin,LOW); // Turn off Solid State Relay
// Wavemaker not available 9 pm to 10 am
if ( (hour() >= 20) || (hour() <= 9) )
ReefAngel.Relay.Off(Port5);
// Web Banner stuff
ReefAngel.WebBanner();
